Question about Cuisinart PowerBlend 500 7Speed Blender
I have a blender/processor combination. the wheel
I have a blender/processor combination. the wheel on the base has broken into two parts, can the base be repaired, or the part replaced?
  • 5,603 Answers
Replace the part. Repair of the broken part is impossible to make reliably.
Replacement will take a bit of disassembly.
Posted on Apr 28, 2010
Base of my blender won't detach
please use the WD-40 for to loose and Ready.go www.40company.com
God bless you
Nov 06, 2013 | Cuisinart BFP-703CH SmartPower Duet...
The base is broken
check with abtec.com. They seem to have parts for the Hamilton Beach model 50754 blender but I seem to remember the blade and base come as one unit.
Nov 28, 2009 | Hamilton Beach 50754 WaveStation 10 Speed...
The rotor on the base for the food processor will not engage. It spins freely, and the black wheel on the bottom rotates, but does not engage the blade spindle. Why?
Usuallt, it is simple - you have the position the gear box of the food processor side until there is no gap between the gear box and the teeth on the base - this usually takes me a few tries to get it right.
If you are confident that there is no gap, call Cuisinart and see about getting a new gear box - 1-800-726-0190
Aug 16, 2009 | Cuisinart BFP-703 Blender
I have a BL1900 and the black plastic wheel on the base cracked and broke into a million pieces. It is the part that the glass liquidizer sits on - the collar from the liquidizer 'locks' onto the this...
You can order this part Black and Decker Blender Base Collar Ring BL5000-11
I also had the ring crack and ordered another one. It cracked after just a couple uses. So, even though you can get the replacement part, I'd suggest tossing the whole thing in the garbage and buying a different brand.
May 26, 2009 | Black & Decker BL1900R Blender
Broken Part
Hi, i read your are having trouble with the tap on your blender. We pulled our blender out of the box and used it for the first time and it leaked through the base, through the motor all over the bench top.
At first i thought the tap was leaking too, then I investigated a little bit and found it was leaking through the white tension clips on the inside of the black base.
Then i discovered that there is a recess for an "O" ring, which seals the glass jug to the black base thus solving the leak.
However there was no "O" ring in the recess and now I am trying to find a replacement one.
Hope this helps.
May 22, 2009 | Russell Hobbs 3902US Work Top Blender
My blender doesnt lock
Try going to MarBeck.com they are a great source for small appliace parts.
http://www.marbeck.com
Sep 12, 2008 | Black & Decker BL675 ProBlend Work Top...
I had to call Black and Decker directly 800-231-9786 to order the part (called the "collar"). It was $14.95 w/ shipping and handling!! Seems pretty steep for a piece of plastic.
May 04, 2008 | Black & Decker BL5900 ProBlend Work Top...
Broken gear on BFP-703 base
The drive is replacable and available from Cuisinart, you will have to sign a waver to get the part. the drive is screwed onto the motor shaft with reverse threads. the plastic drive will have to be completely broken off of the unit to expose a brass"nut" which was internal to the drive. depending upon your model you may have to remove the lower half of the base unit to access the lower part of the motor shaft. there will be a slot in the end of the shaft for a large flat blade screwdriver. this is used to hold the shaft still while turning the drive "nut" with a vice grip pliar or similar. the new drive is just threaded onto the shaft and normal operation tightens it.
Feb 14, 2007 | Cuisinart BFP-703 Blender
Open Questions:
See all Cuisinart PowerBlend 500 7Speed Blender Questions
Cuisinart PowerBlend 500 7Speed Blender Logo
531 people viewed this question
Top Cuisinart Blenders Experts
Hjalmer Lamminen
Hjalmer Lamminen
Oloyede Monsuru
eyecam
Are you a Cuisinart Blender Expert? Answer questions, earn points and help others
