Question about Magellan RoadMate 700 GPS Receiver
Need users manual for Magellan Roadmate 700 - Magellan RoadMate 700 GPS Receiver
    Brigadier General:
  • 7,191 Answers
You can download the complete instruction manual in PDF format by clicking this link.
  • You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa.
Posted on Apr 28, 2010
Testimonial: "Thanks for the info !"
DanEz007
  • 86 Answers
SOURCE: RoadMate 700 GPS is not working..
Does the initial Magellan screen appear? If it doesn't display anything and it's just blue... :( Normally means that something on the main board is your problem. Which, means your out of luck. What happened to it? It just suddenly stopped working? Let me know. R/
Posted on Sep 19, 2006
DanEz007
  • 86 Answers
SOURCE: Magellan RoadMate 700 GPS unlockmap
Steve, In this case I would replace the Hard drive. But, since you probably don't have spare HDD's lying around.. do you atleast have the Software version? Some CD that came with it hopefully. If you do, then you may be able to stay alive here. Once your system boots to the user screen.. press + and repeat key at the same time.. "secret" menu now. ONLY IF YOU HAVE SOFTWARE TO INSTALL!! Select NAND FLASH FORMAT.. The unit will shut down after formatting. start up your software installer on computer. plug usb in.. and power on unit. This fix isn't %100, but it's the best shot you have. Otherwise you've gotta send it down here to Texas (where magellan repair is) and pay for the new hard drive. OR.. you could call customer service and see what they have to say. you'll probably be transferred to overseas.. --good luck with that -Dan
Posted on Feb 10, 2007
DanEz007
  • 86 Answers
SOURCE: magellan roadmate 700 gps not working
Jossie, The cable that connects your hard drive to your main board could be loose. If it's not loose, then it's your hard drive. The only thing you can do (if it's not the cable) is send it in for a new hard drive. Unsure what the costs will be but the magellan logo screen is produced from memory on the main board while anything after that is when the hard drive takes over. -Daniel
Posted on Jun 23, 2007
  • 20 Answers
SOURCE: Magellan Roadmate 700 does not power on
Hello, Rafster! Cigarette lighter plug problems are not uncommon, and - hopefully - this is the source of your problem. Because the green LED on your plug is lit, it would suggest that the FUSE inside is okay. Still, it's worth checking! The plug is easy to open, and the fuse easy to inspect/replace. IF the fuse is okay, the cord itself or the plug end that attaches to your Roadmate could be damaged. In order to determine this, you would have to check for voltage at the output end. But, you'd need a circuit tester and a wee bit of electronics knowledge to test it. If you don't have access to a tester, then the easiest test is to simply purchase a NEW cigarette lighter cord. You can get them at most retail discount stores (BestBuy; Circuit City; WalMart; etc.); RadioShack; or directly from Magellan. They're generally less than $10.00!
Posted on Jul 24, 2007
Tigerweld
  • 22 Answers
http://www.magellangps.com/assets/manuals/magellan_roadmate_series_en.pdf
Posted on Oct 17, 2008
Is it possible to remove the previous owners name from a magellian roadmate
It sure is.You can see the easy to follow instructions on page 59 of your user manual. Here is a link for the user manual. Magellan RoadMate 700 GPS Manual.
Feb 04, 2013 | Magellan RoadMate 700 GPS Receiver
Magellan roadmate 700
In configuration, under diagnostics, simulation needs to be turned off
link to web site
user manual link
Are maps unlocked?
https://www.magellangps.com/users/keysIntl/ssl_index.asp
Dec 03, 2007 | Magellan RoadMate 700 GPS Receiver
Can the previous owners name be removed from a Magellan RoadMate
Sure. Consult page 59 of the user manual for instructions on how to do it. Here is the link for the manual. Magellan RoadMate 700 GPS Manual.
Reseting the Magellan Roadmate 360 to the factory settings
Hello there:
here is a couple of linkds that i was able to retrieve hopefully they will help you ok
best regards michael
  1. [PDF] Magellan User Manual 3519k - Adobe PDF - View as html The Magellan RoadMate 800 is a vehicle ... segments totalling 360 degrees. Starting at the Prime Meridian (which is ... 11.2 Resetting the Magellan RoadMate ...www.magellangps.com/assets/manuals/MRM_800NA_en.pdf
  2. Magellan RoadMate 360 Manuals, Support and Troubleshooting - GPS Free download of Magellan RoadMate 360 User Manual. Troubleshooting ... Resetting the Trip Computer " • Viewing a Saved Trip Report " • Deleting a Trip Report " ...www.retrevo.com/support/Magellan-360-GPS-manual/id/421ag200/t/2 - 109k - Cached
  3. Magellan_RoadMate_360_North_America_Manual Documents_and_Forms ... Magellan RoadMate 360 North America User & Instruction ManualGet access the the ... Resetting the Trip Computer. Viewing a Saved Trip Report. Deleting a Trip ...store.payloadz.com/str-asp-i.388383-n.Magellan_RoadMate_360_North_America_Manual_Othe... - 189k - Cached
Sep 18, 2009 | Magellan RoadMate 360 GPS Receiver
I don't have a copy of the Users Manual for the Magellan 1412. Need a copy.
do a google search for magellan 1412 manual.  They are available for download from the Magellan web site
Mar 09, 2009 | Magellan RoadMate 700 GPS Receiver
Lost my instructions to Magellan Roadmate 1412
Here's the User Manual for the Magellan Roadmate 1412:
http://www.magellangps.com/assets/manuals/roadmate_1412_manual_en.pdf
Fixya!
Chris (ziraffa)
ps Remember to rate this solution as Fixya!
Jan 08, 2009 | Magellan RoadMate 700 GPS Receiver
I have magellan 700 roadmate .it is not take signal.it just search and search.
I woud do a reset on the gps device....I have attached a link to the manual for the Roadmate 700....http://www.starbatteries.com/maro700vegps.html
You are going to look for this
Magellan RoadMate 700 Vehicle GPS View the product manual [Download- PDF, 1MB]
Good Luck
cbinny1
Oct 20, 2008 | Magellan GPS
go to the magellan website and all your answers are there.
Sep 13, 2008 | Magellan RoadMate 700 GPS Receiver
All navigation units are GPS Receivers - that is - they receive satellite signals. So, no there is no difference.
Apr 19, 2008 | Magellan RoadMate 700 GPS Receiver
Magellan Roadmate 700 freezes up
Try resetting user data. At user menu, press "-" zoom out and repeat button at same time. select reset user data, it will reboot automatically, then check to see if it is any better. If not, hopefully the software came with your unit and you can re-install it. Good luck and let me know if you need help with the installation. Daniel
Mar 03, 2007 | Magellan RoadMate 700 GPS Receiver
Magellan RoadMate 700 GPS Receiver Logo
360 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
