Question about Garden
I just bought a new Husqvarna riding lawn mower, yth22v46, and I was following start up instructions and checking to see if the lawn mower blades were tight. I moved the blades and the spindles sqeaked and groaned like metal on metal. Is this normal for startup of do the spindles need to be greased. I saw no evidence of grease zirks. Please reply, I would hate to burn out the mower spindles on a new deck. Mike McCarney mcbrossard@meltel.net
  • 251 Answers
Hi. this is quite normal mike as the blades have a brake/clutch arragement.
Posted on Apr 28, 2010
Where is the stater relay located on husgvarna 22/46 riding mower?
Husqvarna YTH22V46 Lawn Mower Tractor Parts
exploded view in here
stater solenoid follow the wires from the the key
Oct 20, 2016 | Garden
I need to route the belt on my Husqvarna YTH22-46 riding mower.
Please follow the link to the owner's manual, the belt routing is shown on page 18 of the pdf file, scroll through the pages at the top to get to page 18.
Husqvarna OWNER YTH22V46 Owner Manual Service And Adjustments
Aug 09, 2016 | Husqvarna Garden
Left side is scalping especially when turning
Stephen Bent/damage blade or spindle, check your deck for support link pin missing, damaged or rusted out brackets, blade spindle loose/mount damages or rusted out, missing deck support spring,wheel/roller if equipped, damaged blades, Recheck tire pressure and front steering axles for bent/damage, etc.
When measuring deck for level, measure at blade tips not the deck on a flat level surface. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Lawn Mower Quality of Cuts Problems and Solutions
How to Adjust the Deck Height on Husqvarna
Craftsman Riding Lawn Mower cutting uneven
cutting uneven chopping up ground Craftsman Riding Mower
Jun 06, 2016 | Husqvarna Garden
How is the mandrel shaft assembly removed from a broken housing and replaced into a new housing? Are there any shop diagrams I can look at?
Use a wood block to hold the blade back while removing the top bolt. then remove the blade. finally knock the shaft out from the top, should free up with a slight hit on the grease fitting and come out through the bottom. Goes back in the same way.
Apr 28, 2016 | Husqvarna YTH22V46 46 inch 22 HP Briggs &...
Husqvarna YTH22V46 install clutch cable
Do you mean the electrical cable which feeds the clutch?
Jun 24, 2014 | Husqvarna YTH22V46 46 inch 22 HP Briggs &...
Excessive vibrating
Exsessive vibration is normally attributable to the mower deck. If the vibration is occurring while the blades are engaged and cutting this would indicate a need for further investigation. Check the blades for damage or uneven ware. If the blades are new or appear in good shape check the mandrals and shafts to ensure they are not Brocken or bent. You can get mandrel assembly's for around $60.00 online and replace all you need in one go.
Jun 14, 2014 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
Reverse operating system
Check the switch down by the gear shift lever, and the wiring to the switch, if one of the wires has come off the switch it will give problems.
May 30, 2013 | Husqvarna YTH22V46 46 inch 22 HP Briggs &...
Blades will not engage on Husqvarna riding mower.
Could be a broken belt, loose belt (stretched) or something is under the mower deck jamming the blades. (stick for an example)
Apr 14, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Garden Logo
187 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
