Toshiba 19dv665db no sound through the speakers and i get sound through the earphone but it sounds funny.
This is a software issue and can be cured via software being loaded onto a usb stick.
If you take a look on Ebay and find seller ANDY2.1 he is selling the software.
It cured my tv and is still going strong now 1 year later so does work.
Posted on Dec 01, 2011
Why no sound from my laptop audio jack
make sure the driver is correctly installed
Apr 30, 2014 | Toshiba Satellite Computers & Internet
Toshiba a665-s6086 with harman/kardon speakers has static sound
That could be a RAM or processing issue.
In the first instance, check the driver for the latest, (toshiba.com) and run a registry cleaner to help speed the system up.
Jan 20, 2014 | Toshiba Satellite L455D-S5976 Notebook
I have a 1993 Toshiba 32 inch tv. suddenly there is no sound. The mute is NOT turned on. What might be the problem?
Hi kohn,
Plug your headset to the earphone jack (if installed) of the TV.
If you can hear the sound there, the fault may due to open(defective) internal speakers or the earphone jack itself. Faulty internal speaker may replaced with new sets to back your sound to normal again. If the earphone jack was faulty, you may spray it first with electrical contact cleanerwhile inserting and pulling the headset plug into it for one minute to clean the contact. If nothing happens, this jack need to replaced with new one.
If you can't hear the sound after inserting your headset, this is an indication that the audio circuitry was gone bad. The most common caused of this trouble was the faulty sound IC(mounted in heatsink). This is the one converts the audio signal to sound and feed to your speaker's. I would advice you to look for a qualified technician to check this parts.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Jdvillanueva
Jul 13, 2011 | Toshiba Televison & Video
No SOUND
If it has an earphone jack try to hook up your headset just to get hint if your problem is in the sound output ic. Listen carefully to your headset if there is a sound or none. If you hear a sound then you the trouble is in between the earphone jack or to your speaker. Just test the speaker and you will isolate the problem. How to test the speaker if good, simple got a battery (either AAA,AA,C,D size) then tap the speaker across the battery when you hear a crackling sound then it is good. If you confirm that the speaker is good then the faulty parts is your earphone jack, replacing it will cure the problem. If you don't hear a sound then through your earphone then the trouble is in the output I.C. or some parts around it and you need a technician to isolate the problem.
If you don't have an earphone jack then I've advice you to look for a qualified technician to look for a defective parts on the sound section.
Thanks for using fixya...
Jan 07, 2011 | Televison & Video
No sound
Hello
If picture is OK and there is no sound output from your tv, means either its speaker or the Sound output Ic is not working. The case of speaker fault can be easly detected without opening the TV. You just place your ear very near to the speaker side and switch on the TV by AC mains [not with remote control]. You may hear a "thumb" SOUND OR A "HUM" sound from it. If any one is there the internal speaker is working fine. The fault lies in audio output Ic stage. If there is no sound said above, speaker can be suspected. Befor confirming that the speaker is faulty, if your TV has an earphone or headphone jack in front, insert the earphone or headphone socket into it, and check whether there is any sound heard from it. If there is sound from headphone, means that the headphone socket is faulty, it does not bypass the sound to the speaker. When head phone is connected, the connection to the speaker will automatically cut of. When it is pulled out from the socket, the speaker connection will resume. If the changeover switch inside the earphone socket also show this kind of trouble. If the speaker inside is found faulty, unscrew it out of place after opening the TV, go for a same type and number, impedence and shape.
If there comes the above said "HUM" sound from the speaker, surely the Sound Output Ic is faulty. Replacing it will solve the probelm. Before replacing it, check it soldering points for any loose contact. It is best to resolder all suspected point is sound section before replacing the ic.
Note: In modern TVs there will be any trace of sound, without a video signal. Without video, sound is muted. ok.
Nov 07, 2010 | Toshiba CF19H25 TV
No sound from speakers and static from earphones
First, let's deal with the speaker problem. Download the latest device driver software for your notebook's built-in audio from csd.toshiba.com, install the software, and make sure the "mute" icon does not appear in place of the volume control.
As for the headphone issue, make sure your volume is set properly and the cord on the headphones is in good condition. Again, update your laptop's device driver software, and if that doesn't take care of the issue, call Toshiba and they can help you.
May 04, 2009 | Toshiba Satellite A215-S5822 Laptop
When ever I look at a video on my laptop I can hear the sound good but when i plug my earphones up it sounds funny u can hear them talk but it sounds funny i upgraded my sound still no change my earphones...
Hi, It seems the sound card might be defective, if you tested with some known good earphones in the computer, and you still have the same sound quality, then it might need to be replaced, HP should have diagnostics software within the computer, if you're able to access it to diagnose the ocmputer please do so, otherwise if your warranty is still valid with HP you should be able to contact them for a replacement or troubleshooting.
May 04, 2009 | HP Pavilion dv9000z Notebook
Headphone problem
GO INTO CONTROL PANAL GO TO SOUND OPEN FOLDER GO TO SOUND TAB AND FIND WHAT ITEM YOU ARE HAVINGISSUES WITH HIGHLIGHT IT AND TEST IT TO.
DEVICE MANAGER IN CONTROL PANAL, CHECK THE DEVICE AND IT DRIVER AND ANY NEW UPDATES
Feb 12, 2009 | Toshiba Satellite Pro L300 Notebook
I have no sound on my HP Pavillion laptop
I had the same problem, but now its solved!
Brieftly speaking, my internal speaker stopped producing sound, but when I plug earphones in, there is sound in the earphones.
Just plug in-and-out ur earphones several times (it took me 5 tries) and voila internal speakers work again!
I think there is a mechanical sensor inside the sound output (plug for the earphone) so that once it senses a plug getting in, it shuts internal speaker.
Maybe the mechanical sensor was jammed (spring problem i guess) and it still believe that u have ur earphones plugged-in. "Clogging" the hole for the earphones would allow the spring to spring back to initial position...
Hope it helps
Jan 13, 2009 | HP Pavilion dv9000z Notebook
Open Questions:
samsung pn64f8500 boot loop with evoulution kit 3000za installed I had perfectly working Samsung plasma ph64f8500 working fine with Samsung evolution kit 3000 ZA installed. Then we moved I took off the evolution kits so the movers would not knock them off. I powered up without the evolution kit installed accidently. Now both plasma are stuck in boot loop. They power up but go to the smart tv logo and cannot find the evolution kit. I read somewhere a long time ago that I needed to reset the evolution kit to a state where it had not been installed. The current issue is the Main Logic Board eeprom instructs the unit to boot correctly but it cannot find the evolution kit. If you boot without the evolution kit the system halts and indicates on the screen the evolution kit has been uninstalled and you must install it if you wish to view. If it could find the evolution kit one could go thru the menu to uninstall it correctly. One option is to manually reset the eeprom to remove the install instruction that boots looking for the evolution kit. I have been looking for the eeprom on the Samsung main logic board but I cannot download the logic board schematic. I cannot find the logic board number. The main logic board is BN94-0625C. The logic board has tow other part number references.• MFR Part Number 1: Samsung BN94-06205C • Board Number(s): BN41-01998A, BN97-06633G i have been researching the logic board IC Numbers and belive that IC 1701 is the eeprom that requires reset. The youtube videos for similar models indicate a eeprom that is listed as a part nmber for this samsung pn64f8500 unit as 24C512 and shows how to jumber 2 IC locations that will force the eeprom to reset to standard starup without the Evoution Kit 3000
Jul 16, 2018 | Samsung Televison & Video
Televison & Video Logo
413 people viewed this question
Top Televison & Video Experts
