Question about Microsoft Xbox 360 Controller
My xbox 360 controller will not connect to my xbox but it will connect to my friends xbox
  • wow gold Feb 25, 2012
    then turn the console off, take out the power lead from the console and then remove it from your mains, wait about 1-2 minuts then plug it up and switch on the console, first sync the xbox then the controller, and this should work, if it dosent try xbox support their number is on xbox.com
    wow gold
  • Microsoft Master
  • 2,404 Answers
See if any xbox controllers will connect to your 360. If you can't get any to connect to your xbox 360 then that means you have a bad controller board. If you can get other controllers to connect then that means you need to configure your xbox to accept that xbox controller.
Posted on Apr 28, 2010
2 Suggested Answers
  • 58 Answers
SOURCE: My WireLess XBox 360 Controller wont connect to my XBox 360
i had the same problem, and is a easy fix, turn on your console, dont need the controller on, and hold the sync button for approx 30 seconds, then turn the console off, take out the power lead from the console and then remove it from your mains, wait about 1-2 minuts then plug it up and switch on the console, first sync the xbox then the controller, and this should work, if it dosent try xbox support their number is on xbox.com
Posted on Jun 02, 2009
Microsoft kinect sensor for xbox 360 wont work unless my controller is turned off
Hi Chris, can you please check this setting:
1. Go to "System Settings" on your Xbox 360.
2. Select "Kinect Settings".
3. Choose "Chat Microphone".
How is it configured here?
Mar 23, 2014 | Microsoft Kinect Sensor for XBOX 360
Ho w to fix x box from controller to x box is really slow how to make it normal
Learn how to connect a wireless or wired controller to your Xbox 360 console.
Connect a wireless Xbox controller
  1. Turn on your console.
  2. Press and hold the Guide button on the controller until the controller turns on.
  1. Press and release the connect button on the console.
Xbox 360 E console fbbfb609-f7ed-4e6e-bd35-7543b1c20d61.png?n=xbox360-connect-m-s.png Xbox 360 S console Original Xbox 360 console 342c6e70-9e56-43d8-bb3a-05f5411040bd.png?v=1#xbox360s-connect-m-m.png 170df81e-0a79-49be-8236-a0fb68eec37b.png?v=1#xbox360-connect-m-m.png
  1. Within 20 seconds, press and release the connect button on the controller.
  1. When the lights surrounding the power button on the console stop flashing, the controller is connected.
On the Xbox 360 S console, each connected controller is assigned to one of four positions. Each position corresponds to a lighted section around the console power button and the controller Guide button. On the 360 E console, a solid green light on the front of the console indicates that the controller is connected. To determine the player position associated with your accessory, look at the ring of light that surrounds the Guide button on the controller.
c9341988-8ed5-4217-9b87-353de50efbec.png?v=1#connect-xbox-controller-m-m.png 5e4ab6ab-8cb0-41e6-a037-b88221a430c7.png?n=connect-xbox-controller-360-m-s.png
71add0b7-ddf2-4439-b4b4-f50f156d92b7.png?v=1#controller-batteries-m-m.png If the controller does not turn on, check the batteries. Insert fresh AA batteries, making sure they are correctly positioned in the battery case.
You can also use the Xbox 360 Play & Charge Kit or the Xbox 360 Quick Charge Kit to power the controller. Learn more about Xbox controllers and chargers.
To connect additional controllers, follow these same steps again. You can connect up to four controllers to the console. Each connected controller is assigned a position that corresponds with the lighted sections that appear around the console's power button and around the Guide button located in the middle of each controller.
  • To disconnect a wireless controller, press and hold the Guide button for three seconds, and then choose to turn the controller off.
  • When you turn off the console, the controller will reconnect the next time you turn on the console.
  • The controller can be connected to only one console at a time. You can connect the controller to a different console, but the connection to the previously connected console will be lost.
Connect a wired Xbox controller
5fb17f50-7448-45d5-a294-9ea90994f55b.png?v=1#controller-wired-m-m.png Plug the Xbox 360 Wired Controller into a USB port on the Xbox 360 console. There are two USB ports on the front of the console. To disconnect the controller, pull on the connector, not the cable.
cbe46bf0-3a46-4d53-9d8c-6697aa57622a.png?v=1#controller-cable-release-m-m.png The cable on the Xbox 360 Wired Controller has an inline release. The inline release on the controller cable is a safety feature designed to reduce the chance of the Xbox 360 console falling if the cable is pulled.
Wireless controller troubleshooting
If your wireless controller disconnects or cannot connect to your console, see Xbox 360 Wireless Controller disconnects or can't connect.
If your wireless controller does not turn on or loses power, try the following solutions:
Solution 1: Replace the batteries
Insert a new set of AA alkaline batteries into the Xbox 360 Wireless Controller, and then try to turn it on.
Solution 2: Try a different battery pack
If you have another Xbox 360 Wireless Controller, take the battery pack off that controller and attach it to your controller. Then try to turn your controller on.
If your controller works with the different battery pack, your original battery pack might be defective. If your controller is under warranty, you can order a replacement battery pack from Xbox Support . See the Assistance section at the bottom of this page for more information.
If your controller is out of warranty, you can buy a new battery pack from a retail store.
Solution 3: Try a rechargeable battery packIf you or a friend has an Xbox 360 Rechargeable Battery Pack, attach that battery pack to your controller and try to use your controller. If your controller works with the rechargeable battery pack attached, you can buy a new battery pack from a retail store or order a replacement battery pack from Xbox Support. See the Assistance section at the bottom of this page for more information.
Feb 08, 2013 | Microsoft Xbox 360 Controller
I was at a friends house and I was playing on the original Xbox 360 with my new Xbox Slim controller now my new xbox slim controller will not connect to my new Xbox? It was working fine before my friend...
Hmmm.....that's sounds weird. The controllers are passive devices. They shouldn't change as far as hardware behavior because they're just that - hardware. Unless the one you have has some sort of CMOS programmable feature? I've never heard of that before. The only recommendation I have is to check the pins on the plug - maybe the old xBox damaged a pin.
Feb 05, 2011 | Microsoft Video Game Consoles & Games
How do I connect 2 or more players with the xbox controller?
Follow these instructions:
  • Set up your Xbox Live connection by connecting your Xbox 360 to high-speed Internet. There are two options: connecting it to your network via Ethernet cable or connecting to your network via a wireless adapter. The simplest and fastest connection is connecting via Ethernet cable directly to your modem or router. If you must connect wirelessly, use the Xbox 360 wireless adapter, sold separately. See the Resources section below for connection tips.
  • 2
    Test your Xbox Live connection after connecting your Xbox 360 to your high-speed Internet. Navigate to the dashboard, select "My Xbox," choose "System Settings" then "Network Settings." Run the diagnostic test to confirm your connection works. Your Xbox 360 will offer troubleshooting tips if the test fails.
  • 3
    Create an Xbox Live gold account. Log out of all profiles then press the "Guide" button and choose "Join Xbox Live." Follow the prompts, entering your billing and personal information. You will also choose your gamertag during this process, which will serve as your online name and identity. Lastly, you will customize your profile. Your Xbox 360 will then create the account.
  • 4
    Insert your Xbox Live multiplayer game and open the game's Xbox Live multiplayer menu. Different games have different options but certain features remain the same across all multiplayer games. There is the TrueSkill ranked matchmaking system, which pits you against players of similar skill levels. There are also unranked player matches, where you can practice and hone your skills in a non-competitive atmosphere. Lastly, there is the quickmatch matchmaking system, which automatically searches for games for you, whether they are unranked or ranked.
  • 5
    Add and play with friends. Xbox Live allows users to add up to 100 friends. Add a friend by pressing the "Guide" button, navigating to the "Friends" tab, then selecting "Add Friend." Type in your friend's gamertag then press the "Start" button and choose "Send Friend Request." Your friend will need to confirm the request to complete the process. You can play multiplayer games with friends by opening your friends list and inviting them to a game lobby.
  • 6
    Communicate with friends and opponents using an Xbox 360 headset. The wired Xbox 360 plugs into your controller. Once it's plugged in, you can speak into microphone and listen to others from the ear piece.
  • Hope this will help...Your response is very much appreciated...
    Jan 21, 2011 | Computers & Internet
    My Xbox controller will not connect to my console (Xbox 360 S). It was working fine and I connected it to a friends Xbox and used it, it worked normally. When I got home it would not connect to my Xbox. I...
    There is a XBOX 360 repair guide available that covers this problem and also all other common XBOX problems. You can get your copy XBOX 360 Repair Guide.....you can download it and get help to fix your console.......
    Click here to download Microsoft xbox360 repair guide
    Jan 04, 2011 | Microsoft Xbox 360 Console
    My xbox 360 controllers will not connect to my unit through the USB, does this mean they need to be replaced?
    take them to a friends house and see if they recognize them. this should tell you. also bring a friends controller and plug into your deck
    Oct 09, 2010 | Microsoft Xbox 360 Controller
    Xbox 360 can't connect to "xbox live party" for me or my friend
    make sure u both have gold and make sure ur network doesnt have strict security
    Jul 31, 2009 | Microsoft Xbox 360 Console
    Xbox 360 wireless control pad wont connect
    have you tried to pair it... the little white button on both the controller and the 360? works just like the wii remote
    Feb 07, 2009 | Microsoft Xbox 360 Console
    Microsoft Xbox 360 Controller Logo
    1,001 people viewed this question
    Top Microsoft Video Game Consoles & Games Experts
    marley mcelhinney
    Tre Elkins
    Martin Murray
    Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
