Question about HP DeskJet 845c Printer
Paper jam light flashing. see no evidence of jammed paper
  • 4,041 Answers
Hello there Yjis trick for the jams gave it a go.
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 28, 2010
  • 163 Answers
SOURCE: Lexmark E232
oh my GOD ,PLESE OPEN ITS ELECTRONIC BOARD AND REINSTALL IT PROPERLY
Posted on Sep 19, 2007
SOURCE: Brother HL-2040 Flashing Paper LED
Clean the drum cartridge
Posted on Feb 19, 2008
SOURCE: Flashing red light - no paper jam
I had this problem and couldn't figure out until I opened the front, pulled out the toner cartridge and found a paper jam.  Removed it and now I have the green light.
Posted on Nov 14, 2008
  • 214 Answers
SOURCE: Brother DCP-145C. Paper jam removed. Light keeps flashing. How can I switch it off? HELP!
There will still be some scrap of paper in the machine. Get a torch and get in there. It's the only way, unless you call tech guy
Posted on Apr 28, 2009
SOURCE: HP Officejet K550--2 lights (KY & MC)are
Open the back of your printer and remove the paper jammed on it
Posted on Oct 21, 2010
The orange light keeps flashing and it says there is a paper jam but I cleared the paper jam but the orange flashing light will not go off.
1. there is a sensor at the end of the printer which shows paper jam recovery. the sensor of your printer may be jammed. clear the jam and it will work. 2. if not, there may be a small piece of paper near the sensor of your printer. clear it.
Aug 30, 2011 | HP Deskjet 460c InkJet Printer
Paper jam
Follow your manufacturer isntructions to removing jams and to the locations of possible jams. Other than that, just look for any evidence of jams. Open doors, remove trays, remove cartridges all in an effort to see if there are any pieces of paper inside. Using a small flashlight will help detect small traceds of paper
Mar 19, 2011 | Epson Computers & Internet
Our printer says paper jam open and close door. We have checked and no paper jam is evident as well we have readjusted the paper and opened and closed the front compartment and the top scanner/printer...
This can happen when there has been an actual paper jam, and in the process of clearing the jam and removing the paper one of the optical sensors inside the paper path has been damaged, thereby giving the alarm when there is no paper in the path.
Repairing this situation requires a skilled technician and dismantling the machine. This very problem happened with my own Canon Pixma MX860, a machine I dearly loved and had only owned for six months...but the cost to repair it was as much as I paid for the printer.
I know that isn't what you wanted or hoped to hear, but I also hope it was helpful.
Jan 08, 2011 | Samsung CLX-2160N All-In-One Printer
Paper jam, message but no evidence of paper jam
did your printer experience paper jam before?
try to chect it again maybe there is small paper stuck in your printer
Mar 29, 2010 | HP Office Equipment & Supplies
Epson CX3900 printer indicates paper jam
Check the paper road and paper sensor.Probably have a piece of paper or something else in the printer.
Sep 29, 2009 | Epson Stylus CX6400 All-In-One InkJet...
Paper jam lights despite no evidence of a jam.
prior to the issue ,basically is your paper path sensor .1)firstly try to check all the sensor lever ,it must be at home position .i guess one of the paper path sensor lever activated paper present.this usually happen when removing jam paper incorrectly causes the lever sensor spring came off .2)it can also be the clutch and solonoid rotation timing issue.good luck ,pls rate me if u satisfy wih my clarification.!!!!!!!
Sep 08, 2009 | Canon PC-735 Copier
Kyocera 3900dn says paper jam in rear but no jam evident
Usually a printer doesn't lie when it indicates a paper jam, if you have checked as thoroughly as possible and no paper can be found. It is possible that the paper just isn't feeding and a printer will sometimes indicate a paper jam when paper doesn't feed. But if this isn't the case and a jam is indicated as soon as you turn the printer on, one of the plastic jam sensing actuators may be broken or hung up.
Aug 05, 2009 | Kyocera FS-3900DN Laser Printer
Paper Jam light on, but no paper jam
A piece of paper torn from copy paper is caught around registration switch, exit switch or feedshift switch.
so check theme.
Jan 18, 2009 | Sharp AL 1631 Copier
Paper jam
well part inside your product (paper handler/sensor) got damaged. must be serviced / non-user serviceable part.
Jan 22, 2008 | Epson 1000 ICS All-In-One InkJet Printer
Cannon copier pc940 paper jam
canon i960 -three flashing orange lights (paper jam error) but no paper is jammed. The print cartridge1.gif will not slide to center either-- I have tried to get the printer into service mode, but cannot get there because the orange lights never stop flashing.
Dec 06, 2007 | Cannon Canon i960 Photo Printer
HP DeskJet 845c Printer Logo
176 people viewed this question
Seeker5211
Seeker5211
