Question about Frigidaire FRS26ZSG
I have a basic chest freezer which freezes very well, and which I defrost regularly. For some reason, when it is full and freezing fine, it is also leaking water from somewhere underneath. How is this possible when there is no water being used by a freezer?
  • l_m_owen May 08, 2010
    I found the tubes and tied them together but I don't think that is the problem. After defrosting I tipped the freezer and inspected it underneath where I found holes in the bottom. Are they rivet points? They were damp and spongy round areas, and one of them had marks of being cut into a square shape. They were actually dripping when I inspected them. Is there anything I can do to these points to strengthen them? What is the normal life span of a chest freezer?
  • l_m_owen May 14, 2010
    Thanks again, Mr Frost. I didn't mention that the holes are about the size of a quarter. The freezer is 25 years old, and has moved once with us which involved 3 months of it being turned off. It's probably been leaking since we moved 10 years ago..I have noticed that it is not leaking at the present time. Maybe tieing the tubes helped. Time will tell.
  • 438 Answers
The dripping is due to moisture getting into the freezer possibly due to a bad lid seal, the moisture condenses into water and runs out a small drain hole at the bottom this can happen on occasion also when loading up new food in the freezer
Posted on Apr 28, 2010
Testimonial: "This sounds interesting. I will check the lid seal, which sometimes is blocked by chunks of ice,thanks. Maybe I need to defrost more often?"
  • Fal Mueller
    Fal Mueller May 17, 2010
    Hi fal again, your unit working fine? making cold ? cooling units will condense moisture and leek water, depends on climate,Where do you live ?
    President:
  • 1,218 Answers
Good day,
What you probably have is sweat back on the tubing that carries the freon back to the compressor, from the coils in the freezer.
If it runs extremely long periods of time, it will get cold enough to start sweating, then dripping on the floor.
At the factory, the line entering the coils, called a capillary tube is warm, and is soldered to the return line to prevent this problem.
They will many times become un soldered.
No damage will occur because of this other than being a nuisance.
It can be re soldered or in some cases re strapped using a quantity of zip ties.
P.S. The capillary tube is very tiny in diameter. Do not mistake it for a wire or abuse it in any way. It carries freon in it.
Testimonial: "Thanks."
  • John Hall May 08, 2010
    Good day,
    Sorry for the delay. Storm outage.
    Doesn't sound good. Seems to be an issue with insulation breakdown between the the inner and outer walls on the bottom.
    You didn't give the age, and like people, it varies. 20 years seems to be the consensus.
    Propping the machine up, and turned off, you could try an extensive drying out process, ideally using a floor fan. But I'm talking maybe 2 weeks. Not very practical for most people.
    Sorry, but that's the only thing I could suggest.
I cleaned my freezer and now it won't freeze
When you say "cleaned", did you defrost it? And. if so, could you have damaged the internal lining? Often the coil inside the wall of a chest freezer can fracture if hit or stabbed at during defrosting.
Other than that, is the compressor running (you would hear it)? it may have overheated. If not running, see if it feels hot (siezed) or cold (no power from thermostat). If cold, put it on fast freeze and see if it kicks into life (thermostat faulty) or not (compressor fault, time for a new freezer!)
Let me know how you get on!
Jul 05, 2012 | GE 14.8 cu. ft. General Electric Chest...
Water is leaking out onto the floor from freezer
The water is from the melted frost of the defrost cycle. The drain at the bottom of the back wall of the freezer is blocked so instead of the water draining into the pan where it will evaperate,it's pooling on the freezer floor and freezing, in many case when the floor indent is full the water will leak onto the floor.By pulling the refrigerator out from the wall,there will be a tube behind the service panel on the right side when looking at it from the rear,that tube can be removed and cleared,then clear the nozzle it connects to inside the freezer.
I hope this helps you to stop the leak,
Gene
Ads by Google' + // // '' + // '' + // makeBoldAdWords(google_ads[0].line1) + '' + // // '' + // makeBoldAdWords(google_ads[0].line2) + ' ' + // makeBoldAdWords(google_ads[0].line3) + // '
' + // google_ads[0].visible_url + ' ' + // '
' + // ''; // } // else if (google_ads.length > 1) if (google_ads.length > 0) { s += 'Ads by Google'; /* * For text ads, append each ad to the string. */ for(i = 0; i ' + makeBoldAdWords(google_ads[i].line1) + '' + '' + '' + google_ads[i].visible_url + ' ' + makeBoldAdWords(google_ads[i].line2) + ' ' + makeBoldAdWords(google_ads[i].line3) + '
' + ''; // '' + // makeBoldAdWords(google_ads[i].line2) + ' ' + // makeBoldAdWords(google_ads[i].line3) + // '
' + // google_ads[i].visible_url + ' ' + // '
' + // ''; } } } document.write(s); G_GGL_SKIP += Math.min(google_ads.length,G_MAX_ADS_AT); return; } var G_MAX_ADS_AT = 4; //var G_MAX_ADS_AT = 3; google_ad_client = "pub-8183356113384228"; // substitute your client_id (pub-#) google_ad_channel = "4447185069+3033438690"; google_ad_output = 'js'; google_max_num_ads = '4'; google_ad_type = 'text'; google_feedback = 'on'; if(typeof G_GGL_SKIP == 'undefined') { G_GGL_SKIP = 0; } google_skip = G_GGL_SKIP; // -->
Aug 22, 2011 | Admiral 26 cu. ft. Side-By-Side...
Inside water dispenser is leaking
If your chest freezer is showing signs of age, it may begin leaking. There are a few methods for troubleshooting faulty chest freezers but knowing some of the obvious signs of why it might leak can be very useful if you need to fix it yourself. Leaking is not limited to older models so be aware that certain maintenance procedures can help prevent leaks in newer models.
Understanding Changeable Parts Prior to Troubleshooting There are not that many serviceable or changeable parts inside a chest freezer. A chest freezer works on a very simple basis. It contains evaporator coils, condenser coils, a compressor, a compressor overload, a relay and a thermostat. These are the basic moving parts of a chest freezer but some of them are not serviceable.
The condenser coils condense the water and the evaporator coils disperse excess water caused by the freezing process. The compressor is a heating component which compresses excess water and recycles it through the system.
Defrosting Remove the contents of your chest freezer and place them in an alternative area to keep them frozen. Unplug and defrost your chest freezer before you do any troubleshooting or maintenance. Wipe and clean the inside of the freezer so that when you plug it back in it, will free of any grime or loose bits of debris. A clean freezer will also help to promote visibility when it comes to fixing leaks.
Where is the Leak? Once you have defrosted your freezer, you need to establish which part of the freezer the leak is coming from. It could be coming from the inside of the freezer and this would indicate a thermostat issue. Alternatively, it could be coming from the freezing unit at the back of the freezer. Water always finds a way to escape so your leak could be restricted to one place but the actual cause could be elsewhere. Locate the drain tube which is normally found at the back of the freezer. You will probably have to unscrew or unclip the backing panel.
Check the Drain Hole If the drain hole on your chest freezer has become blocked for any reason, you will need to clear it thoroughly to continue getting the best performance from your chest freezer. The drain hole is a component within the lower works of the freezer through which excess water runs to be recycled.
Compressor Issues Your chest freezer contains a compressor which evaporates the excess water from the freezer. The freezer will defrost excess ice and the water flows down the drain tube to a pan where the heat of the compressor evaporates the water. If your compressor has failed, the leak will be caused by the water failing to evaporate. Have a repair contractor replace your compressor or, if this is not cost-effective, you may need to buy a new freezer.
Thermostat If your freezer is not freezing at all and is dispersing water in several places, you may well have a thermostat failure. Check that your freezer is cycling correctly prior to making changes or altering the thermostat. Only if the freezer is not cycling are you likely to need to change the thermostat. If you have checked all the parts of your freezer and you still cannot locate the leak, calling in a service technician might be the best answer.
Hoping this will help to solve the problem....
Aug 18, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
Water leaking inside around the drain from the freezer, water collects in the bottom under the drawers
Defrosting
Where is the Leak?
Compressor Issues
Thermostat
Hope this will help in solving the problem...
Aug 04, 2011 | Amana ATB1504AR Top Freezer Refrigerator
Water freezes in bottom freezer and then leeks onto floor
Defrosting
Where is the Leak?
Compressor Issues
Thermostat
If your freezer is not freezing at all and is dispersing water in several places, you may well have a thermostat failure. Check that your freezer is cycling correctly prior to making changes or altering the thermostat. Only if the freezer is not cycling are you likely to need to change the thermostat. If you have checked all the parts of your freezer and you still cannot locate the leak, calling in a service technician might be the best answer if you can not handle it yourself..
Do take care in solving the problem....
Jun 28, 2011 | Amana Refrigerators
JEST STOP GETING COOL
start with a full interior defrost if required then check for any build up of ice under the cabinet(yes underneath)if icy do a full defrost(48hours)if not you may need to check the compressor/temp sensor etc...set at rapid freeze(if fitted) once dry and check again....
Oct 12, 2010 | Kenmore 19.7 cu. ft. / 558 liter Chest...
Does the kenmore cold spot chest freeze model 253.8193610 have a defrost timer
Chest freezers don't normally self defrost. They just freeze. To defrost them, you must shut them off.
May 02, 2010 | Kenmore Freezers
Chest freezer, stopped freezing, Ptc relay attached to compressor has overheated to point of partially melting.
Some of the PTC relays just give out for no apparent reason. (the brown ones more than any other) But in your case you can see physical signs of overheating. I would suspect the compressor has seized up, or has a shorted winding.
Jan 10, 2010 | GE Freezer  14.8 Cu. Ft. Manual...
Refrigerators Logo
214 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
