Question about Kohler 3386-6 Rialto Skylight Round Front Toilet
KOHLER TOILET TOILET MAKES A MOANING SOUND WHEN FILLING
  • 20 Answers
It sounds like a slight flow restriction. Take the fill valve apart and clean all of the guts.
Posted on Apr 30, 2010
My kohler persuade toilet won't fill up
Kenny, the gurgling sound is coming from a stoppage in the air vent located above the toilet on the roof. It has to be open to allow proper drawing of air to pull the contents from the toilet. You also have something lodged in the trap as the water goes out. If a snake doesn't clean it out, then you probably will need to take the toilet up and clean from the bottom side. You can a hose with a sprayer and bllast out from the bottom and most of the time that will free up the blockage.
Feb 18, 2013 | Kohler Persuade Two-Piece Elongated Toilet...
Kohler toilet-Cimarron is having problem with filling tank with water, fill tube is in the canister center but the level in the tank doesn't rise and toilet keeps running, there is not a flapper and no...
i don't know about your toilet but i googled it and found this it's the flapper and flush valve
https://www.plumbingsupply.com/images/kohler-flush-valve-1044458.jpg
and you can go here and see all the parts in it,hope this helps you out.
https://www.plumbingsupply.com/kohlertoiletparts-cimarron.html
Dec 20, 2017 | Kohler Cimarron 2-PC Elongated Toilet with...
I have a kohler model 703 # sb78drn, the toilet keeps running. i changed the flapper and now the toilet doesn't stop running. please help?
Try adjusting the float level. The float is what tells the toilet to stop filling. If the float is set too high, then water will just go down the overflow tube and never be able to get to the level it needs to turn off.
Mar 04, 2011 | Kohler Toilet - One Piece with Ingenium...
I have Kohler 3386-6 Rialto Skylight Round Front Toilet problem is that tank filling is very-very slow, perviously it used to fill in few seconds now it is taking 15 min. please let me know how can...
There is a screen @ the inlet to the vavle where the water connects that may be plugged or contact Kohler they will send you a repair kit for the fill valve.
Dec 12, 2010 | Kohler 3386-6 Rialto Skylight Round Front...
My Kohler toilet tank is not filling fully, the water that is filling the tank sounds so loud it sounds as if the sink faucet is running instead of the toilet filling and the bowl does not fill fully and...
Change out the ball **** and float assembly and flapper valve to one of the newer types...
Also you can set the level of water in the tank by an adjustment screw located at the top of the ball ****.
The Flapper valve on the bottom of the tank also needs replacement, that is causing the tank not to drain properly.
This is a free answer, please rate me
Oct 13, 2010 | Kohler Home
My Kohler toilet is about 5 years old and is making this awful whistling sound after being flushed. What part needs to be replaced so I can make it quiet again!?
The valve that fills the toilet is making that sound... it is filling up with dirt and the water is struggling to get through the smaller hole...
heatman101
Sep 03, 2010 | Home
Just bought and just had installed a Santa Rosa toilet that will not shut off when filling. Found flush valve filling chamber to have a triangular hole close to base of cylinder. when you cover this...
I would say yes....here is the .pdf for your toilet and it has nothing like that in it...your toilet should be a simple fill device and flush mechanisim...
I would return it for a new one...
http://www.us.kohler.com/onlinecatalog/pdf/1066506_2.pdf
heatman101
Aug 05, 2010 | Kohler Santa Rosa K-3323-0 White Compact...
I have a Kohler Highline toilet that sputters
Did you try to lubricate with something waterproof to stop the squeak? How about grease? Petroleum jelly, something. Or how about a weight on the high side to balance it out as it goes up. A lead sinker or a penny. Hope this helps.
May 25, 2010 | Kohler Highline - Comfort Height Two-Piece...
Toilet tank not filling
shut the water off to the toilet .Remove the toilet supply from the tank end.slowly turn the valve on to see if their is any water coming thru the supply.If water is coming thru the supply than you know you need to change the ballcock.This is the part in the tank where the water comes out of.
Feb 01, 2009 | Kohler Santa Rosa K-3323-0 White Compact...
Kohler 3386-6 Rialto Skylight Round Front Toilet Logo
182 people viewed this question
Top Kohler Home Experts
john h
Tim Whalen
Mike
Are you a Kohler Home Expert? Answer questions, earn points and help others
