Question about KitchenAid Superba Architect KSCS25IN Side by Side Refrigerator
How to remove rust looking stains on outer doors
How to remove rust looking stains on outer doors of refrig mold? Thank you
HB
    Scholar:
  • 145 Answers
Use DeBruce Polish, we use DeBruce Polish on all of our stainless steel. DeBruce Polish also works on glass cook tops. We get DeBruce Polish at debrucepolish.com.
Posted on Apr 29, 2010
Painting the outer edges of the interior of a refrigerator..where the door seals meet the interior
Most likely not rust. You would see rust stains. IF you do repaint it, make sure that it is clean and dry. Oil or contaminates can cause the problem that you are describing.
Feb 15, 2015 | Refrigerators
Is ge doing anything about mold issue in their refrigerator model zir36nmarh
It is very easy to prevent and/or remove mold once formed.
Mold usually forms around the freezer doors an the door gasket. This usually happens in a humid climet when the "Energy Savings" mode is on. That causes sweating on the door frame followed by mold and black residu.
PREVENT MOLD BY TURNING THE ENERGY SAVINGS OPTION OFF!
You can usually turn it on during the winter, when home heating is running and humidity is low.
Remove mold from door gasket by applying any spray cleaner that contain Bleach or just use towel with bleach. For very dark stains, allow the bleach to stay for about one hour, it will remove most stains
After cleanup, using you finger, redress the door gaskets with a very light coat of common Petrroium Vaseline. This will leave the door gasket soft and protected for a long time.
Jun 02, 2014 | GE Refrigerators
Mildew in washer
Hi Meredith, this is AP!
I understand you are struggling with mold spreading in your Frigidaire dishwasher, model PLD2560LCC. The average useful life of a dishwasher is about 13 years, so I would attempt to get a few more years from the dishwasher if you can. Chlorine bleach kills mold and helps remove most mildew stains. Dilute 1 cup of bleach in a gallon of water and scrub the interior of the machine with a stiff brush. Use a toothbrush to get in narrow areas, such as around door gaskets. Wear gloves to protect your hands when you use bleach, and also avoid mixing bleach with any other cleaning product. Run the dishwasher empty after cleaning it to rinse out the bleach residue. If stains remain after mold removal, scrub them away gently with a damp rag and mild scouring powder.
Or you could run a cycle with no dishes. Once the dishwasher has completed its initial fill, add 1 cup of white vinegar and complete the cycle. If you find that removes the mold I would open the dishwasher door after each use and allow it to dry out completely before closing it to prevent mold growth. Moisture, bits of food and a warm environment can lead to unwanted mold growth. If you won't be using the dishwasher for a while, such as when leaving for vacation, leave the door open while you are gone to ensure no trapped moisture leads to a mold or mildew problem.
I hope this information proves helpful to you, thank you for the post.
Thanks,
Mar 29, 2014 | Frigidaire 24 in. PLD2560LCC Energy...
How do I get the mold off the rubber piece on the door can I use terpintine?
Turpitine may damage the seal.Vinegar should safely and effictivly clean mold
Aug 12, 2011 | Frigidaire Washing Machines
I have rust spots/stains in my bathroom door frame which is alongside my showerwater appears to be getting into the door frame (aluminium not wood) and staining the paint its rust spots so i know its...
aluminium does not rust so the stain will not be rust stains
could be leaking fitting at the plumbing pipes at the taps
could be that the washer under the tap insert is leaking especially if not replaced when doing the spindle seals
May 03, 2017 | Washing Machines
How to remove rust stains from driveway.
http://living.aol.com/gmc-trade-secrets/eric-stromer/how-to-fix-driveway-stains-step-by-step
Jul 08, 2009 | Electronics - Others
Rusting of the door on a stainless steel refrigerator
True stainless steel will not rust, but it can get rust stained, which could be removed. Without any further info about your situation, I'd have to guess that you have a high iron content in your water supply, and thus rust issues with your sinks, etc., unless you have a good iron reducing softener and the water to the refrig is not running through that softener. Again, without further info, I'm guessing the rust issue is at or below the water dispenser area. Keeping the water from spilling over the drip tray will help. You might try Wink rust remover, but do test it on an inconspicuous area first to make sure it will not adversely affect the finish in a visible area.
Dec 07, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Repainting doors on whirlpool white refrigerator
oowwwww!!! thats what we call in the refrig biz "refrig cancer" the door itself is actually rusting from the inside out. the older refrigs used fiberglass insulation inside the doors which has a tendency to hold moisture, and overthe years rusts through. the new door use blown-in poly styrene foam far less likey to hold moisture. That being said you could remove the door lightly sand and paint, can of krylon enamal aint should do it, at least for a little while anyway
Nov 30, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
KitchenAid Superba Architect KSCS25IN Side by Side Refrigerator Logo
303 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
