Question about Epson Office Equipment & Supplies
I have an EPSON Expression 636 scanner I use in my orthodontic office to scan X-Rays. It connects to my current Dell laptop computer with a SCSI card. I recently bought a Sony Vaio computer, which does not have a connection for the SCSI card, but uses an ISB socket. Is there a cable that will connect my scanner to my new computer with an ISB plug?
  • 6,993 Answers
you typed "ISB Plug" but I believe you are referring to USB plug.
The answer is yes, there is USB cable for your scanner. Check the link below, you will find a picture of the plug, so that you can have an idea of what it looks like.
http://www.getprice.com.au/Gryphon-M130-Scanner-USB-Cable-Gpnc_629--29938276.htm
or
http://www.getprice.com.au/images/uploadimg/348/350_product_374.jpg
You can order this plug online or get it from any computer accessories shop within your vicinity.
Good luck.
Posted on Apr 28, 2010
My computer is toshiba vista have tried to connect my older scanner but message comming back reads - cannot communicate with scanner if using scsi connection restart computer. Also say's fine scan cannot...
its possible that the driver for your older scanner is not compatible with vista this is often the case. the disc that came with your scanner will tell you this ie: for use with win 98, me, xp. if it doesnt say vista you will have to search internet for a vista driver or go to scanner make(ie: epson.logitek) internet site and see if there is a drver there. hope this helps
Jul 08, 2010 | Computers & Internet
Fuzzy scanned image from Epson Expression 10000XL scanner
Make sure that the item being scanned is lying flat against the scanner's glass. If the scanned image is still fuzzy after adjusting the object, clean the scanner glass with a lint-free cloth and some vinegar or ammonia-free window cleaner.
Hope this helps you. Please If this solutions solves you problem, please do not forget to rate my solution. If not, then please comment back so I can help some more
Apr 10, 2010 | Epson Scanner Expression 10000xl Pro A3+...
Stopped at start-up after months of no problems
Please trash the twain driver completely.
- Trash epson scan and epson scanner monitor from applications.
- Go to hd. Go to library, then application support. Trash epson scanner module.
- Go back to library. Click on image capture. Trash twain data sources.
- Go to the hd. Click on users. Click on your computer name. Click on Library. Click on preferences. Click on the epson folder. Trash epson scan.
- Empty the trash and restart your mac.
Log on to epson.com. Install the epson11926.dmg.
Apr 28, 2009 | Epson Expression 1640XL Flatbed Scanner
Our Epson Scanners do not work from Photoshop CS4
Try using a separate scanner utility to do yr scans - not ideal but sorted my problem. I use the EPSOM scan utility with a Perfection 2400 scanner.
Apr 17, 2009 | Epson Expression 1640XL Pro Flatbed...
Dell laptop wont recognize ls2000 scanner
The LS-2000 is a "legacy" device to XP and the Nikon software. It needs to be connected to a true SCSI bus adapter, and it's actually pretty finicky about which ones will work in XP. Sorry, you won't be able to use this with your laptop.
Feb 28, 2009 | Nikon LS 2000 Film Scanner
Scanner won't turn on
Try to test the power cord of the scanner (cable from scanner to outlet) using multitester if there is an electricity or if you have extra power cord test it. Maybe that's the defect. If that's not the problem it is now the scanner itself, have it for the repair man or technician.
Thanks
Nov 19, 2008 | Epson Expression 10000XL Flatbed Scanner
Epson Expression 1680
Hi-
Do you have any existing drivers for new epson scanners( models), if you have then there are compatibility issues between new drivers and old drivers, are you using a leopard 10.5 operating system or tiger 10.4.**? try uninstalling every epson info from applications folder and from library/image capture and library/preferences. you an use the finder to search for epson scan and drg them all to trash. Try using image capture application as well if it will scan when you run it, then reinstall driver.
One more thing, when you click on epson scan, does it bounce continouosly from the dock? if it is then look for a subfolder and install everything in it.
Keep me posted, thanks!
Aug 27, 2008 | Epson Expression 1680 Flatbed Scanner
Trouble with an older scanner
I'm assuming this scanner interface is a SCSI connection. First thing you may want to look at is the SCSI ID number switch at the very back end of the scanner. Before changing the SCSI ID switch make sure your scanner is powered down. Repeat steps above when trying different SCSI ID numbers to see which one works with your computer. If you have other SCSI devices connected make sure they are not sharing the same SCSI ID # which will cause a conflict.
Jun 06, 2007 | Agfa DuoScan Flatbed Scanner
201 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
