Question about LG WM2688H Front Load Washer
My LG front loading washer is leaking at the door.
  • 185 Answers
Carefully check gray door gasket fot tears/waves/stretching on outer edge. if so, replace gasket. be sure gasket and door glass are clean where surfaces meet.
Posted on Aug 25, 2010
Lg tromm washer leaking from front door
We have the same problem with our LG washer. Don't think the door can be adjusted but I'm not for sure. I think the gasket is wore out but haven't checked on fixing the problem yet because it barely leaks.
Sep 29, 2012 | LG WM-2277HW Front Load Washer
I have a LG front load washer seem to leaking front area. Hoses OK Need o see what causes it to leak
you will need to narrow down where the water is leaking from. under the door...? behind the bottom drain door..? underneath machine..? behind machine..? leaks can be found in many areas.
May 16, 2011 | LG WM-2277HW Front Load Washer
Front door leaks
Get this, the recommended fix from LG is: Get some washers and add them to the door lock switch. So that the lock is offset more than normal and that will draw the door closer to the frame and stop the leak. I kid you not.
Feb 15, 2010 | LG WM-2277HW Front Load Washer
I Have an LG front load washer machineit leaked water and I am getting error code LE
le is usuaslly a bad stator or hall sensor at the rear of the unit.the most common leak on lg washers is from the btm of the door.if you see water trickling from the btm of the door. then the door latch needs washers installed between the panel and the latch .also ive had one or two that cleaning out the pump solves the problem, manufacture reccommends unplugging unit and waiting 4-5 min and plug it in , it may reset the board it has a lot of boards and electrical parts inside .
Sep 19, 2009 | LG WD-1280FHD Front Load Washer
My LG front loader is washer leaking water.
Could be the bladder from the drum to the door of the door seal. It could also be the drain pump hose.
Sep 13, 2009 | LG Washing Machines
LG front load washer leaks from door gasket
This is best left for a proffessional to repair
Affordable Appliance Repair
LAke Forest, CA. 92630
Aug 21, 2009 | LG WD-3274RHD Front Load Washer / Dryer
Leaking from bottom of front door
hi..
Try checking the rubber boot from the door opening to the drum for signs of hole or cracking..
thank u
rate me!!!
Aug 19, 2009 | LG WM2688H Front Load Washer
Water leaking from my front load LG washer
My LG WM2277HB also leaks after 4yrs of use. I found a hole in the front door gasket at the 3 o'clock position. I also have LE errors constantly.
Mar 09, 2009 | LG WM-2277HW Front Load Washer
Front load washer leak
This could be the rubber seal or the door lock. If the door lock is not pulling it tightly closed then it needs to be replaced. Check the seal really closely and make sure there are not cracks and it does not look deformed
Feb 16, 2009 | LG WM2277H Stainless Steel Front Load...
Leaking door
get a thin rubber ring of the same diameter of the door and fix it around tightly then the water wont leak out
Jul 25, 2008 | LG WM-2277HW Front Load Washer
LG WM2688H Front Load Washer Logo
245 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
