Brother MFC 240C All-In-One InkJet Printer Logo
Posted on Apr 28, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Printer is jamming up
My all in one brother printer is jamming paper; for this reason I cannot print anything. what can I do?
Clive
Level 3:
  • Master 4,362 Answers
  • Posted on Apr 28, 2010
Clive
Master
Level 3:
Answers
4362
Questions
0
Helped
1813926
Points
14613
Hello there Ok try see if this will help
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you.
Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 07, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
90
Points
I don't have a solution, but unfortunately for me, my 8890DW also started jamming papers suddenly. The machine is too heavy for me turn upside down. I was wondering if you have any suggestion specific to this model. Thanks.
How do I Fix Brother printer printing blank pages issue of my Brother printer?
Completely or partially blank pages when printing from ...
Brother-USA https://help.brother-usa.com > answers > detail > a_id
Completely or partially blank pages when printing from Windows or Macintosh computer only. 1. Place a document with text or an image on the flatbed or in the ...
The printer prints blank paper - Brother HL-5240
iFixit https://www.ifixit.com > Answers > View > The+printe...
Sep 5, 2016 · 5 answers
Here are the steps to fix the brother printer printing completely blank pages issue. 1. First of all, you should restart the devices, ...
Fix brother printer printing blank pages
brothersetupsupport.com https://brothersetupsupport.com > fix-brother-printer-...
Jan 23, 2023 - Why brother printer keeps printing blank pages · Ink cartridges have jammed or there is a paper jam. · The printer head is blocked or jammed. · The ...
1helpful
When I turn on the printer the light paper flashes
The paper light flashing because there is some paper inside the printer. Open the front cover and remove the cartridge and look inside for the jammed paper. Remove the jammed paper and insert the cartridge , closed the front cover and switch on the printer.
It will help you to solve the problem.
I cannot get my brother HL-5140 laser printer to print anything!!!!!! I have tried all troubleshooting suggestions.light on status is red
There is some paper jam inside the printer .Please remove the cartridge and look inside the printer for paper jam. If paper jam is there , remove the paper . I hope it will help to solve the printer problem.
My Brother HL-2040 paper led light won't stop flashing, the paper's not jammed or anything, I just put in a new toner, too. I tried doing what someone else said about opening the cover and holding Go until...
Hi. The reasons listed in the manual that cause the LED to flash normally are:
Front cover is open
Close the front cover of the printer.
Back cover is open
Close the back cover of the printer.
Paper jam
Clear the paper jam. See Paper jams and how to clear them on page 6-5.
If the printer does not start printing, press the Go button.
No paper fed manual feed slot
Put the paper in the manual feed slot. See Printing on plain paper, bond paper
or transparencies from the manual feed slot on page 1-10 or Printing on thick
paper, labels and envelopes from the manual feed slot on page 1-13.
Memory full
The printer memory is full and the printer cannot print full pages of a
document. See Solving print problems on page 6-15.
Print overrun
A print overrun occurred and the printer cannot print full pages of a document.
Drum Error
The corona wire needs to be cleaned. See Cleaning the corona wire on page 5-14.
If you check out page 6-5 it tells how to clear the paper jam from the rear of the machine! A point often missed.
Check out the website below if you don’t have a copy of the instruction manual =
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc002089/US_Eur.pdf
If all else fails, try a reset of the printer Drum & Page counter:
  1. With printer tuned on.
  2. Press and hold the “internal button” behind front cover, until all LEDs illuminate.
  3. Make sure Drum light is off, then release and close front cover.
Hope some of this helps………..Please post a response back here and let us all know if it works?............Regards, Cornwellnet (UK)
Paper Jam
Check the paper being used against what the printer manual recommends.
Fan the edges to ensure cut edges are free.
Don't use damp paper, ie high humidity may cause drag.
Leading edge should be flat, not curled.
1helpful
Won't print. blinking red paper light flashing
This usually means your printer is out of paper or there is a paper jam somewhere.
1helpful
My Brother Multi-Function Center MFC-240C All-in-0ne Paper Jammed
how i can i plug mymulti-function center mfc model mfc240c to my pc
Paper jam with 4 x 6 paper
I would tell you how I solved the problem, but it will cost ya !
Norman Weimar
Norman Weimar
k24674
