Question about Dryers
MOTER SQUEEKING -MAYTAG - Dryers
    Top Expert:
  • Dryers Master
  • 76,673 Answers
The motor is not squeaking the drum roller s and belt are, replace them and the noise will ggo away, the belt is the biggest cause of noise. here is how u replace the dryer drum belt.
Instructions Things You'll Need:
  • Flathead screwdriver Phillips screwdriver Assistant
  1. Step 1 Look up your specific model number and buy a replacement belt from a MaytagMOTER SQUEEKING - 2_bing.gif dealer or a third-party supplier of replacement appliance parts.
  2. Step 2 Unplug the dryer and remove the exhaust vent tube from the back.
  3. Step 3 Pull out the lint screen. Use a Phillips screwdriver to remove the screws around the lint screen housing.
  4. Step 4 Slide the blade of a flat screwdriver underneath the top panel at one of the front corners of the machine. Pry the top panel up slowly, being careful to not nick or scratch the finish. You should hear a snap when you've lifted the panel high enough; that noise is just the latch releasing.
  5. Step 5 Repeat Step 4 on the other front corner of the machine and then lift the hinged lid up.
  6. Step 6 Firmly grasp the top edge of the front panel of the dryer. Wiggle it to the front and back slightly as you lift upward, and the panel should come loose from the latches holding it in place.
  7. Step 7 Slide the front panel forward while your assistant supports the inner drum. Pull the front panel completely off of the machine.
  8. Step 8 Reach underneath the drum and pull out the broken belt.
  9. Step 9 Slip the replacement belt around the drum while your assistant continues to support the front of the drum. Turn the belt so the grooved side fits into the visible grooves around the circumference of the drum.
  10. Step 10 Get on the floor again and locate the motor underneath the drum. You will see two round pulleys; the larger one is the motor pulley and the smaller one is the idler pulley. Grab a section of the slackened belt, fold it in half and push the loop underneath the idler pulley. Wrap the loop around the motor pulley.
  11. Step 11 Push the idler pulley to the side, away from the motor. The grooves on the pulley should fit just right with the belt, and moving the pulley over should create tension in the belt all the way around the drum.
  12. Step 12 Slide the front panel back up against the machine, working with your assistant to fit the front of the drum into place. When the drum is secured to the front panel, slide the panel straight down into place. You may hear or feel it lock into place when you've pushed down far enough.
  13. Step 13 Lower the top panel and push it down until it snaps into place. Replace the screws surrounding the lint screen housing and put the lint screen back.
  14. Step 14 Reattach the exhaust vent tube and the electrical plug.
Posted on Apr 28, 2010
Dryer makes a squeeking,or "chirping" noise while
Most likely the problem is the drum rollers are in need of lubrication.
Lube the drum rollers and this should solve your noise problem
Jan 05, 2011 | Maytag MDE9700AYM Electric Dryer
My dryer is squeeking when turned on and stops when the door is opened or it is stopped. what could cause this?
most dryers have drum rollers and an idler pulley. either of these could be squeeking. it also could be the motor bearings going bad.
May 24, 2010 | Maytag Dryers
Maytag washer noise
Hello, If its making a loud squeeking/scraping noise, in my maytag that i repaired, the problem was the waterpump. If you turn the washer on it's side, you will see that it has a belt with three pully's on the bottom. One pulley is connected to the waterpump and right where the pulley meets the metal plate it's connected to, there should be a gold2_bing.gif coupling. This coupling sometimes comes loose and scrapes the metal plate on spin cycle (when the pulley is spinning) which causes the scraping/squeeking sound. If this is the case, you will see where the coupling has scraped a groove into the metal plate. The coupling will eventually catch while spinning and break entirely. The cheapest new water pump is $80.
Thanks
May 19, 2010 | Washing Machines
Dryer squeeking while tumbling & leaves black smudge on clothes
it sounds like a drum support roller is going bad or the belt idler pulley. i think maytag has a kick panel on the bottom that can be removed. look inside with a flashlight and you may be able to see something. if not, you may have to take the drum out to get a really good look. make a note and study how the drive belt serpentines around the motor, pulley, and drum so you can get it back together.
Oct 20, 2009 | Maytag Dryers
I have a Maytag Legacy Dryer SDE305DAYW that is squeeking. How do I change the belt?
the belt is not causing the squeek. either the tub rollers, or the idler pully is squeeking. you must remove the front panels and drum to inspect these parts. usually when a roller or idler pully is squeeking, you need to replace them. if they arnt to worn, you can clean the shaft and grease them to stop the squeek, but i dont recomend that, as it will just be a temporary fix and will start squeeking again. this isnt a easy repair if you've never done it. let me know if you have any further questions. Shane
Jun 19, 2009 | Dryers
Maytag MDE5000 squeeks while running
hahhaha your celfone is ******* noob bulshit ************
Mar 29, 2009 | Maytag Atlantis MDE5000 Electric Dryer
Dryer making squeeking noise
Check the dryer belt tensioner and pulley assembly. It be wearing out. You'll need to remove the back cover of the dryer to do this. Turn off the gas and/or electric before working on the unit.
Mar 26, 2009 | Maytag MDE9316 Dryer
Dryer was squeeking now not spinning
It sounds like the dryer belt is wore out or broken, you can usually order a replacement belt from the maker of your dryer at there website.
Mar 11, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Squeeking noise
it could be the bearings going out on the tub from the sounds of it
Jan 24, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag gas dryer makes squeeking noise
it is more likely one of the drum rollers
Dec 20, 2008 | Maytag Dryers
Dryers Logo
Top Dryers Experts
