Question about Sanyo 42 in. LCD TV
MY ORION TV KEEPS FLASHING PINK AND I HAVE FUNNY LINES ON THE SCREEN CAN ANY ONE HELP THANX ANT
  • Sanyo Master
  • 8,457 Answers
Ur Tuner signal board might be dead,need replacing or the incomming coalax signal cable is damage.Take ur tv to another location plug in another incoming coalax signal cable,if u have the same problems after the tv is on about 20 mins or less.Than ur Tuner board is the cause,tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.If the incommnig coalax signal cable is the problems,call ur cable companny.
Posted on Apr 28, 2010
Pink screen
Sensor failure. Washy, distorted picture. All funny colours.
Replace sensor.
Jan 12, 2014 | Fuji FinePix S5000 Digital Camera
Orion TVD2710. Lost remote, can't change signal input
I would suggest you try to find a universal remote that has an "input" or "source" button and program that one to your tv. By pressing the "source" or "input" button, it will change the input to the tv. I hope this helps! -Der Strom
Apr 06, 2010 | Orion STV2763 27" TV
Orion 42inch plasma screen tv problem
most likely a bad Plasma Display Panel. Costs more than a new TV
Jul 22, 2009 | Televison & Video
Orion and TV Converter box
Most converter boxes will hook up to your tv if it has an antenna jack. I'm guessing the list you were looking at was a list of converter boxes that could be purchased with the governments coupons, not a list of tv's. I hope this is helpful to you. Make sure the converter box you buy has coaxial out to tv jack(it will look like the ant in jack).
Apr 16, 2009 | Orion1934 19" TV
Two vertical yellow lines
MABE CONTACT ORION SUPPORT FOR MORE INFO
Nov 06, 2008 | Orion STV2763 27" TV
Screen is pink with rolling lines-no picture
This is a defective doubler/formatter board PT# 934C063001 which is available from Mitsubishi for $205.50 + S/H with another $75 core deposit. You may want to check with PTS Electronics at 1-800-797-8037 about sending yours in for rebuild. There are 2 other possibilities, Look for signs of coolant fluid on the the circuit boards (if there is your set is toasted) and a slight chance of the Signal board having a problem (fluid being the most common).
Nov 06, 2008 | Mitsubishi WS-55313 55" Rear Projection...
Line across the screen
dry joints on the field output ic is a fairly common problem with these.if a firm slap changes things,a simple resoldering job does the trick.resoldering is usually the cure ir the fault was intermittent.otherwise the ic may need to be replaced.cheap as chips,so to speak.hope this helps,steve.
Nov 05, 2008 | Orion STV2763 27" TV
32inch orion bad picture
Hii...
I'm absolutly have no idea whit thos tv set ( Orion ) but...your problem looks like mall function at the vertical circuits....can you see the ic or transistor nearst the FBT ? or you can type all the ic number/type and the Chassis of the tv set olso the Transistor around the Fly Back Transformer ?!
I hope it's can help you..
Hear from you soon
Thank's
[Vrya] be_cek@yahoo.com
Feb 23, 2008 | Orion1934 19" TV
Help me fix my orion tv problem
Let it run an autoscan or see if in the menu it has channels that are blocked or disabled.
Nov 26, 2007 | Orion STV2763 27" TV
Sanyo  42 in. LCD TV Logo
133 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
