Question about Canon DR-5010C Scanner
Canon DR-5010C when settings are changed to Auto Detection for page size gets an error message stating that "Scanning parameters are incorrect." I want to be able to scan stacks of paper of various sizes. For example, the first page may be a legal sized document and the second page a letter sized. Please advise.
  • 490 Answers
If you are using CapturePerfect 3, select page size as Auto-detection, detect size by Image width, Deskew by roller & Image, then you will get images exactly as that of the scanned image.
If you ae using CP2, then you can select Auto-detection AND page detection. The problem with CP2 is if the image is less than that of the guide-plate, you will get black background. You can clean this through software.
If you had select B&W scanning and chosen to save file in JPG format, the scanner will report error. JPG is only for Color/ Grey scale.
With CP2, I have observed that sometimes, the changes are not retained, unless you select 'default' first and alter the parameters. This is not found in CP3.
S. Mohan, Chennai, India.
Posted on Nov 19, 2010
  • David C. May 09, 2013
    Hi Mohan, I don't have a selection for detect size by image width, where is this setting ?
Canon DR-5010C Scanner How to get rid of the 4 zero's at the end of the naming convention?
The 4 zeroes at the end are added on purpose. If you are scanning a set of documents, say 11 pages, to maintain the sequence the scanner scans them as abcd0001, abcd0002 till abcd 0011. Without 4 zeroes, the first file will be abcd1, abcd2....abcd10, abcd11. Now in the Computer the sequence will be abcd1, abcd10, abcd11, abcd2 till abcd9, altering the sequence. If you are scanning into PDF, the scanned images will be added automatically maintaining sequence.
S. Mohan, India
Jan 09, 2013 | Canon DR-5010C Scanner
5010C scanner won't skip blank pages
We had this problem and discovered it was caused by a small piece on the glass. Once the glass was cleaned, the blank pages were skipped.
Sep 11, 2012 | Canon DR-5010C Scanner
AUto Detection bad parameter issue with Canon DR-5010C
If this is a hardware issue, the unit will have to be serviced. If it's a software problem, you could try uninstalling the CD, then reinstalling it to see if it clears up this issue.
Couldn't find anyone reporting this problem on the net, but perhaps Canon might have a heads up on it. Contact them at their support site:
http://usa.canon.com/cusa/about_canon/standard_display/contact_us
Good luck, and hope this helps.
Nov 18, 2010 | Canon DR-5010C Scanner
Auto detection can not be set as default
A 'Driver' is only the software portion to connect two hardwares. You need to install a printer driver for Printer, or a DVD driver for a DVD drive. Similarly, the scanner driver just connects the scanner to the computer.
You need to use a Scanning software to use the scanner. Canon offers CapturePerfect 3, using which you scan documents, do rotation, convert to PDF etc. CP3 has option to detect the page size. CP2 is available free of cost from Canon sites. CP3 comes with the scanner.
Apr 01, 2010 | Canon DR-5010C Scanner
Canon DR-5010C just black scans
I would completely uninstall the software, unhook the hardware, reinstall software toy around with the program a bit at this point. If the software states it WILL scan in color, I would go to Manufacturers site and download the latest version of the software.
Sep 22, 2009 | Office Equipment & Supplies
Parts of page being scanned are cut off
Whcih version of CapturePerfect you are using?
I use ver 2.0. In the settings page select scanners maximum. In the 'advanced' select auto detection. Then whatever size of the paper guides you choose, that will will be the width and ofcourse the length is automatic. There is a sensor under the paper guide, and it detects the paper width. Any rotation chosen will be after scanning the required size.
Jul 20, 2009 | Canon DR-5010C Scanner
Dr 5010c feeds one to five sheets, then stops
Clean the rubber rollers (pickup and ******) with a damp cloth, loosen the papers to be scanned. Clean all the rollers in the scanning path. What is the eror that is displayed? Download the user manual from this site http://www.usa.canon.com/opd/controller?act=OPDSoftwareAct&fcategoryid=2341&modelid=11293 (5010um.pdf). Change the rollers if they are old.
Apr 16, 2009 | Canon DR-5010C Scanner
Scanner Canon 5010c
This is a known problem with the scanner. Use PixEdit to scan which comes around this problem so the scanning terminates OK after the ADF goes empty.
Dec 22, 2008 | Canon DR-5010C Path-Through Scanner
Error while scanning
Techlove -
Was there any resolution to this problem?
Mar 28, 2008 | Canon DR-5010C Path-Through Scanner
Canon Dr-5010C Scanner to Pc problems.
Are other formats, like JPG, working okay? Unselect multiple pages so that you get on image per sheet. Reinstall scanning software after a 'scandisk' command.
S. Mohan
Mar 04, 2007 | Canon DR-5010C Path-Through Scanner
Canon DR-5010C Scanner Logo
3,319 people viewed this question
old marine
old marine
