Question about Refrigerators
Hi, my hotpoint Side by side hss25gf is running but not cooling well it has done this before for a few days and then resumed to normal but this time the temp has not returned to normal. The compressor is warm and vibrating to the touch as if it is running the fan in the condenser is running It seems that under normal temps that I hear more going on in the fridge side after I close the door. right now that does not seem to be happening... Any ideas? Also once I get it working again is there any problem with keeping the adjustment numbers on the colder side?
  • cvbndfgherty Apr 29, 2010
    Hey thanks for the info!
    Well the Heater tested good so If it is the heater thermostat switch would any type do or would I need a specific one?
  • 4,059 Answers
ONE POSSIBILITY
Make sure the evaporator fan inside the freezer behind the rear cover is running. In some models it won't run unless the door is shut so hold the door switch in to check. It circulates the cold air in the freezer and into the fridge through a damper (vent). Make sure the air is blowing into the fridge through it. Your fridge temp control opens and shuts the vent to adjust the amount of cold air getting to the fridge.
SECOND POSSIBILITY
DEFROST PROBLEM
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. Your motherboard is part 801 on this diagram and parts list. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5130309&diagram_id=22283831#d22283831
Your should be able to run it at any temp you want to. GE is known to have problems with the water dispenser water freezing in the door and you have a water reservoir in the fridge behind the crisper for the chilled water. It can freeze but in a fridge working properly the would be no problem.
Posted on Apr 28, 2010
  • Charles T Nevin
    Charles T Nevin Apr 29, 2010
    Any defrost thermostat will work just so the cut in and cut out temp is close to what is recommended and it will fasten to the evaporator coil. The one at the sears site is 8 dollars.
Freezer and frige are not cooling correctly. I have tried unpluging a few times and letting it get to room temp. It then works normally for a few days before going back to not cooling
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 14, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Hotpoint G/E Side by side refrigerator Model
I have seen this issues with GE and HotPoints. I recorded video for You. Hope this will help. I replace usually both : main board and evaporator fan motor.
Nov 24, 2010 | Hotpoint HSM25GFRSA
The freezer side frost up over a short period of time.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 16, 2010 | Hotpoint HSS25GFP Side by Side...
It freezes up every three days i have it set on five it not but two and haft yrs old plese help me thank you
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Aug 31, 2010 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
My freezer side is not cooling properly
I would say that you have a small leak and are looking at major problems down the road...
Checkout this tip that I wrote about that...
http://www.fixya.com/support/r4588788-refrigerator_or_freezer_not_cooling_or
heatman101
Apr 21, 2010 | Hotpoint (HSM25IFTSA) Side by Side...
Fridge/freezer cooling inefficiently
Either the repair guy did not wire up the heater correctly or he replaced the wrong part, if the heater was good it was likley to be the defrost thermostat...I would call the repair guy back to check.
Jun 23, 2009 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
I have a Kenmore Refrigerator that a friend just gave me that is about 5 years old in good condition. On the move we didn't lay it on it's back, but of course it was tilted back at times. Transported it...
How long have you let the unit run? Sometimes if you leaned it back too far you need time for the oil in the compressor to recess..to go back into the compressor. It normally takes a refrigerator 24 hrs. to cool but also up to 72 hrs. if after three days of continous run and not cool at all then you have a restriction in the system, in this case oil in the lines or a stopped up liquid line dryer. It's a filter for moisture and impurities in the closed system. Otherwise give it time to cool without putting the settings all the wayup. Put them on the factory settings usually in the middle of both knobs or whatever you have for adjusting the coolness. Overheating the compressor will not cool the unit and you might try shutting the unit down for a day and then resume again the next day at middle or lower settings. Make sure never to lay a refrigerator over on it's side! The life of a refrigerator should be up!
Randy
A.I.R. Appliances
San Antonio, Tx. 78209
210-822-1818/210-493-2700,cell 210-264-1471
Feb 24, 2009 | Kenmore 53642 / 53644 Side by Side...
Refrigerators Logo
51 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
