Question about Onkyo TX-SR505 Receiver
Do all speakers need to have the same impedance? (Protect mode)
I am hooking 6 speakers up to this receiver as follows.
Front: Bose Acoutimass 3 series IV impedance between 4-8 ohms per Bose CS No set impedance
Center: Bose V10: 6 ohms
Rear: three ceiling installed speakers all 8 ohms. (1 KLH, 2 Insignia)
Onkyo manual says it can operate speakers between 6-15 ohms.
Onkyo Customer Support (if that's what you call them), told me all the speaker must have the same impedance? If they are not the receiver will go into protect mode? This does not sound right to me!
Before I send this thing back AGAIN (long boring story) can anyone help?
  • OblivionSIx Apr 06, 2011
    You should be able to find a relatively cheap universal remote control to work your receiver. I use a "Universal URC-R6" cause my Onkyo remote got smashed. Easy to program and also works my TV, Cable and DVD player.
    http://www.amazon.com/URC-R6-Learning-Re...
I have old model non HDMI AV Reciver model no TX-SR505 but I lost my remote controller.Now I am presently in India.How will get this type remote contoller
Posted on Apr 06, 2011
    I use a "Universal URC-R6" for my Onkyo as my remote got smashed. It works great and controls my receiver, TV, cable and DVD player. Much cheaper than a factory model and easy to program!
    Novelist:
  • 142 Answers
Amplifiers sometimes like to have "balanced loads" on them, and this may be the case with your unit, meaning yes, all the impedances should match.
Judging by the impedance numbers you provided, you should be all set. You really want to avoid having something like 2 ohms on the left side and 8 ohms on the right side - grossly imbalanced. I don't see any problems with what you're going to run.
Posted on Mar 24, 2008
On back panel impedance for 2 speakers is 4-16 ohms. I run a pair of 6 ohm speakers with receiver and this is find. I want to connect 4 speakers all 6 ohms impedance and need to know if this is safe for...
Stephen, it may depend on how the system is protected, but generally the protection is designed to prevent the transistors from overcurrent. This would happen if you turn the volume up too high. If your receiver is newer--say built after 2005 or so, it will likely protect itself. You can hook up your speakers and see if it works. It will likely trip the internal protection at high volume, depending on the amplitude of the music signal. My main warning would be to not run the volume high for long periods and make sure there is nothing blocking the cooling vents on the unit.
Jan 14, 2015 | Audio Players & Recorders
How to connect denon AVR 1513+Bose Acoustimass 5
Plug the speaker wire from the speakers themselves directy to the receiver or you can plug them into the acoutimass module and the module into the receiver using speaker wire.12_16_2013_3_46_09_pm.gif
Feb 19, 2013 | Denon Avr-1513 5.1 Channel 3d Pass Through...
Hi,,My onkyo tx-sv828thx problem was it shows "protect" sometimes.then after 2 to 3 second its back to normal operation. What do you think the problem?can i do it by myself? anyway,i am using...
The protect message appears when the current powering an amplifier inside the receiver goes beyond the safety limit or the amplifiers overheat. So just check the wiring and the speakers impedance with an ohmmeter - each should be above 6 ohms
If they are lower then you have a short in one of the actual drivers of the Bose 901 speaker . If the impedance is OK then the Onkyo overheats, place it in a better position to increase the airflow thru it.
Sep 04, 2011 | Onkyo TX-SV828THX Receiver
I have four Bose 161 speakers and an Acoutismass 5 bass unit (original cubes are bad and replaced with the 161s). My Onkyo receiver started turning off and going into protect mode recently. Bought new...
you're going to need a ohm meter (good electrical testers have them) and make sure ohm ratings from speakers match the ratings for your receivers. Sounds like to much resistance for receiver(s)
Jan 06, 2011 | Bose 161 Rear Speaker
Front Speaker not working
Yes, ur setting needs to be changed. On fliping the settings u will realise in one of the modes mostly the surround mode the speakers will work.
Thankyou
Appreciate a good rating from you..
Jul 31, 2009 | Bose?® Acoustimass?® 10 Series IV home...
I just hooked up my old Onkyo TX-8511 receiver to my bose speakers, which is also hooked up to a subwolfer. When I turn the volume up the system goes into protect mode. Any solutions.
Just check your speaker cabling again. Make sure that all of them are seated properly, none is touching each other or the body of receiver. Rewire if necessary..
Are you using banana plugs for connecting speaker or just directly. Some times even a little tiny wire touching the receiver could trigger the protect mode. Be careful, since protect mode is sometimes not fast enough and it could blown a few trasistors in the power circuit.
Otherwise, do your bose speakers play out load on other systems?
Mar 08, 2009 | Onkyo TX-8511 Receiver
My yamaha receiver shuts down when I turn it up.
If you have bare wire going into the receiver's output terminals, make sure a strand or two of wire is not touching the other terminal. That can short out the outputs, especially when you turn up the volume, which increases the voltage present at those terminals. That would cause the receiver to shut down as a saftey precaution.
Dec 13, 2008 | Yamaha HTR-5940 Receiver
Bose 901 speakers the wiring inside
- Bose 901 Series I and II speakers have 8 Ohm impedance each.
- A row of 3 speakers in series gives you 24 Ohm.
- 3 parallel rows gives you finally 8 Ohm.
Front with 8 speakers (view from the rear):
(1) (3) (5) (7)
(2) (4) (6) (8)
Rear speaker is number (9)
Row 1: -(1)+ -(3)+ -(7)+
Row 2: -(5)+ -(9)+ -(2)+
Row 3: -(8)+ -(6)+ -(4)+
Oct 30, 2007 | Bose 901 VI Main / Stereo Speaker
Stuck in protect mode
i believe protect mode is because you have the wrong impedence speakers, they are too low (4 ohm? 6 ohm?) it chols work with 8 ohm speakers
Aug 16, 2007 | Onkyo TX-SV454 Receiver
Onkyo TX-SR505 Receiver Logo
433 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
