Question about Boating
Need to install water pump in a 87 lowe pontoon with 30 hp evin rude motor
  • 64 Answers
The water pump is in the leg, you must disconnect the gear linkage and undo the bolts that hold the bottom of the leg in place( pointing up above water intake). Dont forget the one near the propeller. Wiggle the leg and slide downwards. place the leg on the bench , the drive shaft protrudes from the center of the water pump housing. Undo the bolts holding the housing on, and slide it off. Be sure to install the new impeller with the rotors folded in the correct direction to avoid pinching. when re installing the leg be sure to align the water cooling pipes correctly. It is always a good idea to refer to a workshop manual when attempting any maintenance upon machinery.
Cheers, Timo.
Posted on Apr 29, 2010
I have a 1987 24' lowe pontoon boat. I need to know the max hp motor that i can put on it
You need 50hp to run it, but to fly, if she is strong you can try 150hp or even 300hp at your risk...
Mar 27, 2017 | HP Boating
What should the tilt be set at for a 12 ft pontoon with a 15 hp motor
Bill,
The tilt is dependent on weight in the boat, location of people, etc. The majority of people set it by feel. For a pontoon with low horsepower a general setting is set it so the propeller is horizontal to the floats (pontoons). Since you only have a 15hp on it I would set it this way. That way your propeller is pushing water straight back and all power is utilized in moving the boat and not wasted on raising or lowering the bow/front of the boat under power which is what your tilt up or down does. Raise it up your bow goes up. Tilt it down and your bow goes down.
Fred-
Aug 06, 2016 | Boating
Water pump impeller change
There is another bolt up under the zinc plate on the cavitation plate.
Jun 04, 2010 | RTO Oar Sockets
2005 Water Skeeter Pontoon..What kind of pump for the valves
If you look up Halkey-roberts valves you will see the air filler part.
May 24, 2010 | Water Skeeter Guide Lite Pontoon Boat
2 hp Swimming Pool - Jet / Well Pump Motor / Century B124: Water pump from swimming pool to filter lost it's ...
NOT THE MOTOR ,THE SEAL... JET PUMPS ARE NOT FOR POOLS.. LOW FLOW HIGH PRESSURE.. YOU NEED HIGH FLOW LOW PRESSURE ... IF NOT YOU MAY HAVE A SUCTION LEAK OR A BAD SHAFT SEAL... VOTE JAY
May 17, 2010 | AO Smith 2 hp Swimming Pool - Jet / Well...
Endura 30 Freshwater Transom Mount Trolling Motor: I JUST PURCHASED A Pellican pontoon boat 10e and i...
probably an endura 50 would be a better fit for a potoon boat. assuming the boat is normal size. if its a smaller one then this motor might work just fine. give it a try and see if it moves you about fast enough for your taste.
May 15, 2010 | Minn Kota Endura 30 Freshwater Transom...
MOTOR SIT TOO LOW IN THE WATER ON PONTOON BOAT WHEN GOING OVER 3000 RPMS
you need to trim the motor by adjusting it so it is more vertical. It must be angled down into the water too much now and so it is pulling itself deeper in the water,
Oct 07, 2009 | Boating
Boat engine 1995 Johnson Outboard 70 HP
Ihave a 1991 70 hp Johnson outboard thats hard to start the first time but starts good after that. Seems to be flooded. Starting rpm seems to be low.
Jun 25, 2009 | Boating
Low pressuere motor pump when i plug the vacumm drop 30 to 5psi
if your filter pressure is 30 psi it needs to be backwashed! Reson pressure drops when hooking up vacuum cleaner is reduced water flow will drop pressure
May 15, 2009 | Pentair 1.0 Hp Whisperflo Pump
Boating Logo
103 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
