Question about Karcher K2.26 Electric Power Washer
Model330m no power
When pluged in & turned on unit will not start. even tho the unit is old i have only used it approx. 7 to 10 times. a frend has the same unit & his unit did the same thing.
  • 299 Answers
With the water at the hose bib on the side of the house turn on the unit and see if any water flows through. If not, clean the nozzle as it gets plugged up when not regularly used. Also be sure the REST button on the GFCI plug is pushed in.
Posted on Apr 28, 2010
Where is the G202 and G203 fuse for a 2002 PT Cruiser located
G202&G203 are grounds if I knew what you are trying to fix it would be more helpful the power side of G202 uses fuses #5&9 for the airbag system G203 uses fuses #7,10,&20 for several interior components fuse block for #5,7,9,10 left of dash interior and power distribution under hood behind battery for#20
Mar 16, 2015 | 2002 Chrysler PT Cruiser
Ask questions
make sure that the crankshaft position sensor is pluged in(and to the rite connector)you can find it starting at the drivers side upper bell housing of the transmission,then chase it to where it is supposed to be pluged in.
Jan 03, 2012 | Jeep Grand Cherokee Cars & Trucks
Frigidaire Air conditioner: fas296n2a2 Compressor
Do you have an amp meter? and volt meter. Are you sure that the compressor is getting power? The click may simply be a relay closing but no power. Check both sided of the relay. You will need to trace the power and make sure that the compressor is getting power. Then check the amps to see how much power it's pulling.
Jun 15, 2010 | Heating & Cooling
I was playing music off PS3 HDD when we had a power cut for approx 0.5sec. Surge/spike protecter was fitted to power source, but no power back up was fitted. Error msg was on screen saying to turn off PS3...
This is a processor error. There is no way to get to the restore screen when you have the yellow light issue. Try CPR in NYC. They usually have a 1-3 day turnaround time, and are pretty cost effective. You can easily ship them your unit. They are faster and cheaper than Sony!
website is www.cpr-nyc.com
Hope it helps!
Mar 30, 2010 | Sony Playstation 3 (PS3) Console
My kodak M1063 digital camera was working great with no problem, my husband started useing it but the batterie was low and needed charging he didnt want to wait so he took out the batterie and put a...
The old used battery was probably not used for a long time and in time, completely discharged and died. It can't be brought back. I don't know why your camera won't turn on with the original battery.
Dec 23, 2009 | Kodak EASYSHARE M1063 Digital Camera
I want to use a 80gb hdd out my old xbox, externally thru my comp, but its locked & comp wont recognise it even tho it sees it being pluged in thru usb. So cant format as it not really seeing drive? so...
I suspect the harrdrive may be set as a Master and not as a slave. If you're familiar with jumper settings, change the drive to a slave and try that...
Here's a link to the WD Jumper Settings guide...
http://www.wdc.com/en/library/eide/2579-001037.pdf
Sep 20, 2009 | Computers & Internet
Viking Microwave Model VMOC205SS little over 4
9 amps is approx. correct. Does magnatron make an odd sound when running? If not, you will need to discharge cap then clean terminals with alcahol. Replace diode as well. Should run correctly.If blows again, replace magnatron. Suggest you put a 12 amp fast blow fuse in circuit and nor a 20 fuse.If you dont have a grill or an oven, use a 10 amp fuse.
Sep 17, 2009 | Viking VMOC205SS Microwave Oven
Dead unit
My Quest2 has a short in it that drains the battery even when it is turned off. But the battery lasts normal 15 to 20 hours when fully charged and unit is on. Whenever the battery is completely dead, I have to place it on the charger for a hour or two before the unit will even start even though it is plugged plugged in. The battery can be replaced by the staff at batteries plus for under $60.00
Oct 12, 2008 | Garmin Quest GPS Receiver
Minimal sound from subwoofer
MAKE SHURE YOU HAVE TOLD THE AMP YOU HAVE A SUB IN THE SET UP MENU UNDER SPEAKER SETTINGS.
IFF YOU ARE USEING SMALL SPEAKERS THEN SET THIS IN THE MENU AND OUT PUT BASS 2 SUB ONLY ,SET XOVER ON AMP IFF U CAN 2 120HTZ, ALSO CHECK THAT YOU HAVE THE SUB CABLE PLUGED INTO SUB OUT ON BACK OF YOUR AMP ,AND NOT THE 6 CHANNEL INPUT.
HOPE THIS HELPS.
CABLE GUY.
Apr 05, 2008 | Yamaha HTR-5650 Receiver
Karcher K2.26 Electric Power Washer Logo
194 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
