Question about Leviton 003-1755-W Three Rocker Switches
Both 3-way switches don't work
If I turn the light off at switch 1 of the 3-way switches 2 will not operate the light. In this condition I also can only ready about 75 volt accross one of the wire paired choiecs
  • gtro887 Apr 29, 2010
    My son moved into and older home and one of the rooms with 2, 3 way switch wasn't working. Since my request I looked at the wiring in a different room with 2, 3 way switchs and the wiring appears to be the same and in that room both switchs work. So I decided that being the home is 25 years old the first course of action should be to replace the switchs. So I will see if that fixes the problem.
  • Al Kupchella
    Al Kupchella May 11, 2010
    Provide some more details and I may be able to help you. How many switches, 2 or 3? Exactly how are each of them wired? How many terminals (other than the ground) are available on each switch?
    I assume if the problem started with an existing setup that used to work, you would have already gone down the road of replacing the switches, or maybe this is a new installation for decorative reasons--- either way this must be a new installation and it's probably not wired correctly - but I'm guessing here. The 75 volt reading is most likely a red herring. Volt meters are very sensitive to voltage potential, regardless of the available current. If you can hook those leads with 75 volts to an incandescent light bulb, and it lights up (a bit dimly) - then you have a problem, but it probably won't light up at all.
    Good luck, I'll respond to more info if I can.
    Al Kupchella
    Guru:
  • 351 Answers
In a situation like this , If the switches are new, then the wiring has gotten messed up. If they are old installation, then it sounds like a loose or broken wire in one of the switch boxes. check the sketches for correct wiring, making sure that the travellers between the switches are on the brass colored screws .. and check all wire nut connections and scrwew connections to be sure that all wwires are secure in their connections.
Posted on May 04, 2010
My lights will not shut off on my pontiac grand prix 03
Headlamp Low or High Beams Always On
Was the Lighting System Diagnostic System check performed?
Go to Step 2
Go to Diagnostic System Check - Lighting Systems
  1. Turn the ignition switch to the OFF position.
  2. Turn the headlamp switch to the OFF position.
Are any of the headlamps on?
Go to Step 3
Go to Testing for Intermittent Conditions and Poor Connections in Wiring Systems
Disconnect the headlamp switch.
Are the headlamps on?
Go to Step 4
Go to Step 8
Disconnect the multifunction turn signal switch.
Go to Step 6
Go to Step 5
5
Test for a short to battery positive voltage in the headlamp switch signal circuit. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Did you find and correct the condition?
YES Go to Step 10
NO Go to Step 7
6
Test for a short to battery positive voltage in the headlamp supply voltage circuit. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
YES Go to Step 10
NO Go to Step 9
7
Replace the multifunction turn signal switch. Refer to Turn Signal Multifunction Switch Replacement in Steering Wheel and Column.
Did you complete the replacement?
YES Go to Step 10
8
Replace the headlamp switch. Refer to Headlamp Switch Replacement .
Go to Step 10
9
Replace the underhood fuse block. Refer to Underhood Electrical Center or Junction Block Replacement in Wiring Systems.
Go to Step 10
10
Operate the system in order to verify the repair.
Did you correct the condition?
System OK
Go to Step 2
Jun 21, 2016 | Pontiac Cars & Trucks
2006 buick allure , automatic low beams do not come on when key starts car
Headlamps
You can use the headlamps two different ways.
Place the headlamp switch in the HEAD position for normal operations
Place the headlamp switch in the OFF position for automatic lamp control (ALC) operation. During ALC the low beam headlamps are ON for daytime running lamp (DRL) operation in daylight conditions at reduced intensity or low beam headlamps ON at full intensity with exterior park lamps ON in low light conditions. The ambient light sensor is a light-sensitive transistor that varies its voltage signal to the body control module (BCM) in response to changes in the outside (ambient) light level. When the BCM receives this signal the BCM turns ON just the low beam headlamps at reduced intensity for the daytime running lamp (DRL) operation. A resistor wire is used (CKT312) to reduced the voltage which reduces the light intensity for the DRL's function. The ambient light sensor can also turn ON the low beam headlamps and the exterior lamps for automatic lamp control (ALC). Any function or condition that turns ON the headlamps will cancel the DRL operation (this means no reduced voltage to the low beam lights). Thirty seconds after you start the engine with the headlamp switch in the OFF position, the DRL will perform one of two actions:
Illuminate the low beam headlamps at reduced intensity in daylight conditions
Illuminate the low beam headlamps and exterior park lamps for low light conditions
The DRL operates when the ignition switch is in the RUN position, the parking brake is not set and the transmission is not in the PARK position When these conditions are met and the DRL ambient light sensor indicates daylight conditions the DRL will illuminate
Should have BCM scanned for DTC'S - diagnostic trouble codes , could have DTC'S stored in memory !
DTC B2645 Ambient Light Circuit
The body control module (BCM) monitors the ambient light sensor signal circuit in order to determine if the daytime running lights (DRL) or the auto headlights (ALC) should be turned ON in the AUTO mode. When the BCM senses the ambient light sensor voltage is between 1.75-4.9 volts, either the DRL will be commanded ON or the ALC will be commanded ON.
  1. Turn ON the headlamps.
  2. Ensure that the headlamp dimmer switch is in the LOW position.
Do both low beam headlamps illuminate?
Is only one low beam headlamp inoperative? YES / NO
IF no
  1. Disconnect the lamps switch assembly.
  2. Install a jumper between the headlamp switch headlamps ON signal circuit and ground.
Do the low beam headlamps illuminate?
Go to Step 18
Go to Step 7
7
  1. Remove the headlamp module.
  2. Install a fused jumper between battery positive voltage and the switched low beam voltage supply circuit.
Go to Step 8
Go to Step 11
8
Test for the following in the headlamp module control circuit:
An open
A poor connection
A short to ground
Refer to Circuit Testing and Wiring Repairs .
Go to Step 19
Go to Step 10
9
Inspect for a poor connection at the harness connector of the lamp switch assembly. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs .
Go to Step 19
Go to Step 14
10
Inspect for a poor connection at the headlamp module. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs .
Go to Step 19
Go to Step 15
11
Test for a short to ground in the low beam voltage supply circuit. Refer to Circuit Testing and Wiring Repairs .
Go to Step 19
Go to Step 12
12
Inspect for a poor connection at the harness connector of the underhood fuse block. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs .
Go to Step 19
Go to Step 17
13
Inspect the inoperative low beam headlamp voltage supply and ground circuit for a high resistance, a short to ground, or an open. Refer to Circuit Testing and Wiring Repairs .
Go to Step 19
Go to Step 16
14
Replace the lamp switch assembly. Refer to Headlamp Switch Replacement .
Go to Step 19
15
Replace the headlamp module. Refer to Relay Replacement in Wiring Systems.
Go to Step 19
16
Replace the inoperative low beam headlamp. Refer to Headlamp Assembly or Headlamp Bulb Replacement .
Go to Step 19
17
Replace the underhood fuse block. Refer to Testing for Intermittent Conditions and Poor Connections .
Go to Step 19
18
Replace the BCM. Refer to Control Module References for replacement, setup, and programming.
Go to Step 19
19
System OK
Go to Step 3
IF
Sep 30, 2015 | Buick Cars & Trucks
2001 Dodge Ram 3500: brake lights don't come on, switch has been replaced and installed to instructions, turn, four ways, parking lights and cruise control interrupt all work. Is there a brake rel
have you checked wire harness @ rear of truck ? and along frame rail, ? and condition of the rear taillight assymblies, ? corrosion could be in these areas. check all ground wires also, not sure about relay ! don' t think so ! why would brakes need one ?
Feb 02, 2013 | Dodge Ram 250 Cars & Trucks
Lights turn themselves on and off
I have seen conditions of poor / missing ground, high humidity and nearby two way radio operation (CB, Ham, Police, Taxi, etc.) cause unattended operation (on and off).
Make sure the switch surfaces are clean and dry. Try changing metal switch plates to plastic / nylon (and vice-versa) types.
Ensure that the switch is grounded. Before removing switch from box, shut power OFF. Carefully pull the switch from the box and make sure the switch's ground wire is connected to the ground conductors in the box.
Ultimately, if you are unable to solve the problem with these true touch dimmers, changing to a rotary knob / slide operated dimmer or even a standard toggle switch should work without incident.
I hope this helps and good luck!
Sep 09, 2012 | Leviton True Touch Lighting Control
Daytime running light
[Information] For a 2002 Toyota Camry, the Daytime Running Lights (DRL) operate utilizing the High Beams (inner Lamps closer to the center of the vehicle front) at a reduced power.
[The troubleshooting process:] Review the Owner's Manual and ensure the test configuration matches the following criteria:
1. According to the 2002 Toyota Camry Owner's Manual (Check your Owners Manual):
"The DRL system will make your headlights come on at a reduced brightness when:
The light switch s in the "DRL" position.
The ignition is on with the engine running.
The headlight switch is off.
The parking brake is released."
2. Set the Test Conditions according to Step 1 above.
3. Check the headlight bulbs to ensure they are not burned out. If one burns out, there is a fair chance that the other would have burned out at the same time. Replace as necessary. In this case, if the high beams operate, the DRLs should also operate.
4. Test the system, ensuring the step 1 conditions are set. (Engine running, Multi-function Switch on Turn Signals in "DRL" position, headlight switch off (repeating what the manual says -- it should be obvious that in the "DRL" position, the headlight switch should be off / do not have the switch positioned to "High Beam"), and the Parking Brake "off").
5. If DRL lights do not work, check the engine compartment Fuse and Relay Box. there is a 5 Amp DRL fuse -- replace it with the spare. Test (step 4).
6. If it does not work, swap around or replace relays -- there are three (3). Any one of them could be bad (stuck or burned out). Test (step 4).
7. Other less likely possible issues could be that the Multi-function Switch is broken or a connection / wire is broken. [Beyond the scope of this process.]
My problem was that the test configuration did not have the engine running and parking brake off - Step 1. Problem solved with much thought, repetitive tests on the vehicle and going back to the basics -- what does the Owner's Manual say and where are the applicable fuses and relays located?
Dec 30, 2011 | 2002 Toyota Camry
Brake lights won't work.... replaced fuse it's fine, top light on hatch works, but right and left don't
need to check the multi-function switch. the brake light signal goes through the turn signal switch on the steering column. the brake lights come on if the turn signal is not being operated. the circuit for the brake light can loose contact in the switch.
Aug 12, 2011 | 2007 Chevrolet Tahoe
What does FH mean on a kenmore front load washer and where can i get a manual
F/H:
Condition
No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Check/Repair:
Press PAUSE/CANCEL twice to clear the display.
  • If there is no water in the unit:
  • 1. Make sure that both valves at the water source(s) are turned on all the way.
    2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
    3. Verify inlet valve operation
  • If there is water in the unit:
    1. Verify Drain pump operation
    2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
  • Verify there is not a siphon problem
  • Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
  • Check all hoses for possible leaks
  • Verify pressure switch operation
  • Verify flow meter operation
  • Verify CCU operation
If this is intermittent, it would be very hard to determine the cause.
I myself have rarely run into this issue, and when I did, it was mainly caused by low water pressure into the water from the customers water supply, or clogged inlet water valve screens.
Make sure you don't have any duct tape or something around your drain pipe, it needs that air gap to prevent siphoning.
Jul 20, 2011 | Kenmore Front Load Washer
2003 nissan altima rpm goes crazy (at 2 then drops to 0, back and forth)then it dies. it is doing it more frequently
I have also read in the service manual that doing an idle relearn helps with RPM problems. This is the procedure below. It is complicated to do unless you have a watch or something to count the seconds with.
DESCRIPTION
“Accelerator Pedal Released Position Learning” is an operation to learn the fully released position of the accelerator
pedal by monitoring the accelerator pedal position sensor output signal. It must be performed each time
harness connector of accelerator pedal position sensor or ECM is disconnected.
OPERATION PROCEDURE
1. Make sure that accelerator pedal is fully released.
2. Turn ignition switch “ON” and wait at least 2 seconds.
3. Turn ignition switch “OFF” wait at least 10 seconds.
4. Turn ignition switch “ON” and wait at least 2 seconds.
5. Turn ignition switch “OFF” wait at least 10 seconds.
Throttle Valve Closed Position Learning UBS002OA
DESCRIPTION
“Throttle Valve Closed Position Learning” is an operation to learn the fully closed position of the throttle valve
by monitoring the throttle position sensor output signal. It must be performed each time harness connector of
electric throttle control actuator or ECM is disconnected.
OPERATION PROCEDURE
2. Turn ignition switch “ON”.
Make sure that throttle valve moves during above 10 seconds by confirming the operating sound.
Idle Air Volume Learning UBS002OB
DESCRIPTION
“Idle Air Volume Learning” is an operation to learn the idle air volume that keeps each engine within the specific
range. It must be performed under any of the following conditions:
 Each time electric throttle control actuator or ECM is replaced.
 Idle speed or ignition timing is out of specification.
PREPARATION
Before performing “Idle Air Volume Learning”, make sure that all of the following conditions are satisfied.
Learning will be cancelled if any of the following conditions are missed for even a moment.
 Battery voltage: More than 12.9V (At idle)
 Engine coolant temperature: 70 - 95ーC (158 - 203ーF)
 PNP switch: ON
 Electric load switch: OFF
(Air conditioner, headlamp, rear window defogger)
On vehicles equipped with daytime light systems, set lighting switch to the 1st position to light
only small lamps.
 Steering wheel: Neutral (Straight-ahead position)
 Vehicle speed: Stopped
Apr 29, 2009 | 2003 Nissan Altima
Headlights don`t work
Sounds like a bum relay in the main underhood fuse box. My complete illustrated tutorial for repairing this $80.00 part is here: http://www.customsaab.com/Custom_Saab_NG900_OG9-3_Performance_Articles/p2_articleid/24
Nov 05, 2008 | 1996 Saab 900
Leviton 003-1755-W Three Rocker Switches Logo
153 people viewed this question
Top Leviton Electrical Supplies Experts
 Kenneth
Kenneth
Steve
Hippy_dd
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
