Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Washer will not drain
I just replaced the timer. now the washer will not drain and stops when it comes to that part of the cycle
    Genius:
  • Whirlpool Master
  • 1,474 Answers
Ok..assuming that the timer/wiring okay......Checck that the pump is not blocked also check voltage is getting to the pump 1st..
Posted on Apr 28, 2010
Washer Stops Mid-cycle
HI. this is a defective timer mechanism. it must be replaced asap, if possible. the timer is the principal initiator of the units cycles. The motor is defective at this point.
Replace this damaged timer control device asap.
Aug 20, 2009 | Kenmore 22422 Top Load Washer
WASHER SHUTS OFF BEtween wash cycle and rinse
Sounds like you have a bad timer. Simply purchase the timer. Remove the screws on the backside of the control panel and remove the defective unit. Replace the timer keeping careful attention on the placement of the original wiring. Also, when you have trouble with the unit not running for rinse and spin cycles, it is generally a good idea to replace the lid switch as well.
Jun 27, 2009 | GE WBSE2090A Top Load Washer
Frigidaire (LTF2940E) Washer starts, stops, starts, stops...
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
May 07, 2009 | Frigidaire GLTF2940ES Front Load Washer
Not sure if manifold is leaking
Leaks water...check the pump first. The fill valve and hoses may be the next step. See how to take apart info. With the use of plastic drain hoses on many machines today, this has become a common leak trouble maker. The drain hose can rub the wall or a pipe and this will rub a hole in the drain hose.
  1. Agitation problems and agitator dog repair aid info
  2. Automatic dispenser information
  3. Common problems with Inglis, Whirlpool, Kenmore direct drive style of washers
  4. Diagnostic Direct Drive washer chart from American appliance
  5. How a washer works, good to read this first
  6. Help for storing an appliance
  7. How does the agitator come off my washer ??
  8. How to prevent socks from getting into your pump
  9. Ohm test a common direct drive motor
  10. How to by-pass a lid switch for testing the washer
  11. Basic information: Inglis, Whirlpool, Kenmore Direct drive washers
  12. Inglis, Whirlpool, Kenmore Direct drive washers - How to take apart - Cabinet off, cabinet on, checking or replacing a lid switch, replace the pump, replace motor coupling or motor.
  13. Inglis, Whirlpool and Kenmore direct drive washer- useful parts breakdowns
  14. Important disclaimer
  15. My direct drive washer will fill ok, agitates ok but when it comes to the spin and drain cycle the washer comes to a screeching halt...no spin, no draining and the timer stops, what's up?
  16. My clothes have a whiting on them that looks like lint.
  17. My washer has a funky odor
  18. Noises
  19. Ohm meter testing a motor capacitor
  20. Slow water fills
  21. The wash tubs on my direct drive washer are leaning to the right...why?
  22. Timer stalls or missing cycles
  23. Timer will not advance
  24. Tips on changing a common washer fill valve
  25. To learn more about washing machines, click here
  26. Washer Basics: Filling with water
  27. Washer leaks water
  28. Washer moves around to much
  29. Washer will not spin
  30. Washer sample wiring diagrams
  31. Washer spins and agitates at the same time
  32. Washer belts: If your belt on any washer looks like these, replace the belt(s).
  33. Washer runs but wont agitate or spin
  34. Washer won't run, agitate or spin
  35. What is that black power powder or filings under my washer??
Apr 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Goes through all cycles by will not drain or spin.
If the timer hangs at points in the wash cycle, and you can manually advance, then the timer continues to run or runs shortly before hanging again, then the timer is bad and needs to be replaced.
Jan 24, 2009 | Kenmore 24032\24036 Top Load Washer
Washer fills/agitates and stops prior to draining
If pump works fine or still pumps out water, then it is a timer malfunction. Replace the timer and you should be fine. To locate a part number for your timer, refer to www3.sears.com with the model number off your washer.
Mar 14, 2008 | Kenmore 24032\24036 Top Load Washer
Washer will not pass wash cycle...Will not Drain
Nightshade, in most cases, no spin, no drain is a lid switch problem. If you advance the timer to the spin position does it spin? If the machine is agitating you can rule out the coupler. If you are sure that it is not a lid switch problem, then you are probably looking at a bad timer....Catriver..post back.
Nov 08, 2006 | Roper RAS8445KQ Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
107 people viewed this question
Dan Webster
Dan Webster
Sal De
