Question about Canon MP610 Photo All-In-One Printer
When turning on my Cannon mp610 I get error 6A00 - telling me to turn power on and off - if not consult manuel -- the print heads do not appear to be tracking as I cannot get them to come to the middle as if I need to change the ink -- any ideas? Thanks a million:)
  • 4,041 Answers
Or the purge unit needs replacement.
Incidentally, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model.
And it’s always a paper path error or purge unit.
The purge unit, called a spittoon assembly in an HP, Lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Also clean the purge unit out make sure all is clean.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 28, 2010
Testimonial: "Great -- fixed it myself in 60 seconds Thanks for your rapid response:)"
  • Clive
    Clive Apr 28, 2010
    Happy it works for you.
I have a Canon MP610 printer and am getting an error message 6A00. I have tried moving the carriage but nothing seems to help. Any suggestions?
1. Turn off the printer
2. Open cover
3. Print head and cartridges manually move to the left
4. on the extreme right is a white plastic cover is visible, which is attached to a spring
5. Clean the cover carefully (no chemicals, not wet) and gently push it back (it clicks) and remove any impurities -> the black collecting sponges for the storage of the print head can see
6. Print head and cartridges manually back to the right move
7. Turn on printer
If the above steps does not fix the problem, Click on the link below to check the forum for more details on resolving the issue.
Canon Mp610 Error 6A00
Regards,
Shawn
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Jan 05, 2011 | Canon MP610 Photo All-In-One Printer
6A00 error appears on the LCD. Have disconnected power and reconnected after a while but problem persists. Advice very much welcomed. Mike
Hi there
This answers with a titch more detail.
The 6A00 is a Canon generic code for paper path jam.
Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code.
As a Canon tech, I usually find the code, almost 90% of the time, is related to the purge unit being jammed with something and not being able to move.
Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
And yes I have found all those things in a purge unit.
The offending item needs to be removed or the purge unit needs replacement.
Mar 24, 2010 | Canon PIXMA MP610 InkJet Printer
My canon MP610 shows an error message U052 Incorrect print head
Sounds like you have to buy new printhead... take a look on amazon: Amazon com canon mp610 printhead. I hope this was helpful. Cheers
Mar 01, 2010 | Canon MP610 Photo All-In-One Printer
Error 6A00 appears. Will not print. Cannot find
Try it maybe
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Jan 08, 2010 | Canon PIXMA MP610 InkJet Printer
Error 6A00 appears. Wil not print. Cannot find
I found this elsewhere and it is from a Canon technician.
The 6A00 is a Canon generic code for paper path jam. Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code. As a Canon tech, I usually find the code, almost 90% of the time, is related to the purge unit being jammed with something and not being able to move. Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like. And yes I have found all those things in a purge unit. The offending item needs to be removed or the purge unit needs replacement. A Pixma would still be under Canon warranty, get it into a shop and save yourself the hassel.
Incidently, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model. And its always a paper path error or purge unit.
I forget myself so here goes, the purge unit, called a spittoon assembly in an HP, lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing. That is why you'll find the print head assembly parked on top of it. It also has a an electrical pump to milk the print heads and test for ink flow.
so what I would do is check for something blocking the paper path, plus turn off the printer, manually move the print head from one side to the other and back, and then turn the printer back on.
MP830 6A00 error & ON/OFF switch not working
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Jun 10, 2009 | Canon PIXMA MP830 All-In-One InkJet...
MP830 6A00 error, On switch also wont work
Hi
Seen this lots
Solution 1:
Solution 2:
Solution 3:
Showing printer error 6A00
I just copy this solution for you to this link:
the solution is posted by BAB..
they have the same problem as you ..then this solution solve it..^^
http://www.fixyourownprinter.com/forums/inkjet/39177
The 6A00 is a Canon generic code for paper path jam. Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code. As a Canon tech, I usually find the code, almost 90% of the time, is related to the purge unit being jammed with something and not being able to move. Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like. And yes I have found all those things in a purge unit. The offending item needs to be removed or the purge unit needs replacement. A Pixma MP830 would still be under Canon warranty, get it into a shop and save yourself the hassel.
May 19, 2009 | Canon PIXMA MP610 InkJet Printer
MP600
when i turn on my mp600 canon printer i get the same error code 6A00! i cannot do anything with the printer, please help!
Apr 08, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Canon MP610 Photo All-In-One Printer Logo
771 people viewed this question
old marine
old marine
