Question about HP w1907 LCD Monitor
Need to clean up temp and prefetch for memory space and has a .dll problem and driver software download for wide monitor failed
  • 11,361 Answers
Try CCLEANER from WWW.FILEHIPPO.COM
Also should get MALWAREBYTE.
Posted on Apr 28, 2010
PC monitor goe blank when mouse is moved to the right, but not to the left
it seems that your window is crashed so you have to frist boot your window in safe. when you press power button to ON your computer then press f8 it will show you safe mode after when your systems start in safe mode then reinstall unused software from add remove program . clear temp file, prefetch . in can come in run and write %temp% and hit enter and delete all temp file. for prefetch -write prefetch in run and clear all. if you download any suspious software so remove it from download then shut down your computer and then POWER on after 5 Minute then your system will work fine
Aug 21, 2014 | Dell Computers & Internet
Kernel32.dll can be a problem, so my pc taking too much time to shut down
How to perform kernel32.dll repair, one common methodinvolves acquiring a new version of your kernel32.dll file and installing itright into your registry. This will fix most problems with the file- like ifit's missing or if it's still there but has become corrupted at one point oranother.
Dec 21, 2010 | Computers & Internet
Errors
solution 1>
CAUSE:
Certain HP services (and associated DLL files) were somehow partially/improperly installed. (Possibly, from a previous failed install?)
The Windows services (files) were:
Pml Driver HPZ12 (C:\Windows\System32\HPZipm12.dll)
Net Driver HPZ12 (C:\Windows\System32\HPZinw12.dll)
The existence of these 2 files in the System32 directory was causing this error in my situation. Somehow, the installation script was not identifying that these files were already installed (or improperly installed) and failing to properly set them to be installed again.
SOLUTION:
Steps:
1) Check to make sure that the 2 Windows services above are not running (or not installed).
2) Rename/delete the 2 associated service DLL files (this will only be possible once the services are stopped)
3) Run the installation again.
solution 2>
complete uninstall printer software from computer.
run uninstall L1 L2 L3 L4(if not an hp computer).
run same uninstall l1l2l3l4 from 7z..folder or hp folder from temp if availalbe.
then clean from add remove programs/program and features.
then clean from cleanup utility all hp pritner related entries.
then clean temp folder. clean recycle bin.
delete c:\program files\hp and hewlett packard folders (if not an hp computer). on hp computer delete digital imaging bin folders.
delete following folders from following locations-
C:\windows\System32\Spool\Printers and deleted entries inside it
C:\windows\System32\Spool\drivers\w32x86\*.* deleted entries inside it
C:\windows\twain_32.
cleanup from regsitry--
plz make back up for registry first.
>> hklm/system/current control set/control/print/environment/windowsNT(x86/64)/drivers + processors delete all pritner entries from there.
>> hklm/system/current control set/enum/usb/vid_000,vid_003 delete.
>> hklm/system/current control set/enum/usbprint delete pritner entries.
>> hklm/system/current control set/control/print/monitors/hp standard tcp/ip ports/ports.
>> hklm/system/current control set/control/print/monitors/standard tcp/ip ports/ports.
>> delete same ports from printers and faxes/pritners pritner properties ports
>> hklm/system/current control set/control/print/monitors/hpz..
>> hklm/system/current control set/control/print/providers/lan man settings.
>> hklm/SYSTEM/CURRENTCONTROLSET/CONTROL/PRINt/PRINTERS
>> hkey_Current_User\Software\Hewlett-Packard
>> hKey_Local_Machine\Software\Hewlett-Packard
>> HKEY_USERS\.DEFAULT\Software\Hewlett-Packard
>> hkey_current_user\software\hewlett packard delete if not hp computer.
>> hkey_curent_configuration/system/current control set/control/print/pritners.
then go to msconfig
make it selective startup disable all microsoft services except hp services. hide all microsoft services. disable all startup tab apply restart.
after restart install cue version 12 officejet pro 8500 or 6500.
then run msiexec.exe /unregister then msiexec.exe /regserver cmd commands.
then install software from downloaded version of original pritner install only basic drivers first and imaging devices only and use solution center 12. cue 12.
issue resolved.
Nov 02, 2009 | Computers & Internet
Error Code: 2753 " Fatal Error or error MSI.dot4msi"
CAUSE:
SOLUTION:
Steps:
solution 2>
then go to msconfig
issue resolved.
Jun 19, 2009 | HP LaserJet 3055 All-In-One Printer
Desperatley Seeking Sound
Hey Hi,
Firstly You Need To Completely Uninstall The Audio Driver Software Using The Following Uninstaller Software. Click On The Link Below And Download And Install The Uninstaller Software.
Click Here To Download Uninstaller Software
Delete %TEMP% & PREFETCH files After Removing The Audio Drivers.
Start --> Run --> %temp% --> Delete All Files.
Start --> Run --> prefetch --> Delete All Files.
Restart You System..
Click On The Link Below To Download And Install The Latest Driver Software From Intel Website.
INTEL DESKTOP MOBO DRIVER DOWNLOAD
Choose the exact Model Of The Motherboard and download and install the LATEST DRIVER SOFTWARE...
You may take help from INTEL CHAT SUPPORT as well.
INTEL CHAT SUPPORT
After visiting the link below click on the DESKTOP MOTHERBOARD and scroll down the page and you will see the LIVE CHAT SUPPORT BOX so kindly take their assistance if you need....
May 31, 2009 | Computers & Internet
Laptop network controller not working
hi,
Please install microsoft UAA driver first.
the download the driver from http://support.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R149798&SystemID=INS_PNT_1501&servicetag=&os=WW1&osl=en&deviceid=2966&devlib=0&typecnt=0&vercnt=2&catid=-1&impid=-1&formatcnt=1&libid=5&fileid=19898
and install it it will work.
Make sure that the chipset driver should be loaded there before running the setup of ethernet.
May 28, 2009 | Dell Latitude D600 Notebook
Lexmark X2500 All-In-One delays my windows start up
Probably I've solved the problem.
You have to work on Windows Prefetch.
Download Windows XP Prefetch Clean and Control (from www.majorgeeks.com/download2495.html).
Launch this program.
Select the option "Clean Prefetch Folder Now" and "Monitor boot file launch only (Recommended)". Then select the buttons "Set Prefetch Parameters" and "Exit".
Restart your pc.
dlvico
May 14, 2008 | Lexmark X2500 All-In-One Printer
When updating the anti-virus, a message in the box states"SYMLCSC.EXE file is linked to missing export ADVAP132.Dll. Register service CTRLHandleEXW." The Symantec Shared Components failed. will...
go to symantec.com and download norton removal tool to simply remove your antivirus. then re-install. btw, always empty %temp%, temp, and prefetch. this will help increase the installation rate.
Mar 11, 2008 | Computers & Internet
Install of IBM infoprint printer drivers
make sure you are logged on a the Administrator to the computer then try installing..
Dec 26, 2007 | Office Equipment & Supplies
Low space
Have you tried clearing the "Temp" and the "Prefetch" folders?
Go to Start -> Run
Type - "temp" (without the quotes) in the run dialog and delete all files with Shift+Delete.
Repeat the same operation with the prefetch folder. (Type prefetch instead of temp now)
It should be able to clear just a few MBs.
Also, I would recommend uninstalling any unwanted software that you may have installed on your system.
Also, as it is evident from your above post, you have been saving a lot of stuff in the My Documents folder. I would hereby recommend saving large files on the C Drive(D) drive so a balance would be maintained.
Oct 17, 2007 | Acer Aspire 5630 Notebook
HP w1907 LCD Monitor Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
