Question about Maytag 24 in. MDBH950AWS Built-in Dishwasher
Do you sell silver door panel?
Do you sell the door panel? Woul it work for the white model, MDBH950AWW ?
Do you also have the door latch (to open it)?
    Champion:
  • 246 Answers
You should try applianceart.com for the panel
Posted on Sep 09, 2010
Unlocking dooropen it from inside and outside with key but when I shut it cannot stop it from locking
Sounds like you have what is called a dead bolt on your door these are so you do not forget to lock the door but can be a problem as locking yourself in or out.
In the spot where the little silver latch that goes in and out into the door frame that opens and closes to lock the door and open it there should be a little silver thing above it.
Open the door push the latch in and the silver thing above release the latch the latch should stay in. Then release the top lock.
Regards Craig
Feb 10, 2018 | Cars & Trucks
Older model (unknown) Whirlpool Dishwasher. Door latch failure. Dishes trapped inside.
You may have to break the little handle off to open it and order a new door latch mechanism. Just be careful. This is a lip latch so it wont be hard if you can get to where the latch connects. Use the internet and model to order new one.
Jan 23, 2012 | Whirlpool Dishwashers
Places of simcard in LG model cx9200
  • Power off your cell phone.
  • Remove the back battery plate. Depending on the make and model of the cell phone, you will either have to slide the panel off by applying pressure with your thumb or by sliding a small latch and then removing the plate.
  • Take out the battery.
    Look for the SIM card door. It will be shiny, silver and will be clearly marked. You'll also be able to see your SIM card.
  • Open your SIM card door by sliding it open (follow the arrow directions on the door) and sliding out your SIM card.
  • Apr 24, 2011 | LG Cell Phones
    Thought door was frozen shut on 96 grand am se so pulled it open and now it won't close latch not engaged and door lines up but won't stay latched shut....
    The latch may already be latched like it is closed. You can take a screw driver and put it.. where the latch engages Slightly pry outward agianst the latch while pulling on the door handle. That should release the latch. If you continue to have the problem than the latch will have to be replaced because there is a plastic piece that may be worn out.You will have to remove the door panel to replace the latch. They sell a book on that car that will explain how to remove the door handle(at O'rielly).
    Dec 09, 2010 | 2000 Pontiac Grand Am GT
    I opened the door on my sharp microwave and now it wont latch. it sounded like something snapped off where the door latches to the microwave, not the door itself . Even if the door is held shut the light...
    It may be the latch head spring or the door open lever or button.
    DOOR SPRING LATCH HEAD HOOK
    If you gently push up on the door latch heads (hook-like devices sticking out of the door) there should be spring tension. If they just flop right up, the spring is off inside.
    Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
    If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
    The door latch head (hook) is easy to replace or repair if that's the issue.
    you have to separate the door panels (as shown in the attached photo) and then you'll see how it goes together.
    Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
    DOOR OPENING BUTTON LEVER
    What usually breaks is the door open lever, but it may also be that the rear side of the door open button has worn down too far to work.
    On a counter top model, the outer cover will need to be removed to diagnose and repair this. On an over-the-range model, only the control panel needs to be removed.
    Please unplug the oven first.
    Once it is apart, you'll be able to see how the door open button would press against the door open lever, which would then lift up against the door latch heads (hook-like projections on the door) and the door should open.
    You can usually find exploded views and part numbers for Sharp models by entering your model number at the Sears parts site.
    If not, let me know. We have many Sharp manuals and if we have yours, we can link you to it at no charge.
    The best place to order Sharp parts is
    Encompass (formerly Tritronics).
    Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
    William E. Miller, AS-EET
    prototech@usa.net
    http://www.microwavedisplay.com
    Microwave Oven Control Panel Repair Nationwide
    Oct 10, 2009 | Sharp R-1480 Microwave Oven
    Maytag Model # MDB7600AWW door will not latch
    double check door latch make sure connections are proper if right and still not working probably main board and panel
    Apr 23, 2009 | Maytag MDB7100AWB Dishwasher
    Frigidaire Dishwasher (model FDB1050REB0) Wash Light Flashing
    Well, I've got a different problem. I need a control module!!!
    BUT!
    The flashing WASH light appears to indicate the door latch (switch) is not fully engaged. I proved that I mine which works, just doesn't pump out/drain water. If I unlatch the door and then press START, the WASH light blinks.
    *WARNING* 120V ELECTRICAL CURRENT! ONLY ATTEMPT THIS IS YOU KNOW WHAT YOU ARE DOING!
    The switch is located behind the control panel (5 screws from the inside.) The Hot (Black) AND Neutral (White) wires comes from the electrical input and pass through the switch. You can do a simple continuity check with the power disengaged to test the path through the switch and into the control module (pins 3 & 9m black and white).
    Now... anyone have a Control Module (working) they want to give/sell to me so I don't have to go buy a new dishwasher? I just replaced the drain valve on mine :( If you do, you can send me a note vidioteic (at) gmail (dot) com
    Happy Washing!
    Feb 13, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
    Broken handle on dishwasher
    Bernie,
    TURN OFF POWER TO UNIT. Open door, remove all torq screws from door panel, separate inner and outer door panel. latch assy is able to be removed, place black wire connector and white white connector back respectively, place inner part of door back and replace the torq screws. Then turn power back on for unit.
    Jan 09, 2009 | Maytag Dishwashers
    The door to the PSP won't open. The silver Open latch broke.
    go to gamestop and see what the problem is. They can repair it for about 19.99
    Nov 12, 2008 | Sony PlayStation Portable (PSP) Console
    Panasonic - convection/microwave oven door is stuck shut spring will not open same -dinner in oven help
    What usually breaks is the door open lever.
    removed.
    If you or someone you know wants to look into this, we have critical safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa.
    You can order Panasonic parts here.
    I hope this picture shows up - it helps illustrate:
    Aug 10, 2008 | Panasonic Microwave Ovens
    Maytag 24 in. MDBH950AWS Built-in Dishwasher Logo
    Top Maytag Dishwashers Experts
    Charles T Nevin
    Charles T Nevin
    Mike
    Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
