Question about Dell Dimension XPS PC Desktop
I have a Dell with Windows 98 2nd Edition which starts up OK except it looks as if it is in safe mode when my desktop appears. While starting up, however, I get a message: Cannot find a device file that may be needed to run Windows or a Windows application. The windows registry or SYSTEM.INI filerefers to this device file, but the device file no longer exists. If you deleted this file on purpose, try uninstalling the associated application using its uninstall or setup program. If you still want to use the application associated with this device, try reinstalling that application to replace the missing file. C:PROGRA~1MCAFEEMCAFEE~2SAFE&S~1FBWIN95.VXD Press a key to continue I have had no success with trying to correct this.
    Sergeant:
    Novelist:
  • 172 Answers
Hi mnewo1, after you finish loading windows (you might have to start Safe Mode by pressing F8 at the begining of the boot process), click on start - Run - and type "regedit" (without the qoutes).And click con Find (under edit menu) and type MCAFEE and click on search. You will find several files or access pointing to the file. Delete all the keys. **BE CAREFUL** If you dont do this carefuly you WILL damage the Windows. If you still have the same problem, check the system.ini under C:\Windows or C:\Windows\System32 - you may have to set the folder settings to view hidden files and folders ( under tools - folder options - view) but i doubt you'll find it there, bu then again, it's Windows 98. I hope this helps.
P.S: You may try an automatic registry cleaner, meaning it searchs the registry for deleted files but I dont know if supports Windows 98 - the name is Glary Utilities.
Posted on Apr 28, 2010
  • 561 Answers
Hi
Thank you for your query
Please can try the following
1) Click Start>Run
2) type in msconfig, and then click on the startup tab
3) Remove any ticks/checks which has the mention of mcafee in there
4) click OK and then restart
This will hopefully take the error message away
Regards
shauqat
How do I fix blue screen in dell zino 400 desktop?
What was the last thing you installed on it? Go to safe mode and remove that instillation. Also I would suggest downloading three service programs and run them in safe mode as well
Superantispyware (free edition)
Malawarebytes (free edition
Advanced System care (free edition)
If you still get the issue then back up your data and then do a system restore.
May 07, 2014 | Dell New Inspiron 400 Zino HD Black...
Unable to open defragmentation because missing file MFC42u.dll
Restart in Safe Mode and perform the defragmentation in Safe Mode.
Starting your computer in Windows XP Safe Mode can help you diagnose and solve many serious problems, especially when starting normally is not possible/Just before the Windows XP splash screen shown above appears, press the F8 key to enter the Windows Advanced Options Menu.
Jan 21, 2011 | Dell Dimension 1100 PC Desktop
My dell inspiron mini 10 bootes up to the main sceen but no icons nor start button appear.. please help
ok try starting in safe mode, keep pressing f8 on startup till menu appears, then run system restore if safe mode works
Aug 30, 2010 | Dell Inspiron Mini 10 Notebook
I have a Dell Dimension 24000 that has been in storage for a year. I recently tried to boot it up so I could find a couple of files. It starts booting up; windows logo appears and shows things are loading...
try starting in safe mode.
when you power on the PC, start tapping the F8 key on your keyboard.
this will give you the option to start in safe mode and can possibly let you find out why you cannot start up.
if it does start this way, you should at least be able to retrieve the files you were looking for.
Aug 06, 2010 | Dell Dimension 2400 PC Desktop
Windows installer wont let me download maplestory it ''says windows installer is not correctly installed or windows is running in safe mode''i want to know how to find the windows installer and get it out...
solution 1: your system is running in safe mode..as directed previously,restart the computer and on 1st screen(dell) press f8 5-6 times...and select start windows normally and enter...and try installing the same thing it will wqork
if not..
solution 2) then click on start> run > type services.msc > click ok > on right hand side in the list look for windows installer> double click it >property window will open up..if its stopped/ start it and from start up option select automatic >click apply ok..restart the computer. IT WILL WORK..
cheers njoy
Dec 06, 2009 | Dell Microsoft Windows XP Home Edition
Computer won't start except to take me to a DOS-looking Dell logo. How do I start the pc in safe mode?
Have you tried pressing F8 at bootup? If no, then do it now and be led to a menu with Safe Mode as one of the options. If that does not work, then try using the "Last good boot" option.
Oct 02, 2009 | Dell Dimension 2400 PC Desktop
Monitor is blank on Dell 3100
try starting in safe mode and then change setting
Mar 13, 2009 | Dell Dimension 3100 PC Desktop
Start menu toolbar does not appear on desktop
check this out maybe it can help..
in the desktop..put the cursor and right click-properties-select desktop-customize desktop-check the desktop icons you want..and click ok...just try maybe this is only you want..
Jan 04, 2009 | Toshiba Satellite A75-S213 Notebook
Icons & start
boot to safe mode..then do a system restore about 15 days back
Apr 18, 2008 | Microsoft Windows XP Home Edition
My computer
Search the Internet for a password changer. There are several out there. One I've tried is http://www.password-changer.com/order.htm. It's a $60 hit, but worth it in my business.
Mar 27, 2008 | Dell Dimension 4600 PC Desktop
Dell Dimension XPS PC Desktop Logo
32 people viewed this question
Alun Cox
