Question about LG 50PC3D 50 in. Plasma Television
LED flashes green 3 times then turns RED...doesnt power
Unit use to take a few minutes to power...now nothing..
main power board....if so where & how much can I obtain for.
Also what would a authorized service repair shop charge me?
  • Kenneth Lee Sr. Apr 28, 2010
    the main power board needs replacement? Chu?
    will the part be still available...model discontinued...
  • LG Master
  • 8,457 Answers
Any BIG SCREEN TVS authorized shop,will charge u about $500-575 for parts and labors.Relating to the problems u discribing.
Posted on Apr 28, 2010
Testimonial: "very helpful...fast response..."
  • Chi Chu Apr 28, 2010
    Don't know which power boards are dead. There are two one primary,and a second dairy.Don't know which must take tv aparts first to examine.
    Most likely they take out the two power boards,examine and change parts.If the problems,it difficult to find.They probally order a refurbish power board for the replacement from many sources from the web.
Fujitsu airon ASTA24LCC 2 flashes green and red then 5 red flashes any idea what it means
Had similar problem (ie. 2 green & red flashed followed by 5 red flashes - Fan blowing but not cooling ... I also noted that the outside unit fan wasn't going). Tried restarting several time after waiting only a minute or two after turning the mains power off but with no change. So turned the unit off at the mains power and then fired it up about 2hrs later and it was all working fine.
Jan 24, 2013 | Fujitsu 24C1 Air Conditioner
Sharp lc-32sb220u lcd tv. Green Power LED flashes steady
Okay, I found the problem. There is a problem with the
ccfl (lamp) groung PCB. Mine is completely burnt through. I am going to attempt to repair it, but will likely need to extract it from a different unit. This board is on the front right of the lx in the lamp housing behind the
lcd panel. What is happening: The inverter circuit on the power supply is detecting that one of the lamps is not lighting and it goes into shut down.
Hope this helps!
~Seth
Feb 07, 2012 | Sharp LC Televison & Video
Bought in Dubai 3 years ago Pan.Viera LCD 32"\r\nStandby light flashing red/green. Have to switch on with on/off button after a few minutes switches off itself..........then back on itself
Power LED Blinking timing chart
When an abnormality has occurred the unit, the protection circuit operates and reset to the stand by mode. At this time, the defective block can be identified by the number of blinks of the Power LED on the front panel of the unit.
blinking
1 dg board, (stv 5v sense time out)
2 d board
3 d board
4 p board
5 d board
6 su sd sc boards
7 su sd sc boards
8 ss board
9 panel config
10 digi board-
11 pb board
12 h board
13 dg board
Tom Miller
Broadcast Eng
Mar 04, 2011 | Panasonic VIERA TX-32LXD80 32 in. HD-Ready...
Tv desn't turn on,power light just flashes ten times and then stops and then again
Error Indication Information
Error No. Error Information ERROR DESCRIPTION LAMP LED OSD LAMP OFF
(Note 3) (Note 4)
POWER LED TEMP LED
Note:
1.When any of the above errors has occurred, the LED will flash as shown above every 5 seconds.
2.When two or more errors have occurred at the same time, the LED will light up or flash as shown above, and then
change to another every 5 seconds in turn.
3.Warning OSD appears when the Air Filter is clogged 90%, accumulated operation time of the Lamp reaches 5000 hours,
or accumulated operation time of the Air Filter reaches 400 hours.
4.LAMP OFF: The LED will flash right after the Lamp goes off.
5.IC2301 is mounted on LCD Main C.B.A. which is included in the Projection Unit.
6.IC6001 is mounted on TV Main C.B.A.
Clogged air filter
more than 90%
15)
16)
17)
18)
1)
2)
3)
4)
5)
6)
7)
11)
8)
9)
10)
12)
13)
14)
- flashes 5 times -
every 5 seconds
IC2301(pin82) detects the clogged air filter, then indicates the
error when the air filter is clogged 90%.
Front Fan stop or
Lamp Fan stop
flashes orange
once every
5 seconds
IC2301(pin12) detects the Front FAN stop or Lamp
FAN stop, then indicates the error when the Front FAN
or Lamp FAN is stopped.
Lamp Cover open
Temperature Sensor
short or open
flashes orange
twice every
5 seconds
flashes orange
3 times every
5 seconds
flashes green for
140 seconds.
flashing red for
60 seconds.
light up red.
flashes once
every 5 seconds
flashes once
every 5 seconds
flashes red for
10 minutes
flashes once
every 5 seconds
Abnormal
Temperature
flashes twice
every 5 seconds
flashes twice
every 5 seconds
Request for Lamp
Replacement - - lights up
Power Ballast Error
(abnormal
Lamp voltage)
flashes 3 times
every 5 seconds
Power Ballast Error
(abnormal
temperature)
flashes 4 times
every 5 seconds
Power Ballast Error
(other causes) - -
Request for Filter
Cleaning -
Abnormal Voltage
on 16 V line of
LCD Main C.B.A.
flashes twice
every 5 seconds
flashes twice
every 5 seconds
Abnormal Voltage
on 14 V line of
LCD Main C.B.A.
flashes 3 times
every 5 seconds
flashes 3 times
every 5 seconds
Abnormal Voltage
on 7 V line of
LCD Main C.B.A.
flashes 4 times
every 5 seconds
flashes 4 times
every 5 seconds
IC2301(pin76) detects the Lamp Cover Unit condition
(open or close), then indicates the error when the
Lamp Cover Unit is open.
IC6001(pin85) detects the Duct FAN stop, then
indicates the error when the Duct FAN is stopped.
IC2301(pin74 and 75) detects open or short of the Temperature
Sensor (R2911) on Front Thermistor C.B.A., then indicates the
error when Temperature Sensor is open or shorted.
(The error is not detected for 1 minute after Lamp ON.)
IC2301(pin74 and 75) detects the temperature attached near
the Front FAN by the Temperature Sensor (R2911) on Front
Thermistor C.B.A., then indicates the error when the
temperature becomes more than 43 C (109 F).
IC6001(pin86 and 87) detects open or short of the
Temperature Sensor (R2901) on Lamp Thermistor C.B.A.,
then indicates the error when Temperature Sensor is open or
shorted.
(The error is not detected for 4 minutes after Lamp ON.)
the Lamp by the Temperature Sensor (R2901) on Lamp
temperature becomes more than 60 C (140 F).
IC2301(pin11) detects the error of LCD Power C.B.A.,
then indicates the error when the temperature fuse
(117 C)(243 F) in LCD Power C.B.A. is open.
IC2301(pin11) detects the error of LCD Power C.B.A. and Lamp,
then indicates the error when an inner malfunction of LCD Power
C.B.A. occurs, the Lamp voltage becomes more than 130V or
less than 30V, Lamp current becomes more than 5A, or the Lamp
is cracked.
IC2301(pin11) detects the error of the Lamp, then indicates the
error when the Lamp is short-circuit.
IC2301(pin48) detects +16V line voltage on LCD Main
C.B.A., then indicates the error when the voltage
becomes less than +13V.
IC2301(pin47) detects +14V line voltage on LCD Main
becomes less than +11V.
IC2301(pin45) detects +7V line voltage on LCD Main
becomes less than +5.7V.
IC2301(pin44) detects +3.3V line voltage on LCD Main
becomes less than +2.5V.
flashes 3 times
every 5 seconds
flashes 4 times
every 5 seconds
Abnormal Voltage
on 3.3 V line of
LCD Main C.B.A.
- flashes 5 times
every 5 seconds
Forced cooling
The failure of Lamp
light up
Temperature Sensor
short or open
Abnormal
Temperature
Duct Fan stop -
When accumulated operation time of the the Lamp reaches
5000 hours, OSD (replacing the Lamp) appears on the screen.
Note: The Lamp time is stored in EEPROM (IC2305).
When accumulated operation time of the Air Filter reaches 400
hours, OSD (cleaning the Air Filter) appears on the screen.
Note: The Filter time is stored in EEPROM (IC2305).
During forced cooling, this indication is indicated.
IC2301 (pin11) detects the failure of light up processing of
the Lamp, then the POWER LED is changed as follows.
1) POWER LED flashes green for 140 seconds (while turning on).
2) POWER LED flashes red for 60 seconds (while cooling).
3) POWER LED lights up red (standby).
Note: If the Lamp will not light after attempting turning on the
power 2 or 3 times, the Lamp, the LCD Power C.B.A. or the
LCD Main C.B.A. may be defective.
Error Symptom Problem Possible Solutio
May 30, 2010 | Panasonic Viera TH-50PX80U Plasma TV
Philips TV model 34PW9815/17 the LED on the front of the unit turns green when first plugged into electrical outlet, and then immediately starts to flash red. nothing on the unit works and it doesnt...
Philips TV model 34PW9815 the LED on the front of the unit turns green when first plugged into electrical outlet, and then immediately starts to flash red. nothing on the unit works and it doesnt respond to controls either on the set or the remote
May 12, 2010 | Philips 32PT81S 32" TV
Mine has the same problem, orange LED with humming sound coming from the speakers etc.
Someone brought one to me to look at..same problem. Checked power supply (easy to check, take off bottom cover and measure voltages on connector. standard 5, 3.3, and 12v outputs going to maine board.) Power supply was fine. took out main board and noticed several 100uf,16v caps that seemed to be bloated. replaced them and the unit turns on. Only thing i'm not sure about is the time it takes to initially turn on. when you first turn on main switch in back, the front led flashes green for about a minute then the LCD comes on and says "loading" which takes about 2-3 minutes, then the unit goes into standby mode (red Led) the unit will turn right on and off again quickly as long as the main switch in the back is not turned off and on again. Is it normal for it to intially take so long to boot? I do not know the normal operation as this is the first i attempted to repair.
Jul 03, 2009 | IceBox IBFS1 LCD Television
TV cant be switch on, RED LED diagnostic Blinks .. 3 times... then 4 times. Please advise probable cause and send sTV hcematic diagram.
Hi, this is main board failure and you will need to replace this vital board. you power board is fine but, it is unable to send a proper current through the main mother board due to the damage at hand.
May 21, 2009 | Sony KV-29FX30 29" TV
TV does not turn on/red led flashes 7 times in front
this is common issue with this model and through your troubleshooting is tied to y main board. blinking led on logic main in normal operation. when replacing y main always good idea to replace y upper and lowe buffer boards as they complete a circuit and sometimes replacing one without other could cause additional failure on remaining boards
Aug 10, 2008 | Philips 42PF7320 42 in. EDTV-Ready Plasma...
LG LCD TV Standby Light Flashing Red Continuously
I have had this same problem twice in the past 3 months. So far both times I've been able to get it back after a week or two. I'm not sure what works, but unplugging and detaching the antenna and cable and waiting a few days seems to be the key. In both instances, I unplugged it for a few days then plugged it in for a few days and repeated the processes until I eventually got the steady red led. Both times prior to the red led the led would flash red then green and make a clickiing noise for several hours before I was able to get it working again.
Apr 14, 2008 | LG 26LX1D 26 in. LCD HDTV
LG 50PC3D 50 in. Plasma Television Logo
592 people viewed this question
Computer Repairing
Computer Repairing
