I have a Denon DRA 697C1 receiver,and my speakers are 300 Watts, when I give volume to the receiver, it get hot and shut off, How can I solve this problem?
  • 3 Answers
Which speakers do you have? The Denon is best for 6-8 ohm speakers. If your currently hooking them up to speakers that are 4-6 ohms, it will shut off to protect itself. The other thing to check is the wiring. What guage are you using?
Posted on Apr 30, 2010
Testimonial: "my Speakers are 4 ohms, and my speaker wiring is a monster cable ULT I1000-4"
Can dra 37 be used as a pre-amp without connecting speakers
If you mean a sa control center for source selection, volume and tone control, yes, but NOT for a turntable (no PHONO).
Controlled audio goes emerges from the pre-out. Page 9.
http://www.retrevo.com/support/Denon-DRA-37-Receivers-manual/id/696dj086/t/2/
But you could still use its own speaker terminals if your exxternal amp has is remote or has its own volume control to match it up with other speakers.
Sep 05, 2011 | Denon DRA-37
Denon dra 397 shuts done if I turn on both zone a & b. Have a 100 watt volume control on each pair of speakers. Works fine with only zone a or zone b on, but not both.
Let's understand this - you have an external volume control wired in series with each front speaker set?
Can you elaborate on their electrical characteristics?
http://www.retrevo.com/support/Denon-DRA-397-Receivers-manual/id/696dj087/t/2/
Page 24.
A + B 8 - 16 ohms
Jan 22, 2011 | Denon DRA-397
My denon dra-697ci receiver volume plays fine for a couple of minutes then the volume cuts off how can i fix it easy
You have bad connections on your circuit boards, if you are handy with a solder iron then you will need to touch up the solder joints.
Jan 03, 2011 | Denon DRA-697CI
Denon dra-95vr receiver has no sound out. All
Two things to check. First, the 95VR can be deceiving because it has a "variable loudness" control that some may mistake for volume. The actual volume is controlled by the big up and down arrows on the upper right side. If the volume is turned up, you should see the volume bar graph display show up. If none of the inputs are giving you volume, and the volume is turned up, then try running the output from the processor loop output in the back to another amplifier. The processor out is jumpered to the processor in for normal operation. Missing jumpers could cause a problem also. If there is sound coming to the processor out, then you have a problem with the power amplifiers. Best to refer that to a technician.
Dec 29, 2009 | Denon Audio Players & Recorders
I want to know how many watts, the denon dra-375's output is? my brother-in-law gave me this unit and the cover's became diattatched off the back of the all the pot's. i am still in the process of putting...
The unit is rated at 120 watts total output ( 60 watts per channel x2 channels) As far as being worth fixing it depends on the price of the parts and what you want to do after its fixed. I looked around a little and the unit gets good reveiws from owners. They say its great for a "just music" system.
Jul 28, 2009 | Denon DRA-375RD Receiver
Denon receiver (DRA 397) will not speak to iPod dock
IF YOUR NOT USING A DENON IPOD DOCKING STATION IT WILL NOT FUNCTION CORRECTLY.
YOU CAN CONNCET OTHER TYPES OF IPOD DOCKING STATIONS BUT YOU WILL NOT HAVE CONTROL THROUGH THE DENON AND ONLY CONNECT THE AUDIO FOR THAT DOCKING STATION TO THE DENON AS ANOTHER SOURCE INPUT
Oct 13, 2008 | Denon DRA-397
Denon DRA 395 flashing red power light
Needs to be reset or fuse blown. Take to repair shop, cover has to be taken off and fuse replaced. You could fix it yourself but the warranty won't be honored. Do it yourself electronic shop should have a replacement fuse, may have to be soldered in place. Repair shop, should cost around $30.00 to $45.00 to fix, price of fuse $4.00 to $6.00. Your choice.
Mar 27, 2008 | Denon DRA-395 Receiver
Denon DRA 395 volume creeps to max by itself
I also had this problem with my Denon DRA 395. I fixed it by replacing the batteries in my remote! Apparently when the remote batteries are nearly gone, but not 100%, they are capable of prompting the remote to unilaterally increase the volume at irregular intervals. It was kind of spooky!
Oct 01, 2007 | Audio Players & Recorders
121 people viewed this question
 Grubhead
Grubhead
