Question about Tricity Bendix WDR1240W Front Load Washer / Dryer
Tricity Bendix WDR 1041W - Put wash on and then realised I had missed an item on the floor so paused the machine and opened the door to add item to the wash, but when I pressed the start / pause button it wouldn't start. Have tried turning it off for a while, and starting again but still can't get it start. Turning it off for a while allows me to open the door but when I try any of the programmes the pause light stays on Any suggestions? Is there a reset button somewhere?
    Genius:
  • Tricity Bendix Master
  • 1,466 Answers
Check the childlock is not on
Posted on Apr 28, 2010
How to remove filter on tricity bendix 1000 washing machine?
tricity bendix aw1001w eco shower washing machine ...
? 1:11
www.youtube.com/watch?v=lJZrGLfYdtQ
Aug 19, 2009 - Uploaded by whichwasher2007
my aunt's old tricity bendix. it says aw1000w on the front, but check ... How do you clean out mold in the ...
Sep 29, 2015 | Tricity Bendix AW1000W Front Load Washer
How do i remove clothing stuck between door seal and drum on tricity bendix washing machine
Frankly the only way you can get them out if you can get hold of them is pull like hell, something will give hopefully the clothes, but probably won't be any good afterwards, otherwise this is not an easy task and you should get a repairer to do it. Not the best advice in the world. but in future any small items should be put in a pillow case to avoid this happening again.
Aug 17, 2014 | Tricity Bendix AW1000W Front Load Washer
Wdr 1242 w
Hi if you give the people you are going to buy from the make and model thay should give you the correct part,all the best.
Jun 15, 2014 | Tricity Bendix Washing Machines
Light Blinking (start/pause)
Door lock faulty probably,,,,try closing door,,switching on and lightly thumping door near handle
Jun 15, 2013 | Tricity Bendix AW1000W Front Load Washer
Tricity bendix wdr 1241 emergency drain hose leak
Pull the machine out, if the back is removable, take it off. the connection should be close enough to reconnect...next time? don't pull so hard. if this doesn't work, take it to a reputable Repair Shop/Dealer
Oct 15, 2012 | Tricity Bendix WDR1240W Front Load Washer...
I have lost my manual need a replacement
Hi.
Please click on the link below to open the manual in PDF format.
WDR 1040 W WDR 1240 W
Regards.
Ginko
Aug 31, 2011 | Tricity Bendix WDR1240W Front Load Washer...
Machine stopped in middle of cycle model no wdr 1041 it has come up error 20
Means the appliance is not draining. Remove the filter from the drain pump, this should be located at the bottom front, remove it and check for blockages and remove. hope this helps
Feb 23, 2011 | Tricity Bendix Washing Machines
Tricity Bendix AW1400W front load. Water leaks onto floor (a lot). Hoses dry. Pump and drain hose OK. Running the program causes leak. Pouring water into soap dispenser drawer causes leak. Just pouring...
Ether the washer is over filling or has warn out the seals. If it has been abused (overloaded) it needs serious work. other wise the sensor may be stuck. Try 1/2 cup of vinegar with a load and see if that cleans the sensor travel area past the drum but inside the tub. This is a common problem for an old machine. Best leak is on the door and you may be able to tighten the screws but be careful it could mis aligne it so tighten a small amount and test by closeing the door. Do this at least twice before turning the screws hard.
Aug 17, 2009 | Tricity Bendix AW1400W Front Load Washer
Dryer
We found that we needed to turn down the water inlet to almost off and then the dryer worked when we had the same problem.
Remember to turn it back up again before the next wash
Mar 13, 2008 | Tricity Bendix WDR1240W Front Load Washer...
Tricity Bendix AW1400W Won't spin or agitate.
this could either b the motor brushes or the timer check the brushes first they r mounted on either side of the motor unplug the machine b4 u start good luck
Aug 26, 2007 | Tricity Bendix AW1400W Front Load Washer
Tricity Bendix WDR1240W Front Load Washer / Dryer Logo
319 people viewed this question
Top Tricity Bendix Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Tricity Bendix Washing Machine Expert? Answer questions, earn points and help others
