Question about Craftsman 20 hp 42 in. Deck Yard Tractor
Oil blowing from dipstick on 18HP Briggs and Stratton (Craftsman)
Oil blowing from dipstick on 18HP Briggs and Stratton also smokes (white). Any areas to begin looking.
  • 138 Answers
SOURCE: Craftsman 18.5 briggs/str 42''
flop the seat forward, push the connector firmly onto the seat switch [in the middle of the seat underside], should solve your problem, or the switch could be bad, but not likely unless you're 300lbs
Posted on Aug 17, 2009
SOURCE: craftsman lt 1000 wont stay running
Take a paperclip and clean out the small hole on your gas cap. And yes I am being serious.
Posted on Aug 25, 2009
  • 146 Answers
SOURCE: 10 A Fuse blows each time I shut off engine. Short
Yes, probably a short, and I think you should look at the ignition switch as the first suspect. It has two switches inside - one to send battery power to the various components, and a separate one to ground out the magneto when the mower is turned off. Could be a short between the two parts of the switch. Test it if you have the tools, otherwise try replacing it. Good luck! If this is helpful, please take a moment to rate my solutions, thanks!
Posted on Jun 10, 2010
vetteman3002
  • 2299 Answers
SOURCE: I have a Briggs n
You have a blown head gasket. The gasket is leaking the fuel into the oil. You will have to replace the head gasket.
Posted on Sep 28, 2010
2strokeguy
  • 183 Answers
SOURCE: Lt1000 18hp Briggs and Stratton
Go to your local auto parts store and buy an inline spark tester if you don't have one.
Next time the engine stalls, use the inline tester (goes between spark plug and plug wire) to see if there is spark. If there is no spark, then most likely the engine has overheated the ignition module. Check the oil level, low oil level will cause overheating. Check the cooling fins, clogged fins will cause overheating. The ignition module will need to be replaced for a long term repair. Make sure to correct any overheating condition also. When/if you replace the module, it is a good idea to inspect the flywheel key. It is located under a very large nut on top of the engine. If the flywheel has rotated on the upper crankshaft, the flywheel key (aluminum) will have been damaged. This also can cause an overheating situation.
Posted on Oct 25, 2010
Why is my briggs and stratton blowing oil out the breather
Two possibilites one is the rinds are broken or worn or there is too much oil in the machine
Jul 29, 2014 | Craftsman Garden
WHY DOES WHITE SMOKE COMES OUT OF THE SIDE
If it's coming from around carburetor area than you most likely have a blown head gasket. It's building up to much pressure in block and its blowing out your vent tube.
Jul 28, 2014 | Briggs & Stratton Briggs Stratton Intek V...
17hp briggs and stratton blowing oil out of dipstick
looks the rings are stuck.when you have head off check piston. john.
Mar 10, 2014 | Briggs & Stratton Garden
Briggs & Stratton Vertical OHV Engine 18 hp blowing white smoke engine run great but a lot of smoke and also have oil being spit out of the black hose that come from engine to the carb.
Check your oil.
If it is overfilled, milky, or smells like gas. Your going to need to change that ASAP. It sounds like the float has stuck in the past or is still sticking, and it has flooded the crankcase with gas, which has mixed with the oil. And because it is overfilled it comes through the breather hose into the carb. This also explains the smoke most probably because the oil is spewing in the carb through the breather and being burned.
Jul 05, 2011 | Briggs & Stratton Briggs Stratton Intek V...
Started by Craftsman 2700 PSI , 2.3 GPM Briggs & Stratton Powered Pressure Washer for first time in 9 months. Added new oil, and gas. started but is smoking from muffler and is dripping what appears to...
The first thing I would check would be the oil level, to make sure you didn't put in too much oil. If the oil level is correct, it could be a stuck piston ring, letting oil blow by the piston, and out the exhaust. If this is the case, you are going to have to tear down the engine.
Hope this helps!
May 09, 2011 | Craftsman 2700 PSI,2.3 GPM Briggs &...
I have an 18hp v twin vanguard and it is
Piston rings being wore.Thanks for asking and I hope this helps out.Please leave me 4 thumbs up.
Jul 20, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
Mower blows white smoke
Depending on how old is your mower, it could be broken rings in the engine, or just excess oil. I would recommend to check oil level first.
Hope this helps!
May 24, 2010 | Craftsman 675 Torque 190cc 21" Briggs ...
Briggs and Stratton 22hp v twin OHV smoking badly
First thing to do is pull your dipstick and check for broken or missing O-ring also as you pull it, look to make certain that it was seated properly and all the way locked. If either condition exists, you will be leaking into the crankcase which will cause your symptoms
Jul 11, 2009 | Briggs & Stratton Briggs Stratton Intek V...
18 HP V tech B&S single is smoking only 4 years old
18HP vertical Briggs & Stratton vtech twin ohv; can't find oil leak; motor runs great; is leaking onto housing where motor is bolted to; any suggestions where leak may be coming from????????
Jul 01, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Craftsman 20 hp 42 in. Deck Yard Tractor Logo
335 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
