Question about Dryers
No Heat. Roper gas dryer model # RGX3514PQ0.
I have a Roper gas dryer model # RGX3514PQ0. It is not heating. The drum turns. It blows air out of the vent. I read other posts about no heat problems and decided to replace the thermal fuse. It still does not heat. I looked in the hole in the front of the dryer and turned it on to see if it's heating/burning. It does nothing. There are no clicking sounds when I press start. Any other suggestions? I don't have a voltage meter, but would love an excuse to get one. Can someone walk me through eliminating different issues/parts? There was a post by fixallphil and he suggested gas valve coils and ignitors. How do I check those?
Thanks for your help!!!!
  • russ_d_meyer Apr 28, 2010
    I got the meter! But I can't find a diagram. does a diagram of the parts help? Sears has the dryer parts diagram online at:
    http://www.searspartsdirect.com/partsdir...
  • 438 Answers
Hay Bud, you have an excellent excuse to buy a multimeter congratulations.. when you do, access the burner assembly and controller circuit board, on your disassembley you will likely find a wiring diagram, this will be very helpful in diagnosing your fault, let me know when you have the meter and the diagram and i will step you through the diagnostic proses.
Posted on Apr 28, 2010
  • Fal Mueller
    Fal Mueller Apr 28, 2010
    this is a good one for obtaining parts for your dryer, but you must have some direction as to what wire dose what and where it goes, the control board or ignitor board listed in the parts is most likely the culprit , to diagnose this unit you must define where the power comes in, the burner over temp sensor is, gas valve enable, and flame on sensor is,
    check to make certain there is power going to the board using your meter, then using the ohms scale of your new meter again set to ohms and check to see if there is continuity across the gas valve connections, if all is good set meter back to volts and engage the dryer, as the test probes are on the connections at the gas valve if not find the over temp sensor and check using ohms scale to verify continuity if this is reading as if the test probes are connected together your Ignitor board is defective and needs replacing, well this should help you good luck, let me know how you did
Roper gas dryer model rgd4440vq2 drum turns no heat have front off checked for power seems to be good i can only think the igniter is bad do you have a pic of part so i can compare it please!!!!!
YES!
If you will type in "Sears Parts" you will be given a place to enter your model number.
I tried it and it came up as"not a good number".
You try it.
That web site has complete diagrams for all machines.
Be blessed.
Feb 23, 2013 | Roper 29 Gas Dryer
I have a roper changed heating element. Still blowing cool air. Sister didnt tell me it only comes on in cooldown cycle. Wats could this be?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 17, 2011 | Roper Dryers
I have a Roper gas dryer (RGS7646KQ2) which is not heating up to dry clothes. The drum turns and the timer works as well. It appears to be acting normally, except it is blowing cold air instead of warm...
You have a bad thermostat, flame sensor, thermal fuse, gas valve solenoids, or the high limit thermostat. Below is a video to walk you thru the diagnostic testing and repair.
Jan 03, 2011 | Roper RGS7646KQ Gas Dryer
The dryer blows cold air instead of hot air.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 11, 2010 | Roper RGX4634KQ Gas Dryer
Roper dryer suddenly is just blowing cold air
heatman101
Sep 06, 2010 | Dryers
I have a Roper Gas Dryer model RGX5634KQ2. The
My bet is that your ignitor is bad....change the ignitor and you will be working again...
Here is a tip that I wrote about your problem that will explain it further...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
heatman101
Mar 30, 2010 | Roper Dryers
Roper Electric Dryer Heats but drum won't spin
Yank the filter out the top. Remove the 2 screws in the filter housing. Use a putty knife to pop the top and then remove the screws holding the front on. NOTE: raise up on the front panel slightly so you won't damage the bottom clips. Get the front out yer way and remove the drum. Clean out the dryer and oil the rollers and idler. Use this handy ROUTING GUIDE to see how to put the belt back.
Jan 20, 2009 | Roper REX3614KW Electric Dryer
Dryer tumbles, no heat
its a gas dryer it doesnt have ,,heating element...replace thermal fuse
Dec 28, 2008 | Roper RGX4634KQ Gas Dryer
Dryers Logo
243 people viewed this question
Top Dryers Experts
