Question about InFocus ScreenPlay 61" Rear Projection HDTV
Where can I buy a replacment bulb for TV
Replacement Bulb needed.... Do I need to buy the entire assembly or just the bulb? Most resonable priced please ;-)
    Genius:
  • 1,153 Answers
Vancebaldwin.com
Posted on Mar 24, 2008
SOURCE:
Headlight for 2004 trail blazer
If it's just a bulb replacement open the hood and with one hand push in on the headlight, with the other hand inside, pull up on the white plastic retaining clip. This will release the bulb. Pull it out forward, then replace with new bulb (be careful not to touch the new bulb, oil from the hands can cause bulb to burst.)
If you need to replace the whole headlight assembly I would try buying used for a better price.
Sep 16, 2013 | 2005 Pontiac Aztek
How do i change the bulb?
Unlike conventional incandescent flashlights, where the bulb unscrews or pops out of the reflector assembly for replacement, the Pelican Sabrelite bulb is permanently mounted in the larger assembly. The entire "lamp module" is replaced as a single unit.
Replacement lamp modules can be found on the Internet and at some outdoors stores. For example, Amazon.com sells these, both individually and in 2-packs. Prices vary depending on the website, but just now, I saw them in several places for under $9/each.
Jun 06, 2011 | VWR Super SabreLite Submersible Flashlight...
Should i change my buld myself or do i need to hire a pro. Also, I seem to have misplaced my manual for this TV. Can you tell me a source to get a replacement, other than the sony website. my computer...
Go to website Youtube.com type in tv make model number and projection bulb replacement.Watch somebody video demo changing the tv projection bulb replacement.U think,u can u do it.Tries websites like Partstore.com,Ebay.com to buy a new tv projection bulb.Replaced it ur self.
Oct 29, 2010 | Sony KDS-60A3000 60" HDTV
IF I NEED TO BUY BULBS -WHERE CAN I GO BUY CHEAP- IAM DISABLED VETERAN - I LIVE ON SMALL INCOME -THIS MY ONLY TV -HOPE YOU CAN HELP
Is your bulb still good? You can extend its life by making sure the vent slots on the front and back of the set are cleaned out regularly. Vents plugged with dust will not allow adequate cooling airflow over the bulb.
On-line bulb prices range from $30 for cheap Chinese generic bare bulb replacements (quality unknown) to $150 or more for brand-name lamps already assembled into a housing. If you go with the bare bulb, you need to be able to assemble the bulb into the housing (tools required) while wearing vinyl gloves. Touching a bare bulb with bare fingers will ruin the bulb. Skin oil will react with the quartz when it gets hot and cause discoloration and possibly chemical breakdown leading to a bulb explosion.
Oct 13, 2010 | Sony KP-51WS510 51" Rear Projection...
The power will not turn on and the power LED is flashing red.
PT-50LD54 is an LCD rear projection TV with a consumable bulb that wears out normally after 2-5 years of use.
Most likely you need a bulb. That is first step in any troubleshooting for that tv. Check out Panasonic Gallery to identify lamp and replacement bulb.
Changing bulb involves removing the lamp assembly and replacing the bulb in the lamp assembly. Like doing a puzzle. Requires philips screwdriver, pliers and patience. Don't have jam on your fingers when you do it.
easyab
Apr 22, 2010 | Panasonic PT-50DL54 50" Rear Projection...
2004 malibu maxx third brake light
It is an LED lamp and the entire terminal needs to be replaced. I would suggest checking the fuse first, being that the replacement can run over $60
Aug 08, 2009 | 2007 Chevrolet Malibu Maxx LTZ Hatchback
Lamp(lite bulb) is dead - need to buy replacement and install it
Click here to find the lamp for your TV. You will still need to use the existing cage assembly, once you remove the old lamp you will be able to see how it's assemble.
For the lamp replacement instructions, you will need to download the owner's manual and go to page 16 to 22 to know how is done.
Good Luck.
Jan 06, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
Made a pop sound then screen went black- won't power back on
I'm sure you've resolved this by now, but I am brand new to this site and have the same TV, and have had the same issue. Sorry it's a bit late.
The pop was definitely the bulb bursting. You can pretty easily do this bulb replacement yourself as Panasonic has provided a nice little pull out module that can be removed by popping the front plate off (which requires no tools at all) and then opening the hatch where the bulb assembly is and loosening just one screw. Once that is done you will be able to slide the entire bulb assembly out of the TV. Though they don't always shatter, I suspect that since you heard it "pop", you will find this assembly full of broken glass.
You can either buy an entire new assembly such as this one...
http://www.alltvlamps.com/product_p/ty-la1000.htm
and just slide the new one in,
or if you're comfortable with it, you can open this lamp assembly up by removing just a few more screws (about 4) and just replacing the bulb. I did need to buy a very long #2 Phillips head screw driver to reach one of the screws.
If you search Google for TY-LA1000 you will find both the lamp kit and just the bulb. Be careful though for the really cheap bulbs, it does make a difference, so if it seems drastically cheaper than all the others, there is likely a reason.
Hope this helps you and sorry for the slow response.
-R
Nov 23, 2008 | Panasonic PT-44LCX65 Television
PT Cruiser Brake Light
The bulb in the rear light has burned out and to replace it follow these instructions: 1) go to your owner's manual to find out the part number. You can find and purchase the replacement bulb at Target, any auto parts store and even at Walmart for under $4.00; 2) pop open the trunk door; 3) get a phillips screw driver and unscrew the 2 screws holding the rear brake light fixture to your car body; 4) as soon as you turn over the fixture you'll see where to pull out the burned out bulb and replace it with the new one(s). Good luck!
Jul 14, 2008 | 2006 Chrysler PT Cruiser
Zenith replacement bulb
I would suggest to remove the lamp from your TV and check it. You can also just buy the lamp without the other hardware.
This site seems to have good prices.
Let me know if you need any more assistance.
Mar 26, 2008 | Zenith E44W46LCD 44" Rear Projection...
InFocus ScreenPlay 61" Rear Projection HDTV Logo
98 people viewed this question
Top InFocus Televison & Video Experts
Donni Steen
rostit
Are you an InFocus Televison and Video Expert? Answer questions, earn points and help others
