Trouble shooting after few second cpu fan does not running, OC failure,My Computer configuration amd 3000+, Giga byte mother board,512 MB Ram, intel pocessor
    President:
  • 2,351 Answers
OC failure = over clocking failure. Make sure the CPU fan is clean, free from dirt & dust. Check CPU fan plug is connected correctly. If the CPU fan still stops after a few seconds replace the CPU fan.
It's harder to find just a fan to fit your heatsink, which sits on your CPU. It is easier to find a new heatsink \ fan combo for your Intel. Use your manual to find what Intel chip is on your board. Use that information & search google for a heatsink & fan combo. Pay close attention to how your current heatsink is mounted to the Gigabyte board.
Mike
Posted on Mar 24, 2008
    Scholar:
  • 47 Answers
If your computer just stop running the Fan and shuts down it means its failing to cooldown properly possibly cause
  1. its cooling system is blocked (dirty, cloth or just to close to walls then try unclogging or just giving it air from the walls and other perimeters )
  2. See if the fan is running on the processor (Sorry i havent considered yor mother board type) or if it is using a heat sink make sure the sink/fan is properly attached to the processor and is running
Computer need to operate below a certain temperature so it has a safety feature to turn itself off just before it get damaged
I can install windows 8 on MY pc?? cpu:amd sempron
I don't think you can run Windows 8 on your system.
What Microsoft say are the minimum requirements for a system to run Windows 8 can be found here
http://windows.microsoft.com/en-GB/windows-8/system-requirements
First, the processor needs to have certain features - SSE2, NX and PAE which I don't think the Sempron 3000+ has; and you be able to run only the 32-bit version if could run that because you don't have enough RAM, and your processor is a 32-bit processor.
Secondly, the 9250 isn't up to it. It doesn't have WDDM drivers, because it's not a true Direct 9X graphics card; it not being a DirectX 9 card is enough to preclude from running Windows 6 anyway.
Your processor, RAM and graphics card might be upgradeable to be able to support a 32-bit version of W8, but that may be more expensive than buying a (new) W8 computer anyway.
Anyway that's what my brief study of the topic has lead me to believe. It's a no.
On the other hand, see these:
http://answers.microsoft.com/en-us/windows/forum/windows_8-windows_install/amd-sempron-3000-for-windows-8/9b9c1659-63dc-4069-99fa-eb8e08040738
and
http://www.tomshardware.co.uk/forum/id-1806278/install-windows-cpu-amd-sempron-3000-ram-512-ddr-ddr-gpu-radeon-9250.html
(found by searching the internet with "running windows 8 on a sempron 3000+")
They say "Yes".
So I think more research needs to be done. Note the second article says the system will have terrible performance.
20.April,2014
Sep 19, 2013 | Computers & Internet
AMD Sempron, with sis 964 chip, the monitor gets no signal when the computer is turned on, any suggestions how to get a signal
remove the bettery frome the mother board for 10 minuts, and make sure the main power cable is unplugged, the try again....or your RAM might be broken,,,,
May 11, 2010 | HP dx2250 Monitor Personal computer AMD...
I have 512 mb ram, 2.66 2.66 ghz processor, intel chipset Fifa 08 works well on my pc Is it possible to play Fifa 09 for me?
You shouldn't have any trouble.
Minimum System Requirements for Fifa 09.
CPU with 2.4 GHz (single-core)
512 Megabytes of RAM (1 GB required for Windows Vista?)
DirectX? 9.0c Compatible 3D accelerated
128 MB video card or equivalent
(must support Shader Model 2.0 or above)
DirectX? 9.0c Compatible Sound Card
512Kbps or greater
broadband connection for online gameplay
MS compatible mouse
Keyboard
Cheers'
Mike
Mar 03, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Computer does not post. Fans & lights on.
Good day sir, as you describe your problem, as I see it you forgot to replace your Power Supply box. Swap in a new one, see if it runs. Also make sure that your RAM is good.
Oct 13, 2009 | ASUS A8N32-SLI Deluxe Motherboard
Hardware upgrade required for autocad 2009
Your existing CPU will not work with that motherboard. The AM2+/AM2 processor slot is for AMD processors only. For this motherboard, you will need one of the following processors: Phenom FX / Phenom / Athlon 64 FX / Athlon 64 X2
Jul 06, 2009 | Dell Dimension 8250 PC Desktop
New PC shutting down with MSI K9A2 mother board
this is a problem complexing situation because here are involved more than one device that causing this, if you have time and parts to experiment is a good think, you have to take out from your board cpu ram and vga-s and put in their place a second component(take from your friend or if you know that guy in service maybe halping you with parts so even him is taking experience of this situations). after testing your Mb with second components if it working fine no shut downs no crahes, then problem is in one of other components, try it taking out second parts one by one eny time, replacing with your components. begin with vga(or vga-s if you have more than one but is better to put it and prove them one by one to diagnose if their have problems) after doing this and you didnt finded problem in vga/s let your part in place and change second ram taht you puted with yours(if have more than a module prove it one by one each time reboting system after each one.) if even in your ram you dont have problems, so change cpu/s. one of this components without dubt is faulty.
if problem resolved and you dont have more problems and didnt find a faulty component and your pc is working fine so it was a miss making.
try all experiments with mother board outside case. some time shrt circuit of Mb with case is causing problem, after try it in case if you dont finded problems, in any way that i told you up.
Apr 07, 2009 | MSI K9A2 CF-F V2 AMD 790X AM2+ Phenom FX /...
I want to play Fifa 09 on my compaq presario 2100 amd athlon xp 2800+ 2.12 GHz,448 mb ram laptop,but it does not open.I don't have any graphics card but I want to install one.Which would be the most...
Sorry to tell you this but this laptops video card is permanently attached to the mother board. So upgrading to a new one is no possible.
Sorry,
Armymason
Feb 27, 2009 | AMD Mobile Athlon XP-M 2800+, 2.13 GHz...
Memory synchronization Problem
Did you reset the cmos on board first?
Jan 18, 2009 | MSI K8N Neo3-F Motherboard
Moniter Screen Blank when my PC start....Giga byte 8S661FXME-RZ Mother board
try to remove the motherboard from the casing and see it if the have some capacitors or any circuit distroy. use other mother board for testing chek your hardware one by one maybe some of your hardware devices damages.
Jan 01, 2009 | Computers & Internet
Computers & Internet Logo
594 people viewed this question
David Payne
David Payne
