Error code 10071 appears when calibrating an OCE TCS400 scanner
3 Suggested Answers
SOURCE: OCE TDS600 Error Codes
It might need a new fuse which is located where the hot wires are when the paper feeds through or it might need a circuit an Ormon G3NE-220 TL-US load 20A 240VAC 50/60hz input 24 VDC.
Posted on Aug 31, 2009
  • 990 Answers
SOURCE: Error code E020 0181 on oce cs115 how do we remove the code
Hello sir; Try to replace yellow color developer and then running"stir" or "install". should removed the error code.
Posted on Oct 10, 2009
My oce fx 2081 trouble code 05 help me pleas
OCE clear error message replace toner oce fx 2081 ... - Fixya
www.fixya.com/tags/clear_error_message_replace...oce_fx_2081/.../oce
Ask your Clear error message replace toner OCE fx 2081 questions. ... ...error code0501 message, though we've vacuumed it the toner as best as possible. ... ...error 2201 switch on/off messages very frequently on my oce 9400 machine, any solution!!! thanks Might be NTC6, which is located in ... 05 is appearing on the.
clear error message replace toner oce fx 2081 Questions ...
www.fixya.com > Forum > Tags
Find solutions to your clear error message replace toner oce fx 2081 question. ... ...error code 0501 message, though we've vacuumed it the toner as best as possible. Well ... ...error 2201 switch on/off messages very frequently on my oce 9400 ...
Sharp ARM 550/620/700 Reset Machine with Error Code ...
Dec 15, 2015 | Office Equipment & Supplies
Oce 3165 error code m22505, when I turn on the machine in the morning
downloads.oce.com
Find Oce drivers, manuals, software, firmware, safety data sheets and other downloads for Oce products.
Apr 28, 2014 | Office Equipment & Supplies
Oce scanner Error 10516-247
my oce TDS450 scanner has the 10516-247 error. Please help me
Nov 16, 2013 | Office Equipment & Supplies
Oce tcs500 scanner - error code 10514-246 scan failed. any solution for fix?
Repair of oce scanner with error code 10514-246:
The customer Service said that this error means there is not enough light reaching the camera and we have to let them replace the lamps. cost:1500€ :(
solution: i removed the backplate of the scanner (3 screws) and cleaned the lower mirror. it was that dirty that i nearly didnt find it. it is placed on the groud of the lower big hole behind the backplate.
After that i recalibrated the scanner and now it works fine again.
I hope this helps since there is no correct exlanation of this error on the web.
Nov 01, 2013 | Office Equipment & Supplies
Oce tds 450 scanner error 10508-54664
or you can ask the 24 hrs live technical support, they will like to help you, good luck http://www.diyobd2.fr/service/
Jul 29, 2013 | Office Equipment & Supplies
Oce' tds600 error code 10501
This is a scanner error. Clean the mirror with a soft lint free cloth. Be extremely careful as these mirrors are First Surface Mirrors and are easily scratched as well as being expensive. If the mirror and glass are clean, try the scanner power supply.
Dec 12, 2012 | OCE Office Equipment & Supplies
Oce TDS 600 scanner error code 10501
Clean mirror and scanner glass. Be extremely careful cleaning the mirror. Its a First Surface Mirror and extremely expensive.
May 22, 2012 | OCE Office Equipment & Supplies
My Oce Scanner has the 10514-246 error. Please help me !
my oce tcs500 error code 10514-246 start of scan failed
Sep 07, 2011 | Office Equipment & Supplies
All service codes for ricoh aficio 1075 are required urgently.
RICOH ERROR CODES
Error Code Description
SC184 CIS Transmission Error
SC191 Bar Code Scanning Error SC192 Automated SBU Adjustment Error/Bar
Code Number is Different SC193 Image Transfer Error/IDU Error
SC194 SBU White Level Detection Error SC195 DF Gate Assert Error/Serial Number Error
Error SC196 DF Gate Negate Error
Code Description
SC197 DF Gate Error SC101 Exposure Lamp Error
SC198 Memory Address Error SC107 Scanner Lamp Regulator Malfunction
SC199 DF Scanning Finish Error SC120 Scanner Home Position Error 1
SC201: Polygon Motor Error HP Sensor Abnormal-Stays Off
SC220 Laser Synchronization Detection Error SC121 Scanner Home Position Error 2
SC221 Scan Length Detection Error HP Sensor Abnormal-Stays On
SC230 BCU Received no Feedback from LD SC122 Scanner Home Position Error 3
F- Gate Error SC123 Scanner Home position Error 4
SC231 Laser Beam Feedback Signal Error SC124 Scanner Motor Encoder Signal Error
F- Gate Timeout SC125 Scanner Motor Speed Error 1
SC240 LD Power Supply Excessive SC126 Scanner Motor Speed Error 2
SC260 HP Sensor Error SC127 Scanner Motor Encoder Rotating Direction
SC261 HP Sensor Not Turning Off Error
SC285 Line Position Error SC128 Scanner Motor Start Error
SC300 Charge Corona Output Error 1 SC129 Scanner Motor Speed Control Error
SC301 Charge Corona Output Error 2 SC130 SBU defective Error/Scanner Start
Charge Current Leak Abnormal
SC302 Charge Corona Output Error 3 SC131 F-Gate Asserted During Shading
Grid Voltage Error Charge Roller Current Leak
SC142: White level detection error. SC303 Charge Corona Output Error 4
SC143 SBU Auto Adjust Error Grid Leak
SC144 SBU Connection Error Charge Cleaner Motor Error SC150 Scanner ROM Mismatch SC304 Charge Roller Current Correction Error SC170 Scanner DA1 Abnormal/Video Processing SC305 Charge Corona Wire Cleaner Error 1
Error 1 SC306 Charge Corona Wire Cleaner Error 2
SC171 Scanner DA2 Abnormal/Video Processing Charge Roller Home Position Error Error 2
SC310 Potential Sensor Calibration Error 1 SC172 Scanner DA3 Abnormal/Video Processing
SC311 Potential Sensor Calibration Error 2 Error 3
SC312 Potential Sensor Calibration Error 3 SC173 Scanner Lamp Regulator Adjustment Error
SC314 Potential Sensor Calibration Error 4 SC174 Scanner DA2 Abnormal
SC315 Potential Sensor Calibration Error 5 SC181 CIS Lamp Abnormal
SC316 Potential Sensor Calibration Error 6 SC183 CIS Auto Adjust Error
SC317 Potential Sensor Calibration Error 7
www.smilecopy.com
Aug 11, 2010 | Ricoh Aficio 450 Copier
Jul 13, 2009 | OCE Office Equipment & Supplies
214 people viewed this question
k24674
jasbo
jasbo
