Question about Conair Vacuums
I can't open G55 steamer to add more water. How does top come off.
    Genius:
  • 1,040 Answers
Would you like to provide me manufacturer?
Posted on Apr 28, 2010
My compact steamer does not let the steam out when I press the black release button help?
I examined mine. There is literally NO hole in the steam wand for the steam to exit. It's a wonder the thing didn't blow up. Take it back and be glad you still have your face.
Jan 01, 2015 | Top Vacuums
Shark Steam Mop - Gray/ Purple Vacuum: My shark steamer is heating up but not steaming. ...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
heatman101
May 17, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Solution?
you can use water only or add any extract chemical
Nov 24, 2009 | Bissell 1631 PowerSteamer ProHeat Canister...
CAN,T REMEMBER WHERE THE WATER GOES
Please open the top white lid and unscrew the top black knob with instruction on the back of white lid.
May 11, 2009 | Steam Fast SF-250 Mouse Vacuum
Can't get it open
had same problem. Tried pouring boiling water over cap and it seemed to loosen some so I boiled more water and put the steamer top down in a bowl in the kitchen sink and pour the boiling water in and let it sit about 5 minutes. It came loose with some effort. The grooves are the opening are metal and they had started to corrode.Once open coat with wd40.
Jan 31, 2009 | Kenmore Euro-Pro Ultra Steam Shark II Hard...
How much water should I put in Eureka model 300 steamer
Use 12 ounces of water.
It's best not to use extremely hard water in the Eureka steamer due to mineral deposits it may leave behind.
If you need cloths for your Eureka 300 or 310/311/313A see my listings on eBay by searching "eureka steamer."
This is a great floor cleaning machine. I have several for use on large areas of linoleum and sealed hardwood in our home.
Jan 04, 2009 | Euro-Pro Shark SC-505 Handheld Steam...
Can't get the top unscrewed
I had the same problem. Mine had been stored for a year. We had to completely destroy the plastic cap. Once down to the metal underneath we did the boiling water thing. It didn't work at first so we tried it again. And then immediately after applying the boiling water we used ice water to make the metal contract. With pliers on the neck and pliers on the lid we were able to open it. But, I know my husband had to put some strength into it. Hope this helps you all!!!
sorcha1580
Nov 16, 2008 | Euro-Pro Shark SC-505 Handheld Steam...
Dirt devil easy steamer need directions to use
Thank you for responding to my question. I should have spent some time really looking at my little machine. It wasn't hard to figure out -once I found and read the back of the cleaning solution bottle and tried my luck following the water to cleaner ratio.. Opening, adding the cleaning solution and water and re-closing the reservoir was pretty easy. Everything worked out fine...and my carpet is...spotless. Thank you, Cmarie
Mar 27, 2008 | Dirt Devil Easy Steamer Upright Wet/Dry...
Heats up and produces steam but the release button does not open the flow of steam.
To remedy this, I did the following:
1) Removed screws from: a) Lower area of handle (1 screw), b) Top of steamer, under round rubber flap around fill hole (2 screws), c) Front of steamer where nozzles attach (2 screws)
2) Removed back of handle, top of steamer, front of steamer where nozzles attach
3) Once all parts are removed, you can see a brass button that is pushed by the trigger
4) Using a needle-nose pliers, grasp and rotate the button several times in both directions (you may hear it cranking against the interior spring). Do this until it turns fairly easily with the pliers.
5) Once this is done, you fill find that the brass button can be very slightly depressed with a bit of force. You may also need/want to unfold a large paper clip to push into the nozzle hole to help unsticking the brass button (not sure if that helped in my case, but it was something I tried along the way). When the brass button moves in and out (again, it won't move much), the steam release mechanism is unstuck!
6) Reassemble all parts (everything snaps back neatly into place).
This worked for my unit!
Nov 11, 2007 | Scunci 52067 Handheld Steam Vacuum
Vacuums Logo
27 people viewed this question
Top Conair Vacuums Experts
ray gallant
Tom Chichester
Robert wilkins
Robert wilkins
Level 1 Expert
Are you a Conair Vacuum Expert? Answer questions, earn points and help others
