Question about Magic Chef MCBR170 Compact Refrigerator
I have never seen a fridge like this .does this fridge use refrigerant how does it work?
Posted on Jun 30, 2010
The fans are not working so the air is not circulation to cool the fridge what do I do?
I've never seen a comercial fridge with fans. I think you speak about the compessor. Assumed the fridge has power (iside light when you open the door) that means the thermostat is defective. Your fridge needs a new thermostat. It could be cheaper to buy a new one.
Nov 09, 2014 | Refrigerators
LG LSC26905TT refrigerator not freezing. Everything is melting in the freezer and fridge.. Lights are on, but no cold air is coming.
Remove all items from the fridge and keep open the fridge doors for atleast 2 days and that will remove all the frosted ice on the evaporator(which can't be seen) and shall work fine after two days.
Feb 26, 2014 | LG LSC26905TT Side by Side Refrigerator
Miele kf 3855 s-6 fridge part not working. Where is the thermostat?
The PCB is probably the temperature controller and most likely uses electronic temperature sensors in the refrigerator and freezer sections. Not having seen this model before, I'm guessing, but perhaps there is a problem with defrosting such as a clogged defroster drain tube, and the insulation between the freezer and refrigerator is iced up. This could also coat the refrigerator temperature sensor in ice if it is on the divider between the two compartments, thus fooling the controller into thinking the refrigerator is too cold. A manual defrost or drain tube inspection should rule this out.
Jul 16, 2017 | Miele Refrigerators
We have a Samsung Fridge Model No: SL39WJ1/XEU - the door is alarmed but now the alarm keeps just going off - for 3 days now and now going off every few seconds. The temperature lights etc at top of...
Even though this video shows a different refrigerator model, I have seen this with Samsung refrigerators (mine for example). I hope this helps.
Nov 22, 2017 | Samsung Refrigerators
My refrigerator is warm, but the freezer seems to be fine.
Top of Form
Since frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.Since Ice forms then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test from the outside and make your observations so that we come to the solution.
Nov 24, 2010 | Jenn-Air JFC2089HE French Door...
I bought at Dometic propane/ electric fridge for my cabin last year. It has not run properly since. The fridge will light and run for a while with a blue flame but sometimes in the idle mode it goes out....
I have to ask, what is idle mode? I've never seen one that runs on idle mode, in a RV in 15 years. Has anyone used a manometer and tested Inches of water column in propane supply to fridge, as well as other appliances?
Any I've seen run on propane, are either on, (flame present, or off, no flame present.) Flame goes out completely when not calling for cool.
Jun 13, 2010 | Dometic RM2620 Refrigerator
Freezer not cold, but fridge is
Condenser coil is probably dirty, or the fan isn't running. If the coil is under the refrigerator, it will probably be coated in dust like a blanket. Use a vacuum cleaner with a straight pipe extension wand. I've also seen a dead mouse stuck in a condenser fan blade.
Sep 15, 2009 | Refrigerators
Whirlpool GD5RHAXNT00 Side By Side Refrigerator
your  problem on this is the main control in the compressor compartment. unplug your refrig then remove this control unplug all connectors and reconnect. this will probably get you working temporarily In almost every case I've seen we ended up replacing the control board. thx peyton
Feb 07, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Fridge door suddenly won't close
Your refrigerator may not be level side-to-side and front-to-back
Jan 05, 2018 | General Electric GDL22KCWSS Stainless...
Magic Chef MCBR170 Compact Refrigerator Logo
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
vince
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
