Question about Polaris 800 Twin Sportsman Ride on Toy
My son's Peg Perego only runs in reverse. Any suggestions?
  • kpbello Apr 29, 2010
    Thanks. I'm not sure that is the answer I need. I should have put more info in my question (duh). We've had the peg perego for a couple of years and it ran fine in ALL gears (1, 2 and R). Now all of a sudden it will only run in R. If we shift it into 1 or 2 nothing happens. ????Help, thanks! :)
    Genius:
  • Polaris Master
  • 1,508 Answers
Sounds like a bad shifter switch
Posted on Mar 30, 2012
    Problem Solver:
  • 15 Answers
41 • GEAR SHIFT LEVER: The vehicle has three
speeds. ATTENTION: When the vehicle is first
removed from the packing, it only runs in first
gear (1) and reverse (R). To use the second gear
(2), proceed as follows:
42 • Screw down the second gear unit, as shown in
the following figure.
43 • 1-R: The second gear unit protrudes from the
chassis, preventing the gearshift lever from
moving down to the second gear. 1-2-R: The
second gear unit is completely screwed into
the chassis, and the gearshift lever can be
lowered.
link
http://www.pegperego.com/pegcatalogue/toys/downloads/Polaris700TWIN_FI000801G121.pdf
Look at diagram on page 4 of 44
Posted on Apr 28, 2010
2 Suggested Answers
adamfjeld
  • 1508 Answers
SOURCE: Peg Perego won't go forward, only will work in reverse.
shifter swicth is probably disconnected
Posted on Oct 16, 2012
Battery is full on my sons peg perego john deere but it wont run
did you verify the battery voltage with a multimeter, could have a bad charger that gives a green light making one think that the battery is fully charged, also check the fuse on the battery
Dec 14, 2015 | Peg Perego John Deere Turf Tractor
Hello, I purchased this Peg Perego Cub Cadet Tractor and trailer almost 2 years ago and have run across a problem. One day it just stopped running. We charged it up as we usually do when the battery...
yes, very common. probably the thermal breaker under the shifter. you can replace it with a 40 amp fuse or bypass it. dont worry its safe to bypass b/c there is a 30 amp fuse on the battery also.
good luck!
Jan 19, 2011 | Peg Perego Cub Cadet Tractor
I need instructions for gator. only goes in reverse
you can translate it by going to the page again & on your browser click page & in the drop down list select:
[ translate with live search ]
Cheers Rob
Jul 24, 2009 | Peg Perego John Deere Gator HPX
I bought a used peg perego stroller-model # 5086-Have questions..
if you go to peg perego.com then click on the online peg perego store. then click on accesories. they have a bunch of them for about 80 dollars. Im going through the same thing. also if you google peg perego p3 5086 manual a website pops up and has a manual you can print and save
May 25, 2009 | Peg Perego Pliko Matic Umbrella Stroller
!st gear won't work
I would replace the shifter assembly. It seems to be a better upgrade with the switches built into the shifter itself. It also has the wiring with it.
As long as the battery seems to work and the motors are going in one of the speeds, then there is not much to the vehicle.
It is a specific Peg Perego Switch assembly.
Hope this helps
Apr 18, 2009 | Peg Perego John Deere Gator HPX Ride on...
I have a John Deere Ride on Toy stuck in reverse
Are the actual shifter levers not engaging or are the switches not clicking?
These Peg Perego Parts are available at http://www.shopjandl.com/, but I would check to make sure if it is the switches specifically or the levers under the shifter.
It is simple to check the shifter by taking the 2 screws out that hold the shifter in.
Hope this helps.
Let me know what you find.
Apr 16, 2009 | Peg Perego John Deere Turf Tractor
MY SON'S 2 YEAR OLD POLARIS WILL NOT RUN IN REVERSE AFTER A NEIGHBOR CHILD RODE IT.
I would check and make sure the wiring on the foot pedal is on.
The Peg perego polaris models will sometimes get corrosion on the red wire.
I called the guys at this website http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego.html and they said to check the red connection. sure enough the connector was barely hanging on.
Hope this helps
Dec 05, 2008 | Polaris 800 Twin Sportsman Ride on Toy
Polaris 800 Twin Sportsman Ride on Toy Logo
273 people viewed this question
Top Polaris Toys Experts
Adam Fjeld
Adam Fjeld
cwradio73
D. E. Hev
Are you a Polaris Toy Expert? Answer questions, earn points and help others
