Question about Scotsman Ice Machine, Cuber, 1930 lb. Unit, Head Only
I have a C0530 cuber and after harvesting the ice the harvest cycle eventually gets timed out. Could there be something wrong with a sensor. If yes which one. After resetting it work again but only for one cycle before it times out again.
2 Suggested Answers
vanni7
  • 163 Answers
SOURCE: CME500 ICEMACHINE MAKES ON BOTTOM PART OF CUBER ONLY
Hi!!!Relax you just answer your question.If you went and advance the timer and it work but was stuck in the same position well its your bad timer.change timer and you will be fine..Good luck
Posted on Jan 05, 2009
Scotsman icemachine constantly freezing up no matter how small you put the setting?
Max harvest cycle just keeps it in a harvest longer. if you set the freeze setting to its lowest point and ice is still to thick then replace the freeze stat.
Feb 22, 2015 | Scotsman Ice Machine, Cuber, 1930 lb....
Why does my cme306 scotesmen go into the harvest cycle in just 40 sec. of starting up
The first thing it does after a failure or power disruption is go into a harvest cycle.It will be a prolonged cycle at the first start . then it should operate normally
Jun 28, 2014 | Scotsman Cooled Modular Contour Cuber Air...
Model CME256AS-1D will not go back into freeze cycle and will eventually stop, requiring the unit to be reset.
So is the unit going into a harvest and not going back to a freeze cycle? dose it dump a batch of ice but wont go back into a freeze cycle? before you reset it have you pulled the front cover to see what code it is giving? any time you have to reset it that means it locked its self out on a fault. if unit freezes and go's into a harvest and dumps the ice but dose not go back into freeze cycle check the door switch when the ice dumps the deflector door opens a magnetic switch which tells the board the harvest has finished and then the freeze cycle begins. Now if there is no ice falling off the plate to open the door then the board will time out and try 3 more times to make ice before it locks it out. the same go's for the harvest.
Jan 08, 2014 | Scotsman Cooled Modular Contour Cuber Air...
MY SCOTSMAN ICE MACHINE IS MAKING ICE, BUT ITS TOO HARD AND CHUNKY HOW CAN I FIX THE PROBLEM
First is the ice to thick coming off of the evaporator plate? If so then you need to adjust the ice thickness probe located at the top of the evaporator plate it is white with a 1/4" screw going through it, turn if left an 1/8" at a time let it make ice and check each batch. Now for chunky ice is it melted together? If so then make sure the machine is not dumping water into the bin during harvest if it is then check the dump valve to make sure it is opening during harvest cycle.
Oct 31, 2013 | Scotsman Cooled Modular Contour Cuber Air...
Low ice output
Low ice production has multiple causes. First check condensing coil to see if they are dirty and not passing air. This is the most probable cause for low ice production. Next, measure freeze cycle time and harvest time. Freeze time is typically 20 to 30 minutes and harvest time is normally 1.5 to 3 minutes. If freeze time is long (> 35 minutes), first check water valve shuts after reservoir is full. If it does not shut off the water solenoid operated valve needs replaced. Second, find the harvest solenoid operated valve which branches off the compressor discharge and port high temperature gas into evaporator during harvest and see that evaporator side of harvest valve cools down to surrounding temperature in a few minutes 8 - 10 after freeze cycle starts and harvest time stops. If it does not cool off the valve is leaking by its seat and will require a technician to replace. Lastly, if long freeze cycle could be due to low refrigerant and will require and tech to charge properly. Ice machine are critically charged and a tech will know how to charge the right amount. Again, it is possible the metering device is not passing enough refrigerant and a technician can determine this by checking the superheat and subcool. Low subcooling <3 and a high superheat >20 typically indicate an txv (metering devise) needs replaced and will require a tech to replace.
Oct 13, 2013 | Scotsman Ice Machine - 290lb...
Code 8 blinking machine making very thin ice?
Short freeze, thine ice.
Cause: Grounded ice thickness sensor.
Solution: Check sensor for dirt and position. Clean and adjust gap to evaporator surface using 13/64" drill bit as a gauge, lay flat between evaporator plate and ice thickness probe and adjust 1/4 screw 1/8 of a turn clock wise at a time after every harvest cycle. You don't wont the ice any thicker than 13/64 or thinner either. If you are still having problem after cleaning probe then replace it but you will still have to adjust the probe.
Aug 08, 2013 | Scotsman Cooled Modular Contour Cuber Air...
I have a hoshizaki ice machine and it will harvest for about 3 harvest and just before the 3 harvest it shuts off. It makes us up untill it shuts off. It beeps 3 times. DONT know what to do! NEED SOME...
How long is a freeze cycle on your unit? How big are the cubes that it's dropping? The three beep error indicates that the unit exceeded maximum freeze time.
Sep 05, 2010 | Hoshizaki KML-600M Low-Profile Crescent...
Jan 05, 2009 | Scotsman Cooled Modular Contour Cuber Air...
Scotsman Ice Machine, Cuber, 1930 lb. Unit, Head Only Logo
50 people viewed this question
Top Scotsman Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Tim Whalen
Are you a Scotsman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
