Question about Kitchen Ranges
Jenn air Fan and light switch
Need to reconnect the wires to the fan/light switch in a Jenn air Range model D146. There are 4 wires; black, blue, brown and white. Using a North, South, East and West as the four terminals on the switch. Pls. advise which wire is to connect to which terminal.
3 Suggested Answers
  • 848 Answers
SOURCE: jenn-air range model S136C
just go through the manual it will have digrams of how to give connection .........
Posted on Aug 26, 2008
  • 3614 Answers
may i know the exact model # of your unit, and the part # of your switch control.
let me know, thanks.
Posted on Aug 27, 2008
Cooling fan below range top goes on and stays on even when oven is off
That sure cools...
Jenn Air Oven SVD48600B continuous fan - ApplianceBlog
Dec 10, 2007 - 10 posts - ‎4 authors Turned the oven on to 250, and the cooling fan (not exhaust fan, not convection ...What part number would this be for our Jenn Air SVD48600B range? ... It may only be that the fan comes on and stays on when not needed. ... Caveat: the same thermometer says my Jenn-Air wall oven is also 50* below the ... Jenn-air JDS9860AAP Oven won't turn on - ApplianceBlog
Mar 24, 2013
Jenn-Air SVE47600 Downdraft Fan Not Working
Nov 30, 2010
Jenn Air Oven SVE47500B oven light and fan stay on ...
Nov 20, 2010
More results from
Nov 21, 2015 | Jenn-Air Kitchen Ranges
Replacing fan switch jenn aire D156
I have a Radio Shack 3-in-one remote control 15-302 and I need codes for Dinex says it is 4 numbers
Jan 01, 2014 | Jenn-Air Cooktops
The light fixture needed to be repaired. It never worked when I bought the house. New light bulbs didn't worked. I replaced the two ceramic light switches that had corroded wiring and reconnected blue to...
if its a duel switch that controls lights, and the fan seperately. sounds like the power for the lights is going directly to the fan, and therefore making the lights work also. also check out switch, make sure power is only going to the lights, with light switch on.
May 01, 2011 | Heating & Cooling
How yo wire up ceiling fan with light
Typically with only one switch controlling the fan/light the connections in the ceiling are white to white, black to black and blue. if you have a separate switch for the light and one for the fan, typically the wiring is white to white, black to black, red to blue.
Mar 07, 2010 | Dacor Remote Light Control for Ventilation...
Just installed a new Jenn-Air Model JED8430. Burners work well but fan will not turn on. Two black wires and a ground coming out of my wall....presumedley no neutral. Any suggestions
I suspect that the two black wires were attached to a wall switch or a wall times, along with the ground.
Check to see if you have a hot wire there. then temporarily wire the two black wires together and see if the fan comes on, i believe it will.
Jun 13, 2009 | Jenn-Air JED8430 Electric Cooktop
Jenn Air stove wired backwards
The fan is likely 120-volt fan, and swapping the wire likely put 220 across the fan. Did the fan seem to rev up very fast? The control is also likely 120-volt, and that too had 220 applied to it.
Give me the model number, and I'll find what parts you need to replace
May 13, 2009 | Jenn-Air SVE47100 Slide-In Electric...
Fan/stove light switch broke needs replacing
The original fan switch for the SEG196 (circa 1995) is a four terminal switch- two for the fan and two for the light . Note that the switch spade lugs for the red and blue wires (which when connected activate the fan) are larger than those for the white and brown wires (which when connected activate the oven light). This design presumably prevented miswiring of the switch at original assembly. Since the four terminal switch is nearly impossible to find (it was discontinued several years ago), an inexpensive fix is to replace the four wire switch with a two wire SPST toggle switch. However, this means that either the fan function or the light function can be preserved- not both. I elected to keep the fan function, and simply wired the red & blue wires to the two terminals of a heavy duty replacement SPST toggle switch. Be sure to fully insulate the remaining (in this case) white and brown wires with electrical tape or wire nuts before tucking them below the new switch. Total cost: $6.00 for switch. NOTE: TURN OFF POWER TO RANGE AT ELECTRICAL PANEL BEFORE ATTEMPTING REPAIR! beec3807-1ba5-40e7-a010-7e26d5fca5c0.jpg
Feb 18, 2009 | Jenn-Air JGR8850 Gas Kitchen Range
Jenn-air downdraft fan not working
there are 4 wires for that red white black and green sure you didnt miss a wire
Apr 15, 2007 | Jenn-Air JED8430 Electric Cooktop
Kitchen Ranges Logo
90 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
