Question about Frigidaire FTF2140E 3.5 Cu. Ft. Front Loading Washer
I have a Frigidaire good model FTF2140ES0 front load washer, and it's indicating error code E59. I read a few Q&A's and replaced the control board. This helped to the extent that the washer would start to fill with water (hot & cold) then shut off for a minute or so then begin to fill again - not ccompletely - then not do anything. Following test 12, the motor spins freely and so does the tub. I can't measure the Ohms. Should I go ahead and replace the control board or is this a problem with the eletronic water level sensor or something else?
  • 196 Answers
SOURCE: Washing Machine starts, squirts water, then stops.
E5E  IS FOR  Communication problem. THERE IS 100 %WIRE SHORTING SOMEWHERE.PLEASE CHECK OUT.
ALSO OTHER ERRORS Error code - Fault condition
E11 Fill time too long.
E13 Water leak in tub or air leak in air bell.
E14 Reed switch.
E21 Water not pumping out fast enough.
E23 Drain pump relay on control board failed.
E24 Drain pump relay on control board failed.
E31 Better models. Pressure sensor not communicating with control board.
E35 Better models. Pressure sensor indicates water overfill.
E41 Control board thinks the door switch is open.
E42 Door remains locked after cycle is completed.
E43 Control board problem.
E44 Control board problem.
E45 Control board problem.
E46 Control board problem.
E47 Board thinks the door PTC circuit is open in spin.
E48 Board thinks the door PTC circuit is closed.
E52 Bad signal from tacho generator.
E55 Motor overheating.
E56 High motor current.
E57 High current on inverter.
E58 High current on motor phase.
E59 No tacho signal for 3 seconds.
E5A High temperature on heat sink.
E5B High temperature on heat sink.
E5C High temperature on heat sink.
E5D Communication problem.
E5E Communication problem.
E5F Communication problem.
E67 Input voltage on microprocessor incorrect.
E75 Better models only. Water temperature sensor circuit.
E76 Better model only. NTC temperature for the cold water valve over the limits.
E95 Communication error.
EB1 Incoming power frequency out of limits.
EB2 Incoming line voltage above 130 VAC.
EB3 Incoming line voltage below 90 VAC.
EF1 Clogged drain pump.
EF2 To much soap.
Posted on Nov 12, 2008
  • 130 Answers
SOURCE: Frigidaire (LTF2940E) Washer starts, stops, starts, stops...
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Posted on May 07, 2009
  • 212 Answers
SOURCE: Code F43 on frigidaire front load washer.
motor control possibly bad
Posted on Jun 20, 2009
SOURCE: my frigidaire washer FTF2140ES0 won't spin on the spin cycle
Hi there, the same thing is happening with our washer. Did you find a solution to the problem? We found a coin the the black tube, but it still doesn't do the final spin. I can hear the motor trying to do something, but it just won't do the final spin. If anyone has any idea or suggestions it would be greatly appreciated. In the meantime, I have a load of slopping wet laundry to deal with. :(
Posted on Jan 26, 2010
  • 2468 Answers
SOURCE: I have a mo# FTF2140ES0 front loader washer that won't spin
check the pump for a blockage,if the water cantget out of the wash tub,the machine senses this and wont spin out the load,also make sure to check both sides of the pump from the tub to pump and pump to house drain sides
Posted on Mar 12, 2010
Testimonial: "Thanks for the help, this was very helpful"
GLTF2940ES3 - Frigidaire Front load washing machine e59 error code
http://www.ehow.com/info_12127418_frigidaire-gltf2940fs1-not-spin-error-e59.html
May 02, 2014 | Frigidaire GLTF2940ES Front Load Washer
FAFW3801LW3 has error e59
Hi Rosie,
I understand that you're receiving an E59 error code on your Frigidaire washer, model# FAFW3801LW3 and are looking how to run the diagnostic test. While there isn't too much information about actually running the diagnosis, I would recommend contacting the manufacturer and seeing if they are able to assist.
-Best Regards-
Jan 23, 2014 | Frigidaire FAFW3801LW Front Load Washer...
Frigidare errow code e59 display
Hi Emily,
I see that you are receiving an E59 on your Frigidaire washer. E59 states that "No Tacho" Signal for 3 seconds. I would recommend giving the appliance a hard reset. You will do this by either unplugging it or switching the circuit breaker off that the washer is attached to. When you do this you will want to leave it off for 3-5 minutes. Once the 3-5 minutes has elapsed, bring power back to the washer and try to restart it. If you are still receiving an E59 error code, I would suggest contacting your local authorized technician to diagnose and see why you keep receiving this error code.
-Best Regards-
Jan 21, 2014 | Frigidaire Washing Machines
Frigidaire E57
Hello Daniel Huntley - Typically error code E59 indicates that that washer is not detecting a tacho signal for about three seconds. Contact a professional to move forward accurately. Certified technicia will need to remove the belt from the motor, spin the motor pulley, diagnose the speed control board and etc.
Jan 07, 2013 | Frigidaire Affinity ATF8000FE
Filter replacement for frigidaire gltf2940es
Hello - The error code "E20" typically means the water is not draining properly or not pumping out fast enough. Does the washer making a humming noise? If so, either the drain hose may be kinked or the drain in the house is clogged. Once you have confirmed and cleaned the hose and issue continues contact a professional to move forward accurately. The unit may possibly have a faulty pump or control board.
Nov 05, 2012 | Frigidaire GLTF2940ES Front Load Washer
Kenmore Super Capacity 3.5 error code E59
see the error code E59= E59 equals no tachometer signal for 3 seconds.
This means that the motor is not signaling to the washer normally and may be caused by a variety of failures within the motor, basket or the control board. Generally speaking, the E59 error requires the service of a Frigidaire professional for resolution due to the technical nature of the ERROR.
God bless you
Aug 01, 2012 | Kenmore 3.5 cu. ft. Front Load Electric...
What does error code E59 means on a Frigidaire Affinity front load clothes washer?
Hiya
if you have pressed any of the buttons during a wash cycle then you will be given an error message on the display to change the wash options once started you must 1st pause the wash before making any changes, this i think would be the main reason for such an error to appear however you can download your operaters manual at http://www.frigidaire.com/manuals
if you do not already have it & from there you may be able to have a read & work out why you received this message alternativly from the site you will get a link to a contact us section where you may be abal to ring the customer services & then have the assistant check the code for you..
Hope this helps
Apr 22, 2010 | Frigidaire Affinity ATF7000ES Front Load...
How do you fix an error E59?
depending on the ohms readings you may have to replace the motor or the speed control board board.disconnect the plug from the motor check the resistance on pins 1to 2 1 to 3 then pin 2-3 the should read between 4 to 6 ohmsi fthis is correct replace the speed control board if not replace the motor.check pins 4-5 if the resistance is not between 105 -130 ohms replace the motor
Sep 17, 2009 | Frigidaire ATF6000ES Front Load Washer
I started with E20, pulled the hoses off and the drain was clogged. I "put it back together" and now Im getting E59 code. What did I do wrong?
E59 No tacho signal for 3 seconds. This is a motor issue. follow the steps bellow to diagnose this issue.
Remove the belt from the motor and spin the
motor pulley. Does the motor spin free? If the answer is no to the question, you will need to replace the motor. if the motor is free, move on to the next step.
Disconnect the plug from the drive motor and
measure the resistance between pins 4 & 5
in the motor. If the meter reads other than between 105 & 130 Ohms, replace the motor. If the reading is between 105 & 130 Ohms, move to the next step.
Disconnect the plug from the motor and
measure the resistance of the windings (pin
1 to pin 2, pin 1 to pin 3, pin 2 to pin 3). All
readings should be between 4 and 6 Ohms.
If the readings are correct, replace the speed control
board.
If the readings are incorrect, replace the motor.
May 18, 2009 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire front load washer displays E20 what does that mean?
E59 code means you need a new circuit board and Frigidaire knows it's a problem, but will only step up to repair if you demand it. we're on our second circuit board in 2 years!
Aug 09, 2007 | Frigidaire GLTF2940E Front Load Washer
Frigidaire FTF2140E 3.5 Cu. Ft. Front Loading Washer Logo
77 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
