Question about LG DLE5955 Dryer
MY LG DISHWASHER AND DRYER ARE DUDS
Hi. I have 2 problems. First, my Lg front loader gas dryer from 2006 started to make a screeching sound while running and eventuall stopped turning. My LG dishwasher turns on , starts to fill then stops and displays LE on the digital display.My usual repairman does not work on LG appliances. Any suggestions? Thanks alot! Chuck
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 113 Answers
Hello,Sounds like a mechanical obstruction somewhere :->. Possible bad rollers or idler pulley. This could have snapped belt. Need to removed front door panel and lid to get at it. Open the door and rotate the inside drum by hand and see if it moves freely. If it does, you may rollers are probably good. Turn on power and listen for the motor turning on. If you hear a low hum then possible idler pulley or belt issue.LE error on DW - no quick fix here. I heard of wiring issues on the LG's, broken wires, that go from the control panel down to the motor/sensors/etc that result in this error code. I'm not up to speed on the LG dishwashers yet so maybe someone else can contribute.Rich
Posted on Jul 23, 2010
My LG Model DLEX3360 dryer will turn on, run about 20 seconds and stop running -- but displays still says it is drying.
Dryer Thermal Fuse Replacement - LG Electric ... - YouTube
? 5:29
https://www.youtube.com/watch?v=b74Mt5sSgRI
Dec 21, 2012 - Uploaded by RepairClinic.com
Dryer Thermal Fuse Replacement - LG Electric Dryer Repair (Part ... The most common reasons for replacing the thermal fuse are when the dryer won't start or ... I have an LG GAS DRYER model # DLGX8001V and it will not ... My front load dryer won'tturn on. .... My LG dryer recently stopped working.Missing: seconds
LG Electric Dryers, no heat? Try this first... - Home Forums
ths.gardenweb.com > Home Forums > Laundry Room
Apr 1, 2006 - I own an LG Electric Dryer model DLE0332W. ... Serviceman: The part you need is a heat regulator and its going to run you about $20 and the labor ... Look into the hole to the left and you will see the Heater Unit right within reach. .... Came back a second time because it still wouldn't dry my clothes (maybe ..
Nov 24, 2015 | LG Dryers
My front loading LG gas dryer does not heat up to dry the clothes, the dryer runs with cool air, what can be the problem and how can we fix it?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101][][
Jul 25, 2011 | LG DLE2532W Electric Dryer
My Lg dryer is 2 yr old, it is gas, front loader. It is not heating p to dry clothes
heatman101';
Jul 17, 2011 | Dryers
Dryer making loud screeching noise LG Trom DLG5988S
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Jan 03, 2011 | LG DLG5988 Gas Dryer
My LG tromm dryer wont heat and i don't know how ignite the pilot
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 02, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
I have an LG gas front load dryer that buzzes and won't start running when i turn it on.
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Jun 10, 2010 | LG DLG5988 Gas Dryer
Lp conversion for LG dryer
After removing the three screws which pass through the L bracket into the back of the dryer:
Stand in front of the dryer and (using the palms of your hands) give the top a sharp push back on the dryer top at the left and right side of the top. The top should slide back 1 to 2 inches. Now lift the top off.
If you post again with further questions, make sure to post under the model number you have. (you posted using a combo washer / dryer, and stated you are converting to LP, which combo units are not gas.)
Apr 18, 2009 | LG WD-3243RHD Front Load Washer / Dryer
How do I reverse the dryer door on my front loader LG
No electronics involved in reversing a LG dryer door. On a difficulty scale of 1 - 10, it rates about a 2. Go for it.
Mar 06, 2009 | LG WM0642H Front Load
LG Dryer overheating
check vent outlet out side house is it blowing out air.
Dec 24, 2008 | LG DLE5977 Electric Dryer
LG DLG 5988 Gas Dryer Does not heat and does not dry
Same problem after 1 year of use. In the past couple of months, the Sensor and Cooling mode light stay on and unit does not dry.
Oct 08, 2007 | LG DLG5988 Gas Dryer
LG DLE5955 Dryer Logo
155 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
