Question about Nokia 1208 Cellular Phone
My cellphone's keypad is not functioning well..if i press the numbers 3 and 6 it will be automatically followed by the clear key.. it's very annoying.. and every time i will click the number sign, it will automatically shut down..
  • 311 Answers
Hi may be there is a small problem with your phone just tight your phone's screw may be this works thank you
Posted on Apr 28, 2010
'tab' button doesn't work on Motorola MC3190
You get 3 different keypad models of the Motorola MC3190:
- 28 Key Numeric
- 38 Key Shifted Alpha
- 48 Key Alpha Numeric
So depending on the type of keyboard your model has, using TAB are different across these 3 keypads.
Please Note: Keypad functions can be changed by an application so the mobile computer keypad may not function as described.
When the FUNC button is pressed the icon "F" appears on the taskbar on WinCE devices or the icon "Blue Circle" appears at the bottom of the screen on Windows Mobile 6.1 devices.
In order to use the TAB function, do the following:
28 Key Numeric - Press the blue FUNC button (Bottom right next to Power button), and press the RIGHT ARROW button.
38 Key Shifted Alpha - Press the blue FUNC button (Right side below RIGHT ARROW button), and press the RIGHT ARROW button.
48 Key Alpha Numeric - Press the blue FUNC button (Right side below ENTER button) and press the number 9 button.
Apr 18, 2014 | Zebra Symbol MC3190G Handheld Mobile...
Konica minolta bizhub 215 showing maintenance call(m2) and service call
Utility-stop-0-0-stop-0-1 for service mode. choose clear data, then supply count then ok to clear. On/ Off the machine it will work as usual.
Apr 03, 2014 | Minolta Office Equipment & Supplies
Richo infotec 3090 SC 593
- Toner Suction Motor Replace Alert.
- The total operation time of the motor exceeded 600 hours.
- The toner suction motor has reached the end of its service life.
- You can try rest it, after some time it will start to print light prints.
- So you will need to replace it.
- You can clear the code in Service Mode.
- To enter into Service Mode you need to follow the next procedure:
- Press the following key in the following order:
1. Press Clear Modes [yellow key] .
2. Press 1 - 0 - 7 [ with the blue keypad numbers ] .
3. Press and hold down Clear key [ C key] for 5 seconds.
(after release of the C key, the Touch Screen will change)
- On the touch screen press the [Cop SP] .
- Press the following number with the blue keypad:
[ 2 - 9 - 7 - 3 - 0 - 0 - 1 ] then press [ # ] .
- On the right side of the touch screen should write the following:
[ Toner Suction Motor Operation Time ] .
- Press [ 0 ] with the blue number keys, then press [ # ] .
- After doing all of this re cycle the machine by turning it off,
wait for 10 second, and then turn in on with the main power switch
[Red Power Switch] .
----------------------------------------------------------------------------------------*note: the machine will work again with this procedure but maybe,
after some time, or maybe even immediately after this,
the machine will start to make light prints.
Mar 12, 2014 | Ricoh Aficio MP 1600SPF Black Toner...
I AM NOT CELLPHONE SAVVY ! I have an LG CG225. If someone is calling me and I do not answer and they want to leave a message, what do I need to do? create a voicemail box so they can leave a message? ...
Issues of accessing/setting up VM on your mobile or Inquiries on accessing your VM using your mobile phone?
I can help you w/that.there are 3 ways on accessing your VM via your mobile phone:
1st:
Long press the number 1 key on your phone's keypad then it'll dial your VM number and would ask for a PIN if PIN is setup.
Follow recording instructions or voice prompts and key presses until you get to hear your voice messages.
2nd:
For some mobile phone service providers,dialing your own mobile number automatically transfers you to your VM.again,if PIN is set up?it'll ask you to enter it,if not it'll automatically proceed to your VM.
Follow recording instructions or voice prompts as well as correct key presses until you hear your voice messages.
3rd:
Almost all mobile phone service providers has a so called "Voice mail Access Number"
This number can be dialled and goes straight to VM.
Voice prompts might ask you to enter your mobile number following the star key or pound sign on your mobilephone keypad.
Voice prompts might also ask you to enter your VM PIN(if seup).
Just follow Voice prompts and you're good to go.
Hope this helps.
Thanks,
FixerDelta
Sep 15, 2011 | LG CG225 Cellular Phone
Canon ir2870 error code e000002
these means that in fixing assy is low temperature. It can be that you only need to clear the error trough service mode, or you need to change thermistor.
To clear the error:
enter the service mode:
1) Press the asterisk key " * " on the control panel
2) Press the 2 and 8 keys of the keypad at the same time.
3) Press the asterisk key " " on the control panel.
then choose COPIER, then FUNCTION, then CLEAR and choose ERR. Shut down and back ON the copier.
If these doesn't helps, replace thermistor which is inside of fixing film ceramics.
Jun 12, 2011 | Canon Office Equipment & Supplies
I want to find out how to set up our Canon CFX0-L4000 fax Machine
CANON CFX-L4000 UNOFFICIAL MANUAL
RIGHT KEYPAD
FUNCTION
SET
01 DATA REGISTRATION
02 DELAYED TRANSMISSION
03 POLLING
04 MEMORY REFERENCE
09 REPORT
11 UP
13 +
14 LEFT
15 SPACE
16 RIGHT
18 CLEAR
19 DOWN
Keys 1-20 are speed dial keys. If speed dial is not set, message is displayed and manually entering the telephone number is prompted. Press STOP to clear.
Pressing FUNCTION accesses the menus associated with keys 1, 2, 3, and 4. After accessing a menu, the cursor keys, SET, and occasionally the telephone key pad are used for selecting options and setting values.
EG. Setting a speed dial number:
FUNCTION - DATA (01) - SET - SET - UP/DOWN to select speed dial number - SET - UP/DOWN to set number/name - SET - UP/DOWN/LEFT/RIGHT/PHONE KEYPAD to enter value - SET
EG. Setting unit telephone number
FUNCTION - DATA (01) - DOWN once - SET - DOWN once - SET - PHONE KEYPAD to enter number - SET
EG. Retransmit from memory (assumes memory light is on)
FUNCTION - MEM (04) - DOWN once - SET - UP/DOWN to select document number (LEFT/RIGHT to view associated telephone number) - SET
EG. Delayed transmission
place document into feed - FUNCTION - TX (02) - SET - PHONE KEYPAD to enter time to send - SET - PHONE KEYPAD to enter phone number - SET - SET - document is scanned and will be transmitted at set time
for full guide you will have to search and purchase one.
May 28, 2009 | Canon Office Equipment & Supplies
Keyboard letters 'm,j,k,l,u,i,o' permanantly locked for numerals. i have no idea how i switched this function on.
NumLock is on. Look for the Fn key in the lower left corner, and lookint in the top right, the NumLock key.
Mar 22, 2009 | HP 2133 Notebook PC
Help needed on N95 8GB
This problem is from your keypad Ic, Possibly it is working automatically. You need to change Keypad IC and then software re-install.
May 12, 2008 | Nokia N95 Cellular Phone
Format
In the Flip Closed mode, turn the Jog Dial one notch:
UP
Press *
DOWN
DOWN
Press *
DOWN
Press *
(The * symbol is the one on the botton left on your keypad)
This will take you to the hidden service menu, choose option number 3; Service functions to start the format. The process should only take a few seconds.
This will completely clear everything out of the phone just like the day it was new. Gets rid of all the folders left behind by a master reset.
Dec 12, 2007 | Sony Ericsson P900
ConairPhone SW324WCS
I just had same problem and went conairphone site and found model sw322 that looked about the same. I downloaded the manuel and it worked for my phone. Here it is. MEMORY FEATURE To Program Your CONAIRPHONETM telephone is equipped with 10 memories for programming your most frequently dialed telephone numbers. You can store up to 16 digits in each of the numeric keys (0 through 9), by following the steps outlined below: 1. Lift handset (releasing hook switch). 2. Press and release STORE key. 3. Press the keys for the telephone number you wish to store. 4. Press and release the STORE key again. 5. Press the keypad number (0-9) you want that telephone number stored in. 6. Your number is now stored. 7. To change a stored number, repeat the same process. The new number will store over the old stored number. A Memory Index card is provided for your use in writing down the person?s name. To Retrieve Memory Numbers Keypad Memories: To retrieve numbers stored in the keypad, pick up the handset and press the MEM (Memory) key. Then press the keypad number (0-9) which stores the telephone number you want to dial. Your call will be automatically dialed.
Jul 12, 2007 | Conair SW324WCS Corded Phone
Nokia 1208 Cellular Phone Logo
63 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
