Init shredder not working the motor is running but the shredder part is not working. This started after clearing a paper jam. Model is NT-PS10CC
  • 61 Answers
Probably a stripped gear in the drive chain caused by overloading. Parts are not usually available for these low-priced machines. Sorry.
Posted on May 14, 2010
Omnitech shredder model ot--exc10a , shredder runs but when insert paper to shred it stops, pull out paper and it runs non stop!
Sounds like there's blockage between rollers and it also jams the sensor so auto function stops working. You will need to clear out as much jammed paper as you can using tweezers. Inspect the centre of the feed opening, there should be sensor which must be clear of blockages and moving freely. So clear any stuck paper with tweezers, in addition you can soak any jammed paper with WD-40 and unit should be good as new. Although if sensor arm is damaged then replacement of such sensor is unavoidable.
Nov 04, 2013 | Omnitech 18-Sheet Cross-Cut Shredder
My omnitech shredder OT-NXC8PA stopped working after clearing a paper jam. Seems the machine is running, but not sucking papers.
I think you just fried your gears. The motor is fine, but the gears that connect the motor to the shredding mechanism have had the teeth flattened up. No teeth on the gears = not shredding papers. The gears are made of plastic anyway.
Jun 26, 2011 | Aurora Electronics AS1015CD Cross-Cut...
My royal paper shredder is jammed. How do I unjam the shredder?
Normally try to run it in reverse while pulling the paper back out to assist the motor. If it won't even run in reverse then you will have to take it apart to manually clear the jam.
Sep 10, 2010 | Royal 15MX Shredder
My shredder quit working.
First thing you have to do is clear all jammed paper. Second..try running machine; if the motor runs and the blades turn put some shredder oil into the cutting blades as lubricant. If the motor wont run you have probably blown the pcb because of too much paper... to get replacement part call Royal at 1-800-524-0799.
Jul 15, 2010 | Royal Office Equipment & Supplies
My Init shredder was jammed and no will not come on. Model NT-PS12DC09. I cleared the jam.
I disagree with jerseypete, I know this model aint cheap. I got my for $100 and my friend got his for $65, but it depends on were u buy it. Some computers repair shops repair them or try looking for parts on ebay or go to microcenter.com they have everything if u cant find anything on their website try calling them.
Jan 17, 2010 | Shredder Office Equipment & Supplies
Shredder will not start when paper is inserted. switch is on auto. This happened after a long session of shredding
Two possible problems;
  1. Teeth underneath lid are jammed; sometimes (especially after a long session) although the papers go through, debris builds up and can get caught in the teeth; to clear unplug and with tweezers or a tina flathead screwdriver, pull out shreds of paper still caught
  2. Motor is overheated; once cool, try it again (move switch to reverse to see if motor is still working). If motor is working, see Step 1 for a jam; some jams can be cleared by running it in reverse. Royal doesn't recommend "long" shredding sessions. My unit recommends sessions of 20 pages or less. If you try to overwork the shredder, it will overheat and in some cases, fry the motor.
I hope this helps answer your problem. Best of luck!
Greg
Nov 12, 2009 | Royal 10X Shredder
I need to find parts for my paper shredder NT-PS10cc
Here is the customer support info for that company. They should be able to help you with the parts you need.
http://www.initproducts.com/t-contact.aspx
Jul 07, 2009 | Aurora Electronics AS1500CD Shredder
670 people viewed this question
jasbo
jasbo
