Question about Kenmore 24032\24036 Top Load Washer
The washing machine only keeps filling with water never stops
Fills constantly with water never stops immediately drains and never goes to next part of cycle
  • 438 Answers
There is a water sensing device in your unit that is not working, it is located at the top end of a small plastic tube cumming from the washing drum the unit will have a number of wires going to the top or side of it and the plastic tube attached to the bottom, replace this unit
Posted on Apr 28, 2010
Simpson esprit 500 wont stop draining
Is it possible the drain pump is running because the machine won't stop filling? Does the drain pump start running when machine start filling or doe it come on when machine is about full?
Jan 27, 2013 | Washing Machines
It dos not stop filling up water
The pressure switch, also called the water level switch, is what control the amount of water goes in the machine, If your machine is constantly filling to the overflow point, then that is your problem. Now, if water is going in and the level is staying the same then your machine drain line is lower than the pump and your siphoning out the water as it goes in. Pull the drain up a little a that should fix the problem.
May 27, 2012 | Zanussi ZWF1430W Front Load Washer
Roper top loading washer RTW440VQ1 will not stop filling up
May 22, 2012 | Roper RAX4232KQ Top Load Washer
Washer doesn't stop filling up
May 08, 2012 | Kenmore Washing Machines
Washing machine constantly fills
May 08, 2012 | Whirlpool Clothes Washer Water Level...
It doesnt stop filling
Apr 26, 2012 | Samsung SW62ASP Top Load Washer
LAV3600AAW Maytag Top Loading Washer
check your house drain make sure it is above water line in tub
Nov 30, 2007 | Maytag SAV5710 Top Load Washer
Running water
Sounds like your stand-pipe has fell over,located behind machine that the drain hose goes into.This pipe must be vertical,and secure.The top of the washers drain hose loop that goes into the stand-pipe, should be as high as your soap dispenser.If this is not the problem then your water pump must be pumping the water out all the time.Can you hear the pump? If so, some faults can force the washing machine into a constant cycle of filling with cold water and pumping the water away if it thinks the washing machine is overheating (possible faulty thermistor).Hopefully its only your stand-pipe causing the loss of water.Lets know how you get on.Good luck.
Sep 05, 2007 | LG WFT1071TP Top Load Washer
Washer fills and drains repeatedly
Have a look at the routing of your drain hose. It sounds a bit as if: a. The highest point of the hose isn't high enough (you normally want to aim for about 3 feet off the ground) - so that water starts draining from the machine before it is finished filling. and b. There isn't an effective air break or anti-siphon valve where the drain hose goes into the domestic drainage system - so that once the machine starts to drain by itself, it continues until empty. A.
Jun 07, 2007 | GE WJSR2070B Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
164 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
