Question about Visonik Car Audio & Video
I was given an alphasonik aeq-720 (made by visonik) equalizer. I need a wiring diagram for it to properly install it
5 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: need wire diagram for clarion 500EQA equalizer
Your installation manual is not anywhere to be found since the product you are inquiring about was made 1985-87... however, by deduction, you can figure it out yourself...
You need a Power 12V Constant.
A 12V Switched
A Ground
And Signal Cables.
Reply with the wire colors available to you, and I will tell you what is what.
Yellow is usually constant 12V.
Red is Ususally switched 12V.
Black Is Ground.
RCAs are self explanitory.
If your EQ has HI Level outputs, the color scheme is a little more complicated.
Posted on Jan 10, 2009
BangEmBoy
  • 40 Answers
SOURCE: wiring diagram for BOSS AVA 1209 equalizer. It
Your wiring is as follow's :
The Red wire is your (+) Positive that connect's to the power source
The Black wire is your (-) Negative that connect's to the ground
The Orange wire is your Auxillary (+) that turn's on Amplifier's or Power Ant.
You should have a Green wire, a Green wire with a White stripe,a Gray wire, and a Gray wire with White stripe
The Green wire is the LEFT channel input (+)
The Green/White wire is the LEFT channel input (-)
The Gray wire is the RIGHT channel input (+)
The Gray/White wire is the RIGHT channe (-)
(BE SURE THAT YOU CONNECT THE RED (+) AND BLACK(-) WIRES BEFORE YOU CONNECT THE ORANGE WIRE TO AN AUX SOURCE OR YOU WILL BLOW THE INTERNAL FUSE !!!)
PS. I have no idea where that White wire you mentioned goes.
Posted on Feb 13, 2011
danielnajer
  • 4 Answers
SOURCE: I need a wiring diagram
Click on MANUAL DOWNLOAD
LOOK PAGE 4 INTO THE PDF FILE!!!!
http://www.pyramidcaraudio.com/sku/903G/10-Band-Half-Din-Power-Booster-Graphic-Equalizer-Amplifier-200-Watts#
Posted on Aug 08, 2012
mail44jacque
SOURCE: need wiring diagram for a Roadmaster EA400N 100 Watt Equalizer
Roadmaster EA400N
Wire Colors
Brown - Right Signal In
Gray - Right Out (-)
Pink - Right Rear Out
Dk Blue - Right Front Out
Green - Left Signal In
Yellow Left Rear Out
White - Left Out (-)
Orange - Left Front Out
Black - Common
Red 12VDC In
Posted on Sep 01, 2012
Where can i find a wiring diagram for these subs??
Here is a link for wiring speakers:
http://www.crutchfield.com/S-cgSECUmngLm/learn/learningcenter/car/subwoofers_wiring.html
Your speaker is a DVC so follow the Dual Voice wiring as it is universal set up.
Sep 19, 2010 | Alphasonik PSW112C Alpha 100 Series 12"...
How to wire pma100 voltmeter without amp
Hey dude- if you dont figure out how to wire that thing up -i need one for my pma-2500a i got it from the pawn shop yo for 150 bucks !!!!!!! shwinggggg its a beast 1600 rms at 4 ohms bridged - what a steal but yea i need one so lets make a deal dude !!!
Jun 06, 2009 | Alphasonik PMA1000HCA Car Audio Amplifier
DONT KNOW HOW TO RUN 2 OHMS
Hello storres18,
If you have the Kicker model number 06CVX122, with dual 2ohm voice coils, they can be connected to a mono amp at 2ohms. First jumper the voice coils in series, the dotted positive (+) to the undotted negative (-) (or vice versa). Each sub is now 4ohms. Then wire both of the remaining positives and negatives together on the amp terminals (in parallel). The amp sees a 2ohm load. Here's the diagram:
If you have the Kicker model number 06CVX124 with dual 4ohm voice coils, they cannot be wired to present a 2ohm load. They can only be wired as a 1ohm load (too low for the amp) or as a 4ohm load (at reduced power). Here is the diagram of the 4ohm wiring:
Hope this helps.
May 10, 2009 | Visonik V900XD Car Audio Amplifier
Need to know what connections for 6 pin input port
honestly anything made by visonik is **** and i wouldent try wiring it like that it could have bad consequences do rca or call visonik and order a replacement
Apr 26, 2009 | Visonik V117SX Car Audio Amplifier
Need wiring instructions for vbx12a
You will need the following:
A power wire (preferably 4 or 8 gauge) with an inline fuse (typically 50amps)
A battery terminal adapter to connect the power wire
A signal wire to let the amp know when the stereo is on
RCA audio cables to connect the amplifier to your stereo
A ground wire for the amplifier (again 4 or 8 gauge preferred)
Walmart sells a Scosche kit that has all of the wiring as well as a basic diagram for about $25, but it does not include the battery terminal adapter.
If you have a factory stereo you won't have RCA ouputs, so you will need a line level converter. A basic one like the Scosche SLC4 usually runs in the $20 range. You splice into your speaker wires and run them into the unit, then plug the RCAs into it.
Mar 08, 2009 | Visonik VB-10PKG Car Audio Amplifier
How do i wire an equalizer without any wiring diagrams
how do i hook up my equalizer color code info
Jan 16, 2009 | Car Audio & Video
Installing visonik bass system
Here is a link to visonik to download manuals.
http://old.visonik.de/en/downloads.php
If you let me know your model number of the sub, vehicle make and model, and brand and model of headunit or CD player you have then i can provide wiring color codes, recommended wire routing locations, etc...
Jan 03, 2008 | Visonik 10" 500-Watt Single Bandpass...
Installing pyramid 795cd equalizer
cd player or dvd player output------------to equalizer input---------equalizer output---------amplifier input--------amplifier output ----------to speakers
May 26, 2007 | Pyramid PR333E Home Equalizer
Car Audio & Video Logo
87 people viewed this question
Top Visonik Car Audio & Video Experts
xxxxxx xxx
Are you a Visonik Car Audio and Video Expert? Answer questions, earn points and help others
