Question about Kodak ESP 5 Printer
Stop printer from printer printing fax lost job sheet
My ESP 9 printer always prints a "fax lost job sheet" whenever the printer is turned on. I tryed following directions (twice) given in a previous email, but that has not worked. [8 steps]
Any more suggestions?
  • 295 Answers
SOURCE: ESP-7 won't print black ink
go to main menu,go to maintenance and then clean printhead go for deep cleaning .. and then caliberate printer from main menu.. ur printer will be working fine.. if not call kodak all in one printer support, they will replace ur printhead.free of cost
Posted on Jun 22, 2009
SOURCE: Printer will not use cyan
I posted as Guest on the 19 Dec 2007 and I got my problem fixed after talking with Kodak and a bit of troubleshooting on my own. Here are the steps I went through:
1. Disconnect the printer from the computer and print a test page following the steps in the Kodak manual which you can download from Kodak. If the printer prints a good test page then reload the printer drivers on the computer. If the printer doesn’t print a good test page then download the Kodak firmware updater and check to see if you have the latest firmware and that the checksum from the printer is correct. If it the checksum on the printer doesn’t match then reload the firmware and try the test page again, if the checksum does match then move onto step two. NOTE: Kodak rep (unofficially) confirmed that the 8500 has two major problems, the grey rollers becoming dirty and fail to transport the paper, and the ribbon three color sensor system stops working which causes only one or two of the colors to print which is the problem we are having.
2. Open the top door (which holds the print head) and locate the sensor to the right of the sticker which says “Phone and provide this K number” this would also be (with the door open) top and aft of the print head. The sensor is about 1/8 inch round and has four very small black dots in it arranged in a square pattern. This is the ribbon sensor; clean it with a cotton swab moistened in alcohol.
3. Remove the ribbon tray and set it aside and look at the forward receiver that the front part of the ribbon tray would rest in. Trace a descending line with your eye from the ribbon sensor to the forward receiver and located along the rear edge of the receiver you will find a clear LED which is the light transmitter; clean it with a cotton swab moistened in alcohol. Reassemble the printer and print a test page, if it prints okay then great if not then onto step four. NOTE: From this point on it gets involved so if you’re not comfortable taking things apart you might want to find a friend who can help you. Oh yah, legal note, I’m also not responsible if you mess up the printer following these instructions.
4. Open the top door again and locate the three screws on the metal plate at the very top (with the door open) and remove them. This will allow the plastic cover piece to be seperated from the print head assemble and allow the head to be closed while the plastic is open. (NOTE: I found the use of a magnetic probe and tweezers helpful in making sure I didn’t drop any screws.) We are going to try to determine if the sensor or the LED is bad by boosting the light to the sensor. With the print head assemble closed and the plastic cover up shine a flashlight along the front edge of the print head assemble where the sensor is located, try to shine the light at a angle as if you trying to see the sensor. Now while doing this print a test page. If the test page is good then we have determined that the LED is not putting out enough light and you can go to step five, if bad then I suspect the sensor is bad. Since my problem was the former I can only suggest you try to get another printer off of EBay and swap out the sensor, don’t bother with Kodak they do not have any replacement parts as I already tried ordering the LED and the sensor.
5. The good news is that with a simple adjustment you can probable fix your printer the bad news is getting to the adjustment point is going to require removing all the plastic covers from the printer. Remember you don’t want to drop any screws, I did and spent a good two hours disassembling far more that I wanted too to recover the lost screw. If you do drop something into the printer you will soon begin to appreciate why you paid $600 to $1000 for this printer as it is a mass of layer upon layer of mechanical pieces. This is also a good time to clean as many of those grey rollers with alcohol as you want to get to, since I dropped a screw into the bowels of this thing I was able to get to all five bars by the time I was done (yah, there some in there you can’t even see).
6. Remove the plastic print assemble cover by lifting it out of its plastic pin holders. Then start with the top light grey cover (6 screws), then the back panel (4 screws), then front panel (2 screws), and finally the sides (2 screws each) being careful to note that the side panels have tabs underneath the bottom of the printer. Then with the front of the printer facing you locate the lower vertical metal plate (below where the paper tray is inserted) which should be held on by a remaining four screws. Remove this plate and behind it you should find a circuit board in a metal box.
7. In this box is several cutouts that the metal plate was covering, locate the left most light-blue potentiometer in one of these cutouts (the potentiometer is a little round plastic thing that looks like it will take the tip of a Philips (+) screw driver to turn it). Turn the potentiometer a quarter turn counterclockwise. You can now skip to step eight, or for those of you who are technically inclined you can compare your findings to mine. There is a small three pin Molex connector to the left of the potentiometer (about one inch) with nothing connected to it (I think it is used during manufacture’s calibration as it is connected to the sensor’s system LED) the pins are from left to right; pin 3 Ground, pin 2 LED grey wire, pin 1 LED blue wire. I hooked a voltmeter across pins 2 (+) and pins 1 (-) and with power on and NOT printing I took an initial reading of +5.16 V dc and after adjustment it read +5.12 V dc. Since my meter is probable not calibrated the thing to note is that it was a difference of 0.04 volts, this seemed to be enough to get mine working again.
8. Now place the light grey plastic top cover on the printer, close the print head assemble and set its plastic cover on top of it. Do not attach anything with screws yet. Power up the printer (and be careful as I am sure there are exposed 120 volt areas that you don’t want to touch) and print a test page, if the page comes out good then the printer is fixed, if not then turn off the printer, unplug it and go back and adjust the potentiometer an additional quarter turn and try again. In my case the first adjustment worked and I can’t promise that further adjustments will not damage the printer, so continue to adjust at your own risk.
9. If you have fixed it then reassemble the printer and pat yourself on the back for not having to throw the thing away. P.S. If at anytime you let the magic smoke out of the printer you will probable need to buy a new one, so make sure you turn off and unplug the printer before adjusting the potentiometer.
Why this fix might work is that as these printers get old (mine was made in 2002) the LED light output degrades and hasn’t got enough power to activate the sensor through the cyan film which is the darkest color, by adjusting the potentiometer you are changing either the output of the LED or the sensitivity of the sensor.
Hope this helps.
Posted on Dec 24, 2007
SOURCE: Kodak ESP-3 Will not print calibration page. It goes thru the motions, spits out blank paper. This is supposed to happen prior to connecting to computer or installing software. Tried two printheads
FYI The printheads that were manufactured for the kodak printers were in a factory in America when they realised the printheads were getting too hot. As a result over half the printheads they produced do not work thus the amount of well known problems with the 5100, 5300, ESP3.
The only way to fix the problem is to contact Kodak and they will send a new one to you along with a free set of inks as a kind of compensation.
Hope this helps!
Posted on Oct 24, 2008
SOURCE: ESP 7 paper jam error
I had the same problem, but after pressing the OK button when the paper jam came up again I pressed the CANCEL button and was able to print my document. See if that works for you too.
Posted on Apr 12, 2009
  • 214 Answers
SOURCE: Constantly cleaning the print head
I feel you should take it back. Under warrantee?
Posted on May 01, 2009
How do I stop the test page from ALWAYS printing from my WorkCentre 7120 printer?
If I am not wrong you are asking about Banner Sheet? I guess. close all your open applications and go to Device and printers, then right click on the 7120 printer and select printing preferences, then go to advanced Tab. select + next to Paper / output. you will see (print ID on Banner Sheet) select it and go for the option Disable job ID. make your changes save by pressing ok.
Apr 07, 2014 | Xerox WorkCentre 7120/P Printer
Prinnter not printing but showing 'put custom in manual tray'
There is still a print job in the queue. Place a sheet so it prints or kill the job.
Open Printers and Faxes. Open printer. Highlight jobs and Right click > Cancel, or Documents > Cancel.
For those stubborn jobs, Right click My Computer > Manage. Choose Services and Applications > Services > Print Spooler. Right click and stop. Then start. This may have to be done from the Print Server if it's network printer. Contact IT to kill.
Nov 09, 2012 | Office Equipment & Supplies
I tried to cancel printing jobs once in progress and had no succe
Printers will hold the documents in the memory of the printer. Windows holds the documents until they are received by the printer.
Go to the printer and cancel the job, then open the printer by double clicking on it in Printer and Faxes (if in XP) and cancel the document from the menu while the document is highlighted. (document, cancel)
A trick I have used is to remove the paper from the printer, wait until the last sheet is printed and turn off the printer. Windows will pop up with an error that includes cancel the print job.
Jan 23, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Won't print or copy black. won't send fax but am hooked up to a digital phone line with clear. Prints out fax report in black. test page doesn't print black ink.
for fax if u have a dsl line,u should have a dsl splitter,if analog line,its fine. u also need to claen printhead of printer and upgrade the firmware of printer,issue will be solved i tried it and it worked on my ESP-9
Aug 18, 2009 | Office Equipment & Supplies
When I print, it says spooling
Go to Control Panel, Printers and Faxes, Cancel any pending document on your Kodak Printer, then delete all kodak icons.
Turn off the printer, Unplug and Replug the USB cable, then turn on the printer. If nothing happens..
Second options: Click Start then select Run Type the word "net stop spooler" then "net start spooler" Then unplug and replug the printer while its on.
Josh
Aug 18, 2009 | Kodak ESP 5 Printer
My printer wnt work i boght new ink but it wont print
Hi
whenever you put new ink cartridges,your printer prints an alignment sheet
if your printer isn't printing,
one of the concern could be that it didn't print the alignment,uninstall the cartridges and put them back again.
also try printing an alignment sheet using the printer driver located in the control panel,printers and faxes
once you go into the properties and click on the device settings and click on service this device you will get option to print alignment sheet
this should work
Jul 17, 2009 | Dell 926 All-In-One InkJet Printer
When I print on my Canon MP730, it always prints out a blank page after every print job. How can I fix this?
SOLUTION(S): Reset the Sheet Feeder Gears
If the power fails while the paper is feeding or during a print job, the paper feed gears will lose their proper
alignment. The reason is that after the power is restored the paper feed gears will attempt to return to the
home position, which may not be possible if the paper stop cam is not in the correct position.
PROCEDURES
1. Remove the sheet feeder from the unit.
2. Remove the sheet feeder motor from the sheet feeder assembly.
3. Remove the drive gear from its spindle.
4. Realign the lifting tray gear and paper stop cam gear.
5. Reinstall the drive gear and sheet feeder motor.
6. Reattach the sheet feeder to the print unit.
7. Reassemble the unit.
Jan 11, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
HP Laserjet 1018 won't delete a printing job
to delete the print job.
shut off the printer, disconnect the printer cable to the computer.
go to strat>>printer and faxes.
open the pirnter queue. stop the print job then delete. you may have to restrat the computer.
once the job is deleted, connect the printer cable back to the computer and turn on the printer.
Jan 09, 2009 | HP LaserJet 1018 Printer
Whats error code 3501
According to Kodak, that error just means the cover was open. I noticed when I print a diagnostic sheet that error shows up whenever I change the ink.
Sep 02, 2008 | Kodak ESP 5 Printer
Kodak ESP 5 Printer Logo
517 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
