Question about Canon PIXMA iP90 Mobile Printer
My I90 printer stop printing I have new ink but still doesn't print. how do i unclog the nozzle. I haven't use it for sometime now. What can I do to get it working again?
  • 4,041 Answers
Hi There
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Posted on Apr 28, 2010
Why won't it print or scan?
How To Unclog Brother Multifunction Inkjet Printhead Nozzles
www.inkmagic.com/shopcontent.asp?type=Unclog...Inkjet_Printhead...
Many Suggestions and Directions to Unclog you Brother Multifunction Inkjet ...problem when a new cartridge is put in, your Brother printer will do a priming. ... So, before you blame the compatible cartridges for your Brother printer not printingproperly, ... Many companies want you to believe that "one ink does all printers".
How to Unclog Epson Printhead Nozzles - - InkMagic ...
www.inkmagic.com/epson_clogged_printhead.htm
Clogged nozzles - Epson printers Epson printers have a built-in, permanent printhead.... To overcome this problem when a new cartridge is put in, your Epson printer ... If you manage to get all nozzles printing after 6, 8, 10 or more cleanings your ...InkMagic International remanufactured 2,000 - 4,000 HP inkjet cartridges a ...
All-In-One Printer Fails To Print Black Ink? - Super User
Jan 05, 2016 | Epson Inkjet Multifunction Machines;...
The black ink has stopped printing. Put in two different new cartridges and that doesn't seem to be the problem. It was first noticed when photos were printing out funny even after changing the color...
Make sure you are inserting genuine Lexmark cartridges.
Try to clean the cartridge nozzles. Refer to the steps below:
Cleaning the Print Cartridge Nozzles:
1. Open the Lexmark Solution Center. Click Start > Programs or All Programs > Lexmark 1300 Series. Select Solution Center.
2. From the Maintenance tab, click Clean to fix horizontal streaks.
3. Click Print. A nozzle page prints, forcing ink through the nozzles to clean the clogged nozzles.
4. Print the document again to verify that print quality has improved.
Using the control panel
1. Press Menu.
2. Press the down arrow button until you highlight Clean Cartridge.
3. Press Select. A nozzle page prints, forcing ink through the nozzles to clean the clogged nozzles.
Oct 13, 2011 | Lexmark P4350 All-In-One InkJet Printer
Can you Help me unclog my nozzle? Epson Picturemate PM240. Head cleaning 3x not successful: no blue ink at all. Print cartridge is brand new and showing 100% full. It tells me to replace the print...
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
May 18, 2011 | Epson PictureMate (C11C556001) InkJet...
When printing, the top half of page prints normal... bottom half of page very faint...
Your ink cartridge has about 9 very small nozzles that spray ink to complete a letter the upper nozzles complete the upper half and the lower half is done by the lower nozzles. The lower nozzles are stopped or clogged up by dried up ink or the control resisters in the firing circuit are burned out. some times you can unclog the nozzles by soaking the lower part of the cartridge in hot water for a half hour and drying it well ,replace it in the carrier and try it again. However you will lose a lot of ink and it may be more prudent to replace the cartridge.
Dec 02, 2010 | HP inkjet 2280 Printer
I need a new print head
Check if the service station proper covers the black nozzles when the printhead is parked. Sometimes the mechanics change its position and the printhead dries out.
Try to unclog the nozzles with very hot water. Sometimes it helps. The new printhead is very expensive and you may want to buy a new printer instead.
Remove the printhed, put it in a bowl with the nozzles down and fill with boiled water until the nozzles are covered. Wait 15 min and dry the electric contacts with a dry napkin. Good luck!
Jun 15, 2010 | Canon PIXMA MP530 All-In-One InkJet...
I have a ip4200 and when printing in black it is faded and stripe
The print head is clogged.Make sure black ink cartridge have ink and then try unclogging with cleaning tests in maintenance mode.If not help try unclogging manually.Open the cover and first remove the ink cartridges.Then open the holder and remove the print head.Run hot tap
water and put the print head with the nozzles up to stream water.Hold that 5 mins then turn the print head around with the nozzles down.Hold that for every color of 5 mins.Then put the print head in hot water with the nozzles down.Left it water about 15 mins and then you must very nice to dry.When the print head dry put it in printer and start cleaning.If
this not help you need to replace the print head.
Nov 20, 2009 | Canon Office Equipment & Supplies
After replacing ink, I (sometimes) get a color, but never black. Is this an issue with the ink purge tube? This is not much fun.
The print head is clogged.Try unclogging with cleaning process in maintenance mode.then wait 4 - 5 hours and run nozzle check.If not help run cleaning again and then wait 1 day.If this not help better think about new printer, because the cost of new print head is profitable.
Nov 08, 2009 | Epson Stylus CX6400 All-In-One InkJet...
After replacing cartridge in dell 810 the colours printing wrong
Hi
If you haven´t used your inkjet printer for a while it may just be dry ink clogging some of the nozzles in the print head.
To check if yours is clogged...
Remove the ink cartridges
Holding the cartridge upright and press down gently onto a paper towel.
The colour cartridge
you should see YELLOW, MAGENTA (red) and CYAN (blue)
But if any colours are missing? The inks have probably just clogged up? and you will need to buy a new one or if you know you still have ink then you can easily unclog it with a
Magic Inkjet Flush Kit (Which you can find on Ebay)
MIXED COLOURS
If you have others colours coming out then the colours have mixed...
Sometimes caused when people put tape onto the inks to keep them moist but instead the colours mix through capilary action.
If so... leave print head sitting on a paper towel for a few mins until the correct colours appear.
Read more about ink clogs here:
How to Clean, Fix, Repair, Unclog, Dry, Clogged Print Heads on CANON, EPSON, HP, Lexmark, Dell, Olivetti etc…
To prevent an ink clog it is best if you print something regularly about every 10 days to keep the tiny print head nozzles / jets open. Otherwise the ink in the print head will thicken. Then it´s like trying to pass a camel through the eye of a needle.
So to preven inkjet ink from clogging print something every 10 days if you dont have anything to print, use something like these test prints
PRINT TEST SHEETS FOR USE WITHMagic Inkjet Flush
http://magicinkjetflush.com/Ebay/Print_Test_Black.jpg
http://magicinkjetflush.com/Ebay/Print_Test_Color.jpg
http://magicinkjetflush.com/Ebay/Print_Test_Cyan.jpg
http://magicinkjetflush.com/Ebay/Print_Test_Yellow.jpg
http://magicinkjetflush.com/Ebay/Print_Test_Magenta.jpg
http://magicinkjetflush.com/Ebay/Print_Test_Grey_Tones.jpg
Good Luck!
Hope this helps you!
Tinteiros (Ebay)
Oct 28, 2009 | Dell 810 All-In-One InkJet Printer
New ink cartrage
Print Nozzle Check Pattern
  1. Press the Open button to open the output tray.
  2. Load letter-sized plain paper in the auto sheet feeder (ASF) or the cassette.
  3. Display the Maintenance screen on the printer.
  4. Press the up or down cursor to select [Nozzle check], then press the <OK>.
  5. Press the up or down cursor to select [Yes], then press <OK>. (The nozzle check pattern is printed.)
  6. Confirm the nozzle check pattern.
05sj00160_03a.gif 05sj00160_03b.gif < 1 > The normal nozzle check pattern
< 2 > The abnormal nozzle check pattern
< 3 > Some black ink lines are broken.
< 4 > White lines are present in the color ink pattern.
< 5 > Both black and color inks are not present.
Note:
  1. When all patterns are printed normally, press the up / down cursor button to select "All A" and press the OK button.
  2. When any patterns are printed abnormally, press the up / down cursor button to select "Also B" and press the OK button.
Print Head Cleaning:
  1. Display the Maintenance screen on the printer.
  2. Press the up or down cursor to select [Cleaning], then press <OK>.
  3. Press the up or down cursor to select [Yes], then press <OK> to start print head cleaning.
    Note:
    Do not do any other operations until print head cleaning is completed.
  4. Print the nozzle check pattern and check the print head status.
Deep (Print Head) cleaning:
  1. Display the Maintenance screen.
  2. Press the up or down cursor to select [Deep cleaning], then press <OK>.
  3. Press the up or down cursor to select [Yes], then press <OK> to start print head deep cleaning.
    Note:
    Do not do any other operations until print head deep cleaning is completed.
    Note:
    Ifthe printed result does not improve even after doing print head deepcleaning, turn off the printer. Then, after 24 hours or later, do printhead deep cleaning again. (After a given time interval, ink coulddissolve itself, resulting in ink unclogging.
Jan 08, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Black ink
It's been my experience when an inkjet printer produces unfavorable printing results ("scan lines or no color) the most common cause is clogged print nozzles. The most common cause of clogged print nozzles is lack of use and the ink dries and hardens in the nozzles.
Your particular model of Lexmark as well as other brands generally have a utility to assist in unclogging the jets by forcing ink through the nozzles. This does "waste" ink, but it is the "easiest" way to attempt in unclogging the nozzles.
For your model try the following: (This is an excerpt from the Lexmark site.)
  1. Load paper.
  2. Click Start onestep.gif Programs onestep.gif Lexmark 4200 Series onestep.gif Lexmark Solution Center.
  3. From the Maintenance tab, click Clean to fix horizontal streaks.
  4. Click Print. A nozzle page prints, forcing ink through the clogged nozzles to clean them.
  5. Print your document again to verify that your print quality has improved.
  6. If you are not satisfied with the print quality, continue with step 7 and then print your document again.
  7. Wipe the print cartridge nozzles and contacts:
  1. Remove the print cartridges.
  2. Dampen a clean, lint-free cloth with water.
  3. Gently hold the cloth against the nozzles for about three seconds, and then wipe in the direction shown. acrtclnn.jpg
  4. Using another clean section of the cloth, gently hold the cloth against the contacts for about three seconds, and then wipe in the direction shown. acartclnc.jpg
  5. With another clean section of the cloth, repeat steps c through d.
  6. Let the nozzles and contacts dry completely.
  7. Reinsert the print cartridges.
  8. Print your document again.
  9. If the print quality does not improve, repeat step 7 up to two more times.
  10. If print quality is still not satisfactory, replace the print cartridges.
Nov 28, 2007 | Lexmark X4270 All-In-One InkJet Printer
Canon PIXMA iP90 Mobile Printer Logo
111 people viewed this question
old marine
old marine
