Question about Mitsubishi WS-65315 65" Rear Projection HDTV-Ready Television
Ws-65315 won't turn on
Hi there i'm a newbie at this i have a mitsubishi ws-65315 that won't turn on and also i hit and held the menu and input button on the front panle and i got code 12? whatever that means. any help thanks alot
  • 4 more comments
  • toyant1 Apr 08, 2008
    hey thanks a lot for the response, on the code part I believe that it is #12 not 12 codes sorry about that, and what see is the led turn on I hear it click to turn on but then it click off someone told me it could be the capacitor
  • toyant1 Apr 09, 2008
    i'm sorry whats that? Is there any pictures, diagram or schematic that you can send me? and how to check it out.
    thanks
  • toyant1 Apr 10, 2008
    yes my email is tonygarcia289@hotmail.com thank alot I appreciate it
  • toyant1 Apr 30, 2008
    hi there I'm sorry i thought i posted my email will here is my it is tonygarcia289@hotmail.com
  • lexibuddy Sep 26, 2008
    When I turn on the tv it will start the green light will come on and then shut off in 2 seconds. I plugged in the cord and the green light will flash 3 times. I have pressed the menu and input buttons and I got a 2-2 code. Now what do I do.
  • jmdarrell Feb 23, 2009
    i have same problem blinking light I have got tv to come back on a few times but now wont turn on at all. I have looked at all the comments and i just need to know where the capicators are located at or the schematics of tv. I have heard this could cost around $400.00 is this true? thanks
    Genius:
  • 1,153 Answers
Need to know more, 1-2 is no error code, you say will not turn on, do it has led light on or do you hear sound in set like high voltage? Any lights blinking? Or just completely dead, like fuse blown?
Posted on Mar 24, 2008
  • Lashawn Robinson Apr 08, 2008
    CHECK C5A09 AND C5A50 BOTH 33 UFD 50 V ON
    PCB-DEFL MINI
  • Lashawn Robinson Apr 09, 2008
    do u have email address?
I have a mitsubishi ws-65315. When I go to turn the tv on the green power light comes on and you can hear the tv click on, but seconds later shuts off.
this model has a self check, when green light comes on and then goes off. Push and hold both the Menu and Input buttons on the front of the set for at least 5 seconds and release both.
Power light will blink a two digit error code like 2 blinks 2 blinks, a pause and then repeat it several times.
Let me know what error code you find and I will tell you what it means.
SD TECH
Feb 22, 2011 | Mitsubishi WS-65315 65" Rear Projection...
I have a Mtsubishi ws-65315... I hit the menu and input and after 6 seconds, it blinks twice, then pauses for a second, blinks twice again, another pause, and does this 4 or 5 times... Can anyone help me...
Hello.
Most likely convergence circuit is out. Two convergence amps have to be replaced as well as some PICO fuses that already open. I would strongly recommend to let professional do this repair, without experience you can damage TV and make it unrepairable.
It should cost you around $300 to fix it at your home.
Regards.
Russ.
Dec 01, 2010 | Mitsubishi WS-65315 65" Rear Projection...
Mitsubishi WS-65315 plug in HD comp shows as 480i
Greetings,
In the input assignment menu make sure that the DTV (the only 1080 input on this tv) is set to Y/Pb/Pr and see if that fixes your issue with at least the HD-DVR.
BTW- the HDMI information "1080i HD can only be selected if TV has HDMI inputs". is not correct.
Feb 25, 2009 | Mitsubishi WS-65315 65" Rear Projection...
Tv won' turn on. Green light constantly blinking.
this tv is mitsubichi?
is mit what is the model?
look like bad DM, you need chage The capacitors.
Jan 31, 2009 | Mitsubishi WS-65315 65" Rear Projection...
Green light doesnot turn off on Mitsubish WS-65315
Just go to menu... then ..setup... then... timer ..and turn it off...... the blinking light goes away
Aug 29, 2008 | Mitsubishi WS-65315 65" Rear Projection...
Tv mitsubishi ws-65315 doesnt turn on,only green light
Good Day, cutito35; 1. This model is equipped with a keyboard lock feature; this can be mistaken as a no power condition. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds. 2. (Power LED may be on after plug in) check for no less than 4.4 volts DC at pin 3 of PC9A21 on the Power PCB, if low or missing replace PC9A21 part # 268P058020. 2.This model is also equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. Shutdown at power with self diagnosis error 2-2. Check for open fuses F9A04 and F9A05 part # 283P144080 on the +24 and -24 volt lines. If the fuses are open the convergence output circuit would be suspect. 2. Shutdown at power with self diagnosis error 2-1. At power on check for 12-volts DC at connector KH pin 8, if missing check IC9C51 part # 270P990010 and L9C52 part # 441D009020 on the Signal PCB. Good Luck, big IRISH.
Mit. WS-65315
A 21 code in mitsubishi is indicating that the set is shutting down for Xray protection. Which means voltages are rising and triggering a shutdown for safety reasons. You will need to trouble shoot the Xray circuit to locate the problem.
Jul 03, 2008 | Televison & Video
Shuts self off
Press input and menu on the tv panel and hold both buttons in together for 8 seconds and let me know if the led blinks a two digit code
May 04, 2008 | Mitsubishi WS-65315 65" Rear Projection...
Mitsubishi WS-65315 65" Rear Projection HDTV-Ready Television Logo
407 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
