Question about Kenmore Refrigerators
I have a side by side kenmore model 25351232102. The front edge of the freezer compartment is hot. what is the cause?
  • 62 Answers
SOURCE: Kenmore Elite Bottom Freezer Mod. #795 75544401
The unit was built bt LG. It is a computer controled unit and the timer is built into the main control board on back of the unit. However, the most likely cause of the broblem is the defrost terminator located on the evap on the upper right hand corner. Also, try unpugging the unit it will reset the computer board. You will also have to defrost the unit.
Posted on Aug 30, 2008
SOURCE: samsung model # rs2630sh side by side fridge. center strip is hot
I had the same problem, and it was the condenser fan motor. I ordered mine from www.partstore.com. It was half the price of sears.
I would suggest ordering the 2 "plastic bushings" for front and back of motor. I was able to reuse mine, but for a few dollars more it's worth it.
Posted on Feb 04, 2009
jumptrout51
  • 3361 Answers
SOURCE: Kenmore elite side by side: hot divider
This is normal. There is a heater in this panel to stop condensation sweating between the doors.
Posted on Feb 23, 2009
  • 531 Answers
SOURCE: The door seal contact surface is hot to the touch.
ther so pose to be a switc if none that for hummit
Posted on Apr 05, 2009
  • 245 Answers
SOURCE: Freezer compartment ice build-up
too defrost just open the doors for a day with the unit unplugged. as far as why it is frosting up check door seals make sure they are all good and seal it up well and that should take care of it.
Posted on Jun 26, 2009
Kenmore upright freezer hot on the sides, stop freezing
Without the model number I'm not sure how to answer your question. Does your model have fans that blow warm air on the outside bottom or a front kick plate? What is your model number? Kenmore has model numbers like this example=> 123.3214567 If the fan has a restriction that causes a lack of airflow it can cause the hot Freon liquid that normally flows around the Yoder Loop inside edges of the freezer door to prevent frost buildup to become very hot because the condenser fan is defective or coils are dirty with dust restricting airflow. If the outside is hot you may have a defective condenser fan motor. That will cause the freezer to ger hot. I am here should you want my assistance....Sea Breeze
Kenmore Freezer Parts
Aug 31, 2013 | Kenmore 14.1 cu. ft. / 399 liter Upright...
Front edge of fridge cabinet gets exceedingly hot...too hot to touch!
condensor coil is clogged up, or condensor fan is not running.
Dec 04, 2012 | Refrigerators
Inside refrigerator strip between the freezer and refrigerator
The condenser fan motor at the back near the compressor is either dirty or not running at proper speeds. Clean the coils for air flow over compressor and if the fan is not running replace the fan.
Jul 05, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Just moved Kenmore s/s co;d spot. edges are now hot
This is caused by a failed condenser fan motor. Since it was recently moved, I suspect the fan blade has been blocked from spinning. Pull the fridge out and remove the cardboard cover near the floor. See the fan? Check for obstructions. If there are none and the fan is not spinning, reach in there and give it a whirl with your finger. It may spin right up, it may not.
If all else fails, you'll need to replace the fan motor. Write back with the model number and I'll get you part numbers and step you through the repair. Deal?
SG
Mar 29, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Freezer stopped freezing
It is possible that the fanmotor in the freezer compartment is faulty which would cause a freeze up and prevent the air from circulating.
Mar 05, 2009 | Kenmore 44103 Side by Side Refrigerator
Hot high side assembly and at the front door section
Replaced the GE fan motor which seems to have solved the problem.
Dec 28, 2008 | Kenmore Refrigerators
I have a Kenmore side by side fridge
check the freezer compartment at the back wall. see if there is frost build up at the back.
sounds like a fosted evaporator to me.
check also the evaporator fan in the freezer section if it is running.
if not, then there is your problem.
tnx 4 using fixya,
drcool
Nov 04, 2008 | Kenmore Refrigerators
Top freezer Freezes/ Bottom not cold
defrost problem. advance defrost timer to defrost (till it shuts off) . remove freezer panel, check voltage and amps to heater,if heater is hot, replace timer, if heater is cold and no voltage, replace defrost limit switch. defrost all ice, carefully! with hair dryer, no poking with screwdriver.
Oct 26, 2008 | Kenmore 53642 / 53644 Side by Side...
Fridge freezing
a defrost problem, is gonna cause excessive ice build up in hte frezzer lower compartment. for somereaon the hdefrost heater was not energized. most common reason is a bad defrost thermostat, clipped on one of hte evaporator coils has gone bad,
Mar 22, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
57 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
