posted by weh116 on Mar 24, 2008
the brush motor only works when then handle is upright. anytime i lower it at all the motor turns off. it still has the suction but the brush motor is off.
1 Other User Has The Same Problem
Comment by Guest, posted on Apr 19, 2008
I have a similar problem with the connection for the power base. I think it's in the upper plug because the upholstrey attachment clicks on but easily comes off when you try to use it. Can't seem to get any connection for the power base.
Best Solution
posted on Mar 25, 2008
The cord at the bottom of the power head neck may be bad. But so could the plug connections in the hose handle, and the cord on the wand. Check both ends of the wand and make sure that the plug ends aren't burnt, if they are replace them and maybe the plug inside the hose handle.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Kenmore 23613 Progressive PowerMate
Email this problem
Email this problem
Can you Help with these Vacuums problems?
Repair Service
Find Vacuum Repairman Near You:
Find Parts
