Question about T-Mobile Dash Smartphone
DEVICE UNABLE TO BOOT - T-Mobile Dash Smartphone
What should i do if it is unable to boot?
Posted on Apr 30, 2010
Hp compaq unable to boot from usb
USB device should be recognized in the bios and make it first boot at the bios boot option menu.
Just plug in the usb device before turning on your computer.
Mar 05, 2013 | HP Presario Computers & Internet
Unable to find Disk error
1st check weather ur system detects the hdd or not
check weather the disk is connected to ur lapy
check the first boot device
set the first boot device to hddif still problem continuess then
replace the hdd
Jul 09, 2012 | Acer Aspire 5100-5480 Notebook
Reboot and select proper boot device or insert boot media in selected boot device and press a key? please help me proceed from this screen when starting pc.
Try putting in your windows disk and using the repair option, your hard drive could be bad or data corrupted, you may have to reinstall windows if you are unable to recover it using the repair console. run CHKDSK /p from the C:\ prompt in the repair console. If you still are unable to access the disk, try reseating the cables on the drive, or using a different power cable. If none of that works, replace the hard drive.
Nov 26, 2011 | ASUS X5DIJ Notebook
UNABLE TO LOAD WIN XP
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you should go back and change the first boot device to your hard drive)
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
hope this helps
Jul 20, 2011 | ASUS P5RD1-VM Motherboard
Unable to boot the windows xp cd
check your boot settings in the comp bios/cmos set-up, you should the boot order of the devices in your system, make cd/dvd romyour 1st boot device then make the hard drive your 2nd boot device then so on, save the changes you had made and reboot insert your windows installation disc then from there it will boot to the xp cd
Dec 07, 2009 | Dell Dimension 4600C PC Desktop
When I boot from a boot disk I am unable to change to another drive tells me each drivce is invalid. Also unable to boot from cd. I have 1) a drive (uncheck or check to turn off or on) 2)hard drive same...
Check the cabling between the drives. Make sure the BIOS sees your drives. Try swapping the ribbon cables between the drives and the motherboard. If you have to, disconnect each device and test them one at a time. This process should isolate the problem device. Make sure that the drives' jumper settings are correct, too (per cable if two devices, one master and one slave, or both devices set to cable select).
Mar 11, 2009 | Dell Dimension 4500 PC Desktop
Dell Dimension 5100
Replace the CDROM, or boot from a USB device.
Dec 15, 2008 | Albatron GeForce MX4000 EL, (64 MB)...
UNABLE TO BOOT htc touch pro
Yes. i solved the problem in my one
press:
vol down + restart + and the middle button = good :)
Dec 03, 2008 | HTC S710 Smartphone
voldown, central key and reset botom at the same time, then text appear, choose number 1 for restore manufacturer default pressing volup or 2 for restore munufacturer default and format moviMand pressing voldown and wait a few seconds.
Oct 16, 2008 | HTC Touch Pro Smartphone
Unable to boot from USB fey on D850MV Motherboard
Download updated bios here
follow instructions carefully to update bios
use the F8 key right after power up to select boot device.
May 09, 2008 | Intel D850MV Motherboard
T-Mobile Dash Smartphone Logo
116 people viewed this question
Top T-Mobile Computers & Internet Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
